Question about GE Refrigerator Glass Shelf Part Wr71x2173 Wr32x1481
How to remove glass from main shelf frame on ge model PSS6PKWBSS
4 Suggested Answers
SOURCE: Is the glass surface on my GE Spectra solid surface glued to the heat element frame ?
The exterior panel (stainless in my case) is "glued" by adhesive to a lower metal piece which attaches to the door. I know this because my front panel came unglued and there is no other means of support. I am buying a very expensive new front panel.
Posted on Nov 03, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Trying to replace handle on
You order parts and find helpful exploded view diagrams here.
I'd recommend that your bookmark this link to your favorites.
Posted on Jan 31, 2010
  • 34206 Answers
SOURCE: How can I remove the glass/screen frame from the door of a GE JVM1653 microwave oven for cleaning?
This is not recommended maintenance.
Posted on Apr 17, 2017
How can I remove bottom shelf?
It is possible that the frame was not intended to be removed. Only the glass can be removed for cleaning. The frame will have to be cleaned in place.
Feb 01, 2016 | Refrigerators
RF197ACRS Samsung fridge How to remove glass from the shelves to clean
Well, I don't know about the individual shelves, but for the long glass shelf above the crisper drawers, there are two white clips located at the back edges of the glass that need to be pried out with a knife blade, or something similar. Place your blade in between one of the grooves of where the clip meets the plastic frame (and, NOT between the clip and glass! ) and pry the clip with a bit of a sideways motion. It's a little stubborn, but if you break a clip, don't worry, you really don't need it for the shelf to function.
Anyway, after you pry up the two corner clips, lift and slide the glass toward the back to get it out of the front groove, and voila!, the glass comes right out.
Aug 14, 2015 | Samsung / RF197ACRS
How to remove the glass shelf for better cleaning PSC25MSSC
if the glass has plastict trim like pieces across the front and rear edges try pushing up on the glass close to the plastic trimat th rear end, the trim should swivel up and the glass pop out of the groove
May 03, 2015 | GE Refrigerators
Can you remove the glass shelf above the 2 vegetable boxes in a RFG23UERS.
It's probably removable. Drawer below needs to be unloaded and removed. you probably can push the glass up from below. Otherwise pleas consult your owner's manual.
Mar 08, 2015 | Samsung Refrigerators
Trying to replace handle on GE microwave oven #JVM1631WB. Have already removed plastic cover that trims the glass on the inside of the door. This exposes two screws on the handle of which I have removed....
Jan 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How can I buy more shelfs for my fridge Galaxy 106
yes you can they are spendy the shelf is a 2 part. the glass which is like 70.00 or better. and you have the shelf frame. that is priced around 50.00 plus shipping. hope this helps. There are several parts warehouses where you can purchase them. glass shelf part number is 2177986 and the frame is 2163572. this is for the fridge side.
Aug 06, 2009 | GALAXY Microsystems 25.4 cu. ft....
Oct 19, 2008 | GE Spectra JBP78 Electric Kitchen Range
GE JVM1650BB005
You can search under Repair Parts and enter your full model number JVM1650BB005 and get an exploded view diagram here: http://www.geappliances.com/shop/prts/ That diagram can be a great help. Also, I've attached below a door panel diagram from a Sharp model. Your GE disassembly may work the same way. If you haven't already taken the door off the microwave, I would recommend you don't unless you leave the hinge assembly attached to the door and remove the door from the hinges. It's critical to be sure you get (or keep) the door and hinged aligned exactly as they were to prevent leakage.
Dec 05, 2006 | GE JVM1650 1000 Watts Microwave Oven
GE Refrigerator Glass Shelf Part Wr71x2173 Wr32x1481 Logo
14 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
