Question about Vacuums
Need some one fix my hoover
Water got into my hoover sparks come out then it spot!
  • 2,509 Answers
Don't use it it could be dangerous, and take it to a vacuum repair shop.
Posted on May 14, 2014
My hoover F5515 was working fine but when I pulled out the tsnk to remove dirty water and place it back and turned it on, brushes stop rolling.
Hello Sonny! If the dirty water tank is not put back on securely it will prevent brushes from spinning. Take off the dirty water tank and replace it making sure it locks onto the cleaner and is flush. Now check your brushes for obstructions. Remove all hair and debris from the brushes. If the brushes still will not spin take your cleaner into a Hoover authorized service center for repair. Follow the link to locate the nearest service center in your area. Hope this was helpful!
Service Center Locator
Oct 19, 2014 | Hoover F5505 SteamVac Spot Vacuum
Water tank leaks water out
Hello! Storing the solution in the water tank can cause the tank to leak. The solution tank is replaceable. Follow the link below to place an order for a replacement solution tank. Hope this helps!
Search Results
Jul 29, 2014 | Hoover SteamVac F5914-900 SpinScrub...
How much soap and water to mix for steam vac
Hi! To fill the solution and clean water tank, turn tank upside down and unscrew cap. Pour Hoover cleaning solution into tank to detergent fill line. Then fill tank completely with hot tap water. Hope this helps!
Jul 10, 2014 | Hoover F5505 SteamVac Spot Vacuum
Hoover max extract 77 water tank leaking
Remove the little black plastic plug on the bottom of tank (has a metal spring around it), that is where it is leaking. Wrap Teflon (pipe tape) around it and the spring. Replace black plug. Not a permanent fix, but can help if you are on a bind. It worked for me.
Sep 09, 2012 | Hoover F5505 SteamVac Spot Vacuum
Need instructions for filling the Hoover Steam Vac Spot with cleaning solutions
Hi There,
Here's a link to the owners manual for your Hoover F5505 Steam Cleaner that will explain step by step how you can add water & cleaning solutions and carpet shampoo. I hope that this was helpful to you. If it did help you, please be so kind and follow the Fixya model and rate the repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair.
Hoover F5505 SteamVac Spot Vacuum Product Manual:
http://www.hoover.com/pdfs/manuals/F5505.pdf
Thank you, this is really appreciated.
Chris J.
GoVacuum.com
Apr 06, 2010 | Hoover F5505 SteamVac Spot Vacuum
My hoover steamvac spot doesn't spray
the pump has to prime first ,put water in the solution tank an yurn on and keep the trigger pulled till it sprays.if that don't work take it back
Apr 28, 2009 | Hoover F5505 SteamVac Spot Vacuum
My Hoover will not turn on
there was probably a leak in the hose/piping near the pump in the vacuum that shorted out the motor. you will need a new motor for the vacuum. you will also need a new pump assembly. i strongly recommend that you also replace all the internal tubing and places where the pipes join.
Aug 24, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac
My Hoover Steamvac won't puo=ll out the water when I try to cleean the carpet. What do I need to do?
K758@aol.com
Dec 30, 2007 | Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
Vacuums Logo
35 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
