Question about Husqvarna Sewing Machines
In the middle of my embroidering on my Viking Diamond, a oil spot will suddenly appear on the design while it is sewing, can't seem to see where it comes from?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • Husqvarna Expert
  • 300 Answers
It is coming from the mechanism that drives the needle bar, if it is dark or black, you need to have it looked at by an authorized Viking repair shop asap or you will wear out the cradle, the crank, the needle bar, or all 3. Those can be costly.
Posted on May 14, 2014
  • 106 Answers
SOURCE: Viking 1+--Thread breaks during embroidery
If the thread will not run through the tension mech on 0 then it is probably stuck on a tight setting. It can be a bit complicated but the tension mech can be stripped/cleaned/free'd up. Another possible cause is the path of the thread from the spool to the needle any deviation from the correct path increases the tension at the needle. If you do not know the history of the machine I would suggest a thorough clean and service.
Posted on Mar 26, 2008
  • 192 Answers
SOURCE: downloading
The Designer 1 needs the design in an shv format in order to read it. The floppy disk for an older machine may be created using several different programs but the Husqvarna Viking module is known as Disk Manager. It is included with many of the HV software packages. With a newer USB Designer 1, the program is Disk Manager USB.
Posted on Jun 12, 2008
  • 192 Answers
SOURCE: Misalignment when embroidering with husqvarna designer 1
Sorry that I did not see this sooner.
It sounds like you should have your embroidery unit serviced. Sometimes they will accumulate lint on the slide rods and it inhibits the movement of the mechanism as if you were to bump into it while it is trying to move.
Quite often, this will happen repeatedly in the same point in the design and make people think that there may be something wrong with the design. But, usually it is just that the embroidery unit can't move freely.
Posted on Sep 30, 2008
  • 192 Answers
SOURCE: Viking Designer 1 won't embroider
I have seen some of the older style machines that are very susceptible to static charge. Usually this doesn't happen with newer ones. If you get static shocks on door knobs in your house, do not touch the screen of your machine with your finger. Use a stylus instead. You may also try touching the metal presser bar just above the foot and ankle when sitting down at the machine prior to using the screen. This should not be happening with a new machine. Check with your dealer.
Posted on Dec 04, 2008
SOURCE: my start/stop switch will not begin sewing
Is the problem with embroidery only? If with both sewing and embroidery function and there is no error code (just 00) on the display, my wife experienced the same problem. There was an internal sensor that was bad. The sewing machine shop repaired with a new Singer part. Part was about $20, labor was $180.
Posted on Dec 25, 2008
How to set the bobbin case in Viking Diamond machine
Hello Ann Thomas
Refer to the Designer Diamond manual section 10:2, page 124. You can download the manual for free here: https://www.manualslib.com/manual/614325/Viking-Designer-Diamond.html?page=124#manual
And here is an excellent youtube video: https://www.youtube.com/watch?v=kQhTTpbzrlg
Please let me know how it goes for you.
Happy Stitching
Sewingirl/
Mar 07, 2017 | Sewing Machines
How set bobbin case in Viking Diamond?
Hello Ann Thomas
And here is an excellent youtube video:https://www.youtube.com/watch?v=kQhTTpbzrlgPlease let me know how it goes for you.
Happy Stitching
Sewingirl/
I have a Viking designer ruby machine. I am trying to embroider a name. I have the right hoop and the design fits the hoop and I keep getting an error message.
Sometimes machines will not work because even though the hoop appears large enough, there is not enough leeway for the presser foot to maneuver inside the hoop. This is a common issue with embroidery machines. The probably answer is to either shrink the design or use a larger hoop.
Nov 13, 2016 | Sewing Machines
I have a Husqvarna Viking Diamond Deluxe and I am getting the following Pop Up Error Message. "Machine needs to rest. Wait a moment and touch OK icon when it is enabled. I have done this a numnber of...
This is usually a bad transformer. If the machine is less than 5 yrs. old it is covered under the mfg. warranty. You need to take it to an authorized dealer.
sorry!
Feb 23, 2015 | Husqvarna Sewing Machines
How can I get my bobbin thead to come through the throatplate easily when it will not engage with top thread to form stitches?
I find that the first time I start sewing the bobbin thread often doesn't engage. Therefore I just feed the bobbin thread through the hole of the thread plate when I start. After that it seems to work on its own.
Jul 31, 2014 | Husqvarna Viking 1
Viking designer SE sewing and embroider machine -- Thread that has come out of the take-up lever
If this problem persists there is an upgrade on the take up lever that has a plastic clip that holds the thread in better. Check with your dealer.
Dec 31, 2013 | Husqvarna Viking 1
Trying to embroider with the Husqvarna Viking Designer I and the thread either bunches up on bottom or pulls bobbin thread up through design giving a white design What can be the problem
your tension sounds like it is off. i had that problem on my husqvarna diamond and had to take it in to be reset. my tensions were off by 1/4 inch. hope this helps. also did you take out your bobin and bobin tray and clean it good. make sure there is no lint in there.
Oct 31, 2009 | Husqvarna Viking 1
Mc 5700 problem
Check for loose threads or fluff in upper tension unit and bobbin case tension gauged to 14g resistence. Otherwise, service time I'm afraid. Have it serviced by an authorized Husqvarna Viking Service Technician. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Feb 07, 2008 | Husqvarna Rose
Sewing Machines Logo
42 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
