Question about Vacuums
Why does the hepa filter pops out of my shark vacuum when I turn it on?
reddevil6
  • 1673 Answers
SOURCE: Kenmore progressive Direct Drive Vacuum w/Hepa
Check the hose and dirt inlet for a blockage. Also the brush roll, check it to see if you can turn it or not by hand. If not, then something may have jammed it.
Posted on Jun 01, 2008
debbily
  • 101 Answers
SOURCE: WindTunnel HEPA Filter won't spin
I just fixed my HEPA filter not rotating!!
It involves taking apart the vacuum HEPA area. All screws are the same size. There are a LOT of 'em. Really straightforward putting it back together too.
ok, once you take the HEPA canister area off the vacuum, careful with the wires! Unplug them from the controller board. You open up the HEPA chamber by removing more screws until you see where the motor that turns the filter is mounted on the side. Remove motor from the green chamber. Note where the washer goes. Once the motor is off, you'll see that the center hub that drives the HEPA filter is rounded out. What I did was jam little bits of aluminum from a pop can into the space between the circle and the square to force the walls back to square. I started by folding a little piece of aluminum over and over so it was about three layers thick. Jammed that in. That wasn't quite enough thickness so I shoved another piece with it. If you can find something that is about 4 times the thickness of a pop can aluminum, that'd probably work too. Slight wedge shape on the tip would help. Any sort of tiny shim.
To test your work, just put a couple of holder screws into the HEPA cannister housing, plug in the cover/switch, plug in the HEPA moter. Turn it on for a few seconds to make sure the filter turns. Then you can add more thickness to the hub or put things back together.
Posted on Oct 12, 2008
  • 294 Answers
SOURCE: Filter in Hoover Wind Tunnel Vacuum
Definitely not. Do not use water or any liquids to clean it. Te normal use life is 2-3 years keeping it maintained. You can clean it dry with the dust brush from your vac attachments. place in a plastic bag and tap it some folks even us an air compressor to blow out the impacted dirt. you will only want to use the Hoover brand, other generic brands dont fit as well.
Posted on Jan 17, 2009
RockyNR1
  • 324 Answers
SOURCE: water leaking from out of the heppa filter
Reasons for that to happen:
a) You have tilted the vac while vacuuming
b) Used the Rainbow without separator (basket like thing on the bottom of the motor)
c) Overfilled the rainbow tank with water (may have happened when shampooing with AquaMate)
Clean and install back the separator, remove HEPA, Set the Rainbow on empty water pan (with HEPA removed) turn it on for a while so everything will dry. Install new HEPA.
You will have to get a new HEPA filter (you can find them HERE)
Good Luck,
Rocky
Posted on Mar 21, 2009
  • 83 Answers
SOURCE: need a filter for rowenta infinium vacuum cleaner
Although it sounds to me like you have a clog in your hose (remove hose and try slipping a heavy butter knife through it, end to end) here is a link to Rowenta manual..lists part numbers for replacement parts.
http://www.rowenta.com/NR/rdonlyres/9A747036-B60E-4F70-96BF-3370EDADAB54/0/Canistervacummcleaners_InfiniumGB.pdf
www.rowenta.com
Posted on Sep 13, 2009
My shark vacuum is having problem 1st the hepa filter kept popping off I made that stop and now the brush won't turn what do I do
Usually a filter popping out means it needs cleaned or replaced. If the brush won't turn it may be the belt, or depending on your model it could be the brush roll or brushroll motor, switch, wiring etc. check these items.
Jan 12, 2017 | Shark Vacuums
Shark rotator will not power on
Hello, this is Ava with Think Crucial.
Your Shark vacuum is equipped with a motor protective thermostat. If for some reason your vacuum overheats, the thermostat will automatically turn the unit off. Should this occur, you would need to restart the motor thermostat. Turn off your unit and unplug the vacuum from the power. Clean the filters and dust cup filters. Check for blockages in hose, accessories and inlet openings. Then allow the unit to cool for a minimum of 45 minutes before plugging it back and turning it on.
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=shark
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Sep 15, 2016 | Shark Rotator Lift-Away Professional HEPA...
I need to replace the filters for my vacuum but I cannot find them for model NV502. Help!
Which filter are you looking for? Is it the foam filter in the bottom of the unit or the HEPA exhaust filter?. Ive found both on Amazon. Amazon com 1 Shark NV500 HEPA Filter Fits Shark Rotator Pro Lift Away...
Mar 23, 2016 | Shark Rotator Professional Lift-Away...
Why cant i keep my hepa filter and cover on my new navigator?? help?
Are you sure that you are correctly connecting the filter, and flipping the tabs to "lock" it into the "closed" position.
Jun 13, 2014 | Shark Navigator Bagless Upright Vacuum
Sep 02, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hepa filter does not rotate
Mar 16, 2008 | Hoover U6630-900 WindTunnel Bagless...
HEPA Filter
It maybe that the filter is in need of replacement. They need to be changed once a year.
Sep 13, 2007 | Hoover U8311900 WindTunnel 2 Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
