Question about IBM ThinkPad T23 2647 Notebook
Need help getting pass the blue screen
I have an IBM thinkpad 2647It's saying that I have to run a CHKDSK/F to check the hard drivefor corruption. My question is how I check this if I can't get pass thisblue screen?Thank youEileen
  • stark4 Jun 23, 2009
    Yes
  • efs_perpends
    efs_perpends May 11, 2010
    ARe you using xp?
    President:
  • 1,996 Answers
Here, here, here and here are some excellent resources that will help you to troubleshoot the stop error codes (blue screens). If you reply with the exact code # you are getting, we can give you more detailed help, but you should be able to run chkdsk from the recovery console (if you have it installed, it would appear as a boot option (breifly) when you boot your system, or by pressing F8 as it boots up. For more info about recovery console see here and here. You can also run chkdsk from an installation cd if you boot the system from the install or recovery disc instead of the hard drive. See instructions to run chkdsk here and here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 23, 2009
  • efs_perpends
    efs_perpends Jun 23, 2009
    Instructions to run the recovery console from a disc here and here.
    More detailed instructions for chkdsk here, and another more technical resource for chkdsk here.
My ibm thinkpad t23 will not go pass blue windowxp screen need help
There are many possible reasons for a blue screen at windows xp.the most likely ones are:damaged windows instalation - in which case you will need to reinstall windows.damaged physical drive - in which case you would need to get a new hard drivethe OS cannot access memory - could be RAM memory or HDD.
I'm guessing you would just need to re-install the windows. You are most likely to lose all data.
Feb 18, 2012 | IBM ThinkPad T23 Notebook
Hi I have a r40 when I go to turn it on it goes to a screen that asks me to start windows normally safe mode and so on I have tryed them all but then it goes to a blue screen and then it just restarts and...
what is the error code on the bluescreen?
have you tried a chkdsk?
if your able to boot to recovery mode.
type chkdsk /r
to repair your hard drive.
there may be corrupted files.
otherwise please let me know what the error is on your BSOD.
Mar 05, 2011 | IBM Computers & Internet
System is saying that I need the original disk their is a problems with windows. I cannot get pass this error message on screen.
It sounds like your operating system has been corrupted either from software errors or a failing hard drive. In some cases you can boot into Safe Mode by pressing F8 during boot. Then you can run a disk error utility to hopefully fix the error. If you do have to reload Windows from scratch, I would recommend installing a new hard disk as they tend to fail after 2 or 3 years from normal use.
Feb 03, 2011 | IBM ThinkPad T40 2373 Notebook
Blue screen says error loading,dont know how to recover with safe mode or how to activate safe mode.it is a think pad t20
Hi,well these should work for you,to get to safe mode,power up the system as the IBM thinkpad logo is about to be displayed press the F8 key just before the Windows loading screen comes up so as to get to safe mode.if it does not work try reloading the operating system using operating system disc.
Dec 20, 2010 | IBM ThinkPad T20 2647 Notebook
My computer act like it is coming on then when it gets almost to the end of loading up it starts making noises and says on the windows xp load up page. Then if i do f8 and i choose the option of...
Replace the hard drive. That is the problem. The windows xp is corrupted due the hard drive error. It cannot continue to load on windows. Replace your hard drive.
Oct 15, 2010 | IBM ThinkPad 600X Notebook
ThinkPad Blue Screen of Death
Sometimes the blue screen can be caused by bad memory, but if it is doing it right when you try to sign in every time, it is probably a software corruption in windows. I have solved this problem by doing a repair install of windows xp, I am not sure if is an option on other os, if you google it you will find directions, you boot off the windows install disk and this option saves your programs and data.
Oct 27, 2009 | IBM ThinkPad T22 2647 Notebook
T 43 says "operating system not found"
Sounds like you have a bad hard drive. Boot up with a Windows CD and select repair at the setup menu. It should dump you to a command line. Type "chkdsk /f" without the quotes and it will check the hard drive for errors. When it's done, reboot normally and it should get you into windows. If it doesn't, replace the hard drive and install windows on the new HDD.
Oct 26, 2009 | IBM ThinkPad T43 Notebook
IBM Thinkpad A20m model 2628
You can download the software known as Active boot disk. With this you can create a bootable cd to run a chkdsk with the f and r command to fix and recover errors on disk. you can also explore your comp and copy files to an external disk. If after the system boots normally after chkdsk you might have a problem with your HDD get it replaced before it crashes again
Jan 20, 2009 | IBM (08K3261) for ThinkPad A20P, A20M,...
IBM Thinkpad 770
Try to format the System using NTFS and if it still says 'corrupted', the Hard Drive is faulty and you will have to get a new one
Hope This Helps
Nov 21, 2008 | IBM ThinkPad T20 2647 Notebook
IBM thinkpad T22 problem
This solution is for s-k-i-t: you will have to get a copy of the win xp install disk to fix this problem (you can borrow one as long as you have a COA on your laptop) but first get into the BIOS by pressing F1 right after you turn it on - you'll see the prompt in lower left corner. Then go to startup>boot>hard drive>Enter. This will show you the type of hard drive. If it is a IBM or Hitachi less than 60 gig chances are it is failing and this is why the hives (where XP stores its memory states) are corrupt. You can download the "Ultimate boot disk" and make a CD that will let you run hard drive test tools. If the hard drive is bad I would try to get the eBay seller to make good - depends on how long you've had it.
Feb 12, 2008 | IBM ThinkPad T22 2647 Notebook
IBM ThinkPad T23 2647 Notebook Logo
107 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
