Question about Sharp AR-5320 Black and White Copier
AR5132 copier E7 with subcode 13 what to do
How to cancel the sub code 13
    New Friend:
  • 71 Answers
Your exposure lamp reflector may have gotten bent this was a common problem to occur after PMs. Otherwise there is an issue with the lamp. Power cycle should clear it after you resolve the problem.
Posted on Jun 06, 2014
  • 990 Answers
SOURCE: error l4 02 in sharp ar5132
Dear sir;the error code you ask about for sharp copier, it means drum motor problem, why don't give them a try to reset before go to replace it, the procedure is
1, press "clear", "pause", "0", "pause"key
2, press 14 then press start.
Have anymore question, please let me know,
HAVE A HAPPY HOLIDAY !!!
Posted on Dec 17, 2008
  • 87 Answers
SOURCE: Error Code E7-03
THAT IS LASER PROBLEM.JUST CHECK LASER UNIT .IT IS SENSETIVE UNIT.CALL A ENGINEER TO SOLVE THIS .ITS BETTER.BY MIAN AKHLAQ
Posted on Dec 18, 2008
SOURCE: AR-5132 Error code E7 13
netoiyer les miroire de scanner et la bare blanve
Posted on Dec 19, 2008
  • 37 Answers
SOURCE: e7 sub 11
The problem is on the scanning unit try these steps:
STEP1: Press continuously CLEAR then INTERRUPT then ZERO then INTERRUPT
STEP2: The panel display will turn off it means that you are inside the simulation if not repeat again step1.
STEP3.Then type 14 then press the print button
Posted on Mar 01, 2009
  • 3 Answers
SOURCE: Code: E7-10 on Sharp AR-M237
Your lsu or laser scanning unit is deffective that's why E7-10 appears. it should be replaced
Posted on Mar 12, 2009
My sharp copier AR-5316, is showing error message E7. How do I clear it and solve the problem. Please I need urgent assistance.
For proper understanding of the error meainig it is necessary to obtain a Subcode of the error by pressing START at the moment of displaying error. E7-02 and E7-16 means Laser unit problems, E7-01 problem with memory, E7-10,11,12 Scanner problems
Jul 29, 2016 | Sharp Ar 5316
What is the error e7
the error e7 may have a variety of "sub-codes" attached to it, each depicting a different problem. hold the start button down to confirm the subcode. the following site offers the technical explanation of the subcodes: http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=sharp&model=ar5320
that is what you asked for but i think the answer will be too technical when you look it up. but you might then google for a repair of that particular code and subcode and see what appears. for that matter, after you determine the subcode, i see no reason why to not contact the manufacturer's support and report the printer information and error code and see if they have a remedy.
here is a site for downloading a manual for such printers. it might simply be a user manual. http://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0cceqfjaa&url=http%3a%2f%2fwww.sharpmea.com%2fcps%2frde%2fxbcr%2fdocuments%2fdocuments%2fom%2f34_ppc%2far5316-5320_om_gb.pdf&ei=csravj7gmuxxmaxsk4hwda&usg=afqjcnedcbf1dnyg_j2h2rxi0ll5sxjrag&bvm=bv.83829542,d.dgy
here is a fellow with a similar problem, an e7 error. but you can see that he was trying to clean the laser and probably disconnected something. http://www.copytechnet.com/forums/sharp/41980-sharp-ar5320-error-code-e7.html?s=84de82058651b6d355c5f09853183f36
good luck.
Jan 21, 2015 | Sharp AR-5320 Black and White Copier
Sharp ar5516 error e7
with such error displayed press the print button, the machine shows another sub code, if it is 11 or 12 means a trouble with the scanner section.
to fix take out the glass ,clean the white strip left, the lamp reflector and mirrors, open the lens cover (5) screws, clean the lens and CCD.
if the subcode is 16 a trouble with laser
Nov 18, 2011 | Sharp Office Equipment & Supplies
I REPAIR THE MACHINES IN AFRICA SO I NI THE ERROR RESET CODES
Perform the following procedure to enter the simulation mode.
"#" key Interrupt key "C" key Interrupt key
Main code Start key Sub code Start key
Usual "reset" codes:
14 - Trouble cancel (except for U2)
16 - U2 trouble cancel
20 - 01 Maintenance counter clear
24 -01 Jam total counter clear
02 Trouble memory clear
04 SPF counter clear
06 Paper feed counter clear
07 Drum counter clear
08 Copy counter clear
09 Printer counter clear
13 Scanner counter clear
14 SPF jam total counter clear
42 01 Developing counter clear
There are codes and subcodes.
example if yiu want to clear the maintenance counter , you have to enter simulation mode and then enter 20 / Copy key /01 /copy key.
I hope it helps you.
regards,
Adi
Nov 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
How to remove erro code E7
Code E7 has got sub-codes. Go and press copy button to see the sub-code and then report it. Generally, this concerns the laser unit and i would advice you to clean the optical platen glass from interior and screw back well. If a code occurs, then report it for more help.
Mar 09, 2010 | Sharp AR-5316 Advanced Digital Imager...
Need to reset the drum counter on the AL 1740 sharp while changing to a used drum
Entering in the simulation mode:press Clear - Interrupt - 0 - Interrupt -Main code - Start -Subcode - Start.
When the clear all key is pressed the simulation mode is cancelled.When the interrupt key is pressed,the proces is interrupted and the screen returns to the subcode entering display.After cancelling the simulation mode be sure to turn OFF/ON the power and check the operation.
Main code 20 subcode 1 =Maintenance counter clear.
Main code 21 subcode 1 =Maintenance cycle settimg
subcode 2 =Mini maintenance cycle setting.
Maincode 22 subcode 1 = Maintenance counter display
subcode 2=Maintenance preset value display
subcode 3=Jam memory display
subcode4=Total jam counter display
subcode 5=Total counter display
subcode 6=Developing counter display
subcode 7=Developing preset counter value display
subcode 9=Paper feed counter display
subcode 12=Drum counter display
Maincode 24 subcode 1 =Jam counter clear
subcode 2=Trouble memory clear
subcode 7=Drum counter clear
subcode 8=Copy counter clear
Maincode 26 subcode 22=Language setting
Maincode 42 subcode 1=Developing counter clear
Maincode 43 subcode 1=Fusing temperature setting
Maincode 46 subcode 1=Copy density level adjustment
subcode 19 AE mode picture quality change
Nov 20, 2009 | Sharp AL-1641CS Laser Digital Copier
Copier turns on but will not copy
There should be a sub code for the E7. Depending on the sub code is what the error exactly is.
Jan 02, 2009 | Sharp Office Equipment & Supplies
E7-15 Error on Sharp AL-1452
THIS CODE IS FOR EXPOSURE LAMP OR INVERTER PROBLEM.CHECK IT.BY MIAN JEE
Nov 17, 2008 | Office Equipment & Supplies
CCD calibration error. Make sure the optics are clean in the machine in the scanner and free of dust.
Nov 03, 2008 | Sharp AR-5316 Advanced Digital Imager...
E7 problem
E7 codes deal with the optical scanner unit and or the laser unit. It could also be the lamp in the scanner unit. The E7 is the main code. There is a sub code associated with it. To view the sub code hold down the start button. Below is a list of specific codes and their meanings:
E7-02: LSU trouble
E7-10: Shading trouble (Black Correction)
E7-11: Shading trouble (White Correction)
E7-12: Shading Trouble
E7-16: Abnormal laser output
If it is a laser (LSU) issue then the LSU may need replacing.
If it is a shading error the first step is to remove the platen glass carefully (with the power off because the inverter board). There is a thin white strip on the bottom side of the platen next to the slit glass. Clean this white strip with a soft cloth and a small amout of isopropyl alcohol.
Dust on the optics can also cause shading reference errors so gently blow off the mirrors with canned air.
Perform the following key procedure to reset error:
"#" key, Interrupt key, "C" key, Interrupt key
"1" key, "4"key
Start key, "CA" key.
See if unit cycles and comes back up. If not turn off and then back on the main power.
If error reappears on site technical service may be required.
Jan 06, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5320 Black and White Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
