Crosley washer washer wont fill with water. it runs into it but drains out immediate
  • Frigidaire
    Frigidaire May 15, 2014
    Good Afternoon Billie, I understand that you are having trouble with your Crosley washer. I see that water is running into the washer and then draining out immediately. I will be more than happy to assist you. I would please like to have your model number, so I am able to better assist you. You can find the model number located on either the door or around the edges where the door meets your washer. Looking forward to hearing from you. WP
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 59 Answers
Have you just had it installed?
if so, check the wastepipe isnt syphoning
Posted on May 31, 2014
  • 45 Answers
SOURCE: washer won't fill
On the drain valve there must be some dirt that does not let the valve close or the valve must be defective and needs to be replaced. By the way you did not mention the make of the washer.
Posted on May 11, 2008
jsrock516
  • 5911 Answers
SOURCE: Washer keeps draining
Sounds like you may have a siphoning problem. The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Double check your installation and drain hose placement. You need to ensure you have an air gap to break the suction caused by the drain line. In the event that this is not a simple siphoning issue, please let me know if you require additional assistance. I hope this helps you.
Posted on Oct 29, 2008
  • 77 Answers
SOURCE: washer fills then nothing
may b the carbon brushes on the motor
Posted on Apr 26, 2009
SOURCE: Washer wont drain and spin properly
whee is th drain filter on crosley front loader
Posted on Jan 09, 2010
beltronic205
  • 1460 Answers
SOURCE: GE Washer Wont Fill
Make sure drain hose not too low , creating syphon...
Posted on Jun 01, 2010
Testimonial: "After posting this question I saw something on the internet suggesting the same. I think this must have been the problem. Thanks for your help!"
Does not fill
nF = no fill so you need to check the water valve see it the screen is clogged or if the water valve is recieving electricity during fill mode. I bet on a clogged screen
Feb 13, 2014 | Crosley Washing Machine CAH4205AWJ,...
Washer fills then drains immediately
Motor plug faulty. Remove and check for burnt wires.
Dec 08, 2013 | Zanussi ZWF1430W Front Load Washer
Crosley 1244 washer won't cycle
This indicates a faulty lid switch.
Apr 27, 2012 | Crosley Washing Machines
Leaving detergent spots. the machine fills up with water washes drains leaves detergent spots on clothes
If you dissolve the detergent in a bucket of water before adding it to the clothes you wont get this problem.
Nov 14, 2011 | Crosley CAWC529JQ Top Load Washer
Will not hold water ,when filling it just drains out
I just had this problem also. The reason I was having this problem was that I was letting the draining hose run into my bath tub to drain. Because of this the water was immediately draining out of the washer. So I had to hook the draining hose onto my bathroom sink to drain. By raising the hose higher,the washer filled up with water and worked just fine. Hope this helps.
Jan 24, 2010 | Haier HLP21E Top Load Washer
Washer will not fill but immediately goes to the agitation cycles. I figure the water level sensor?
yes! check and reset or change the water level switch that sounds like a good place to start
Jan 19, 2010 | Crosley CAWC529JQ Top Load Washer
Continues to fill, not holding water
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
If the above adjustment doesn't produce positive results, replace the control.
May 31, 2009 | Crosley Washing Machines
Apr 02, 2009 | Crosley CW5000 Front Load Washer
Washing machine doesn't full up
Raise the drain hose and or repair the air gap where the drain hose enters the drain line.
Mar 10, 2009 | Crosley CAWC529JQ Top Load Washer
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
