Question about Car Audio & Video
I have a Directed d2400, it turns on and sounds great but when I shut off my car the amps esp light stays on and the top blue leds also stay on. For some reason when I connected my ground wire it sparked a little. Any ideas or suggestions.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 43 Answers
So it is receiving power but not turning off? Sounds like the sense cable is not connected correctly. Amps have a sense cable that determine whether or not the head unit is powered on. They use this sense to power on or power off. If the sense cable is connected correctly and is getting the correct voltage, then the relay may be broken.
Posted on May 14, 2014
Directed d2400 turning onnot going on protected mode but sound on the output.needs resetting?
Just turn it on normally then after you verified that the green power light is on. And the protect light is on as well just one by one remove the fuses and then wait one minute not doing anything and just re install the fuses one by one and when the blue directed light reactivates (THE BLUE LIGHT ON TOP OF THE AMP COVER) you are good to go. Sometimes just removeing the amp trigger wire and reinstalling it will do the same thing. hope this helps. i do this on mine every now and again. Just wish i new what caused it to do it in the first place, this is just my solution to get it working again.
Apr 02, 2015 | Directed 2400d Car Audio Amplifier
TV won't stay on for more than 10 minutes. Won't turn on at all s
Sounds like a power supply issue. Is it out of warranty? If it is, open it up and check the power supply bd. for swollen capacitors....
Apr 07, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Directed d2400 red and green lights on constant and no output...whats the solution
ok ive had an orion amp do this before. oiron is made by directed audio now so its the same style amp. after i checked the ground, power, subs to make sure they were good and not shorted together, i came to the conclusion the amp was bad. its in protect mode right now so check everything with a multimeter and make sure everythings good. if all is ok the amp may be bad. good luck.
Dec 23, 2009 | Directed 2400d Car Audio Amplifier
I have a Directed D2400 amp and my red ESP is on
ESP ties the amp into your vehicle's alarm system. If the amplifier is working normally you can ignore the light. Note that this is NOT the protection LED for the amplifier.
Nov 04, 2009 | Directed 2400d Car Audio Amplifier
My directed d1200 amp blew a fuse i replaced it and the power light is green. However im not getting any sound out of the sub and the esp indicator light is on. what does it all mean.
Hello, first the ESP is for communicating with Directed security systems. If your fuse blew then your amp may have a security feature that disables the amp. The new Directed amps have these features. You need to read your manual or see if you can download one. You should be able to take care of it that way. If you do get it unlocked cause of a security feature and it still does not work, then you are having some internal component problems. I do amp repairs for a living. I own a car audio installation and amp repair shop. I'm the cheapest amp repair you will find anywhere. So if it turns out to be more than you can handle I can repair it for you if interested.
Aug 13, 2009 | Directed D1200 Car Audio Amplifier
When my car is not on the three blue lights on top of the amp are still on, but the power light on the side of the amp is not. Is it normal for the three lights on top to stay on all the time?
No it is not normal.. Normaly when lights stay on the problem is a constantly hot remote wire, but in your case you say the main power light is off.. Soo one can only assume the the problem is in the LED board it's self. This can happen when an amplifier is over heated, or has a poor soldering job. Now if you can hear white noise comming from your speakers with those lights on, then you have a simialr, but more serious issue. If it is just the lights, and not a powered up amplifier I would just let it go.. LED's draw very little power, and can't hurt anything. If the AMP is actualy staying on, I would get it repaired..
Jul 25, 2009 | Audiofonics ADF-241 Car Audio Amplifier
Mxa422 protection
Outputs are fried. Try disconnecting your speakers and see if it still goes into protection mode. If it does then you A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
May 24, 2009 | Lanzar MXA422 Car Audio Amplifier
Protection light stays on
not unhook the amp completely let it sit for 15 minutes it should reset it self and rehook the amp starting with ground rca and remote than the power last it should be back to normal
Apr 20, 2009 | Directed 2400d Car Audio Amplifier
Car Audio & Video Logo
117 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
