Question about Carrier Hn51kc024 Coil Sp Contactor 24v P282-0311
I have a bad HN51kc024B contactor on a Carrier heat pum and I am replacing it with an HN51KC024 from Carrier. (they dont have an A or B anymore). The wiring is different...can anyone map out the old wiring to the new part? thanks?
  • 6 Answers
SOURCE: CARRIER AC UNIT
please summit model number and maybe i can help.
Posted on Nov 14, 2007
  • 230 Answers
SOURCE: Carrier A/C units
Double check that the new contactor has the same electrical ratings on it. My guess is that the coil should be 24v while the relay should be able to carry the same amperage at 220v.
First shut off the breaker and disconnect switch for the furnace and outdoor condenser and call a licensed HVAC contractor:)
If you are determined to do it yourself, Then read the schematics first. Be aware, if you mis wire the system you may cause more damage than you have now. Not to mention your personal safety is at risk.
I am basing this on the most common style contactor found in my area.
The main relay side should be labeled. (eg. L1,L2-T1, T2). These should match exactly like the old one. L1 and L2 are the incoming power. T1 and T2 are the power leaving the contactor. All the 220v wires should correspond to one of these four terminals either by screwing them down or fitting the spade connectors together.
Usually the 24v wires will plug onto the coil (near the bottom, left and/or right sides of the contactor) silver spade connectors.
(STEP 1.) Leave all Wires Connected to your Old Contactor.
(STEP 2.) Remove the two mounting screws that hold the Old Contactor to the Air Conditioners casing.
(STEP 3.) Now Install the New Contactor to the old contactors existing location using the Same two Screws.
(STEP 4.) Now take Off one wire at a time from your old Contactor and Install each wire one at a time to the proper location on the new Contactor.
Posted on Jun 25, 2008
vanni7
  • 163 Answers
SOURCE: 3 amp fuse blows on a carrier 58mcb furnace board
Hi!!! Does your ac unit work fine?If not check your low voltage problem..You have a low voltage problem check the wire going out to your condensor make sure that they are not touching..Good luck..Check low voltage wires..short in progress..
Posted on Jan 04, 2009
  • 116 Answers
SOURCE: My ac fan went out on a carrier ac unit. Need wiring help
use a seperate capicitor for the fan only pick up 1 leg of power from common side of the compressor cap and the other from the contactor or the board in a heat pump situation
Posted on May 11, 2009
  • 38 Answers
SOURCE: outside carrier unit doesn't come on when thermestat on cool
The board is bad, what you can do is splice into the common (blue) and Yellow t-stat wires and connect them directly into the contactor and hopefully the reversing valve engages, giving you cooling for the time being
Posted on May 18, 2009
Carrier heat pump loud hum even when turned off
Look down into the unit through the fan frill. Is the large pipe from the compressor frozen over?
Aug 04, 2016 | Carrier Heating & Cooling
I have a carrier package unit 50HJQ005-631 SERIAL 160BG50314, condenser fan motor wont come on, we found motor was gone and we replaced, capacitor too is new, but still dont come on.we test the contactor...
are you getting power to contactor? 240 volts. is the thermostat calling to the contactor you should have 24 volts to the contactor from the thermostat to turn it on the out side unit. check to see if the contactor is suck in this is in the middle of the contactor you can push it in to see if you are getting power if you push it in then youa re not calling from thremostat.
Oct 24, 2013 | Carrier Heating & Cooling
I have a Carrier 38CKB048 and it runs without shutting off.
99.9% probability that your contactor is stuck/sticking. Replace the contactor.
Apr 27, 2010 | Carrier 38CKC024 Air Conditioner
Have carrier heat pump that buzzes
What exactly does it do? If it buzz and don't turn a starting capacitor will not help, this is an indiction of a shorted motor.
Jul 02, 2009 | Carrier 38CKC036 Air Conditioner
Contactor not pulling in on cooling for carrier pack unit
If the T-stat is on cooling take a volt meter and touch one lead to each side of the low voltage termanals on the contactor and if you have 24 volts the contactor is bad, if not start back tracking
Oct 31, 2008 | Carrier Heating & Cooling
I HAVE A 10 YR OLD CARRIER HEAT PUMP.THE CONTACTOR POINTS WERE REPLACED TWO MONTHS AGO ,THEY ORIGINAL POINTS WERE PITTED AND NOT OPENING CAUSING COND. UNIT TO KEEP RUNNING.THE NEW CONTACTOR POINTS ARE...
First, check your compressor wires connections for loose or coroded, then clean them (file or sand them or just add oil to the ends connectors and go with a higher 24-va contactor instead of a 40-va, maybe a 80va 24-volt contactor.
Sep 04, 2008 | Heating & Cooling
Tuneup kit for BDP A/C model 5690J042
Hi, most of the time generic parts are used to replace bad ones. The voltages and microfarads or UF is what's important on the capacitors and the amperage and control voltage on the contactor. Your unit will not run better with new parts and I suggest your time and money be used to clean and check your unit instead of "tuning it up" with new parts. If the capacitors are swelled or leaking oil they need replaced. If the contacts are pitted or burned, they need replaced. The condensing unit will need cleaned from the inside out. Remove the fan assembly and spray from the inside out on each of the condensing coils to remove the debris stuck inside the fins. If there are oil ports on your fan motor, add about 4 drops of oil into both of them. The same on your inside fan motor. If it has a fan belt inside check it to make sure it isn't worn too badly. Adjust it if needed to give about 3 inches of play. Too tight will make your bearings go bad. Oil your bearings if the fan has then and they have oil ports. Check the evaporator inside to see if it has a blanket of fuzz on the side where the air enters it. It can be removed with a credit card when wet. Scrape along with the fins if it needs cleaned. With the unit running and the inside of the house fairly comfortable the large refrigerant line outside should sweat all the way up to the compressor but the compressor should remain fairly dry. If it does, you have a good refrigerant charge. With this cleaning and oiling your unit should work more efficiently and be ready for another year. NOTE: The heating/air-conditioning companies usually run a special on seasonal checkups. If you have one come out, Have them do all the above plus get your furnace cleaned and ready. If you want more information on the furnace, please let me know what kind it is and I will try to help. If this solution does not rate at least (ALMOST THERE) Please do not rate. Thank You. kstfas
Sep 28, 2007 | Carrier 38CKC042 Air Conditioner
Carrier Hn51kc024 Coil Sp Contactor 24v P282-0311 Logo
127 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
