Panasonic sa ptx7
When turning on it says please wait but think its stuck like that
5 Suggested Answers
  • 4 Answers
SOURCE: disc tray 1 is blinking with 2 ovals around it, tray not in right Panasonic SA-HT680
I had a jammed disc that was causing this same error message. To remove the jammed disc, remove the top by removing the screws and then you can remove the stuck/jammed discs. For the Panasonic SC-PT750 there are 7 screws, three small silver ones on the back, then 4 black ones, two on each side, all philips head. Once you have that off, gently pry it off starting from the back, the cover is actually hinged into the front plastic piece of the player.
Posted on Dec 31, 2007
SOURCE: Panasonic SA-HT700 Home Theatre - Tray won't open
i have the same issues. Just took a screw driver to the four sides and opened it up. Took 5 mintues. Pulled them out.
Posted on Jul 10, 2008
  • 94 Answers
SOURCE: iI have panasonic home theater SC-PTX7, it
Go to the website and enter the model # for Help.http://www2.panasonic.com/consumer-electronics/support/ Good Luck
Posted on Aug 30, 2009
SOURCE: My Panasonic SA-PTX7 doesn't open cd tray. help
I really like my SC-PTX7. But when that happens to mine I reset the unit. unplug, wait 15 seconds, plug back in, fixed!
hope that helps.
Posted on Nov 12, 2010
Please wait
HD drive should be suspected. seek tech support. Do no do anything by yourself at its circuit board. Seek tech support. The work is a very skilled one.
Jun 04, 2012 | Panasonic SC-PTX7 Home Theater System With...
I have a Sharp Aquos with a optical output, i conected it to the tv optical input of the panasonic sc ptx7 but it doesnt have audio via optical,on the contrary via rca works perfectly.
hi,
check the following on ur tv
1. Press MENU to display the MENU screen,
and then press c/d to select "Digital
Setup".
2. Press a/b to select "Audio Setup", and then
press ENTER.
3. Press a/b to select "PCM" or "Dolby
Digital", and then press ENTER.
4. Press MENU to exit.
PCM The optical output terminal output studio signal in PCM form. If your digital audio system does not support Dolby Digital, select "PCM".
Dolby Digital
The optical output terminal outputs audio signal in Dolby Digital form. it reproduces sound from surround program of digital.
also check the input assignment of ur dvd palyer's tv input. if it is selected as analog then change it to digital.
ok
Dec 20, 2010 | Panasonic SC-PTX7 Home Theater System With...
hope that helps.
Nov 11, 2010 | Panasonic SC-PTX7 Home Theater System With...
II have panasonic home theater SC-PTX7, it
Aug 30, 2009 | Panasonic SC-PTX7 Home Theater System With...
Anyone have service manual for Panasonic SA-PM18?
Yes, you have to destroy your Panasonic SA-PM 18 with a srewdriver and than meet the CD changer with a hammer. If this doesn't help you must take this changer into a box - wait a few years and than throw it in the waste. ::))
Mar 29, 2009 | Panasonic SC-PM16 Shelf System
Service manual for Panasonic SA-PM16
When I turn the machine off, it says, "Goodbye." Then five seconds later it turns itself back on again, including the EQ button. Is it doomed, or can I find a cure out there???
Mar 22, 2009 | Panasonic SC-PM16 Shelf System
Dec 30, 2007 | Audio Players & Recorders
Init please wait
I've just spent the last 3 nights trying to fix that same issue with my sa-ht670 player. I ended up pulling out the dvd tray assembly, and making sure there wasn't anything broken inside or obstructing other pieces. Come to find out, my 1 year old had pulled on one of the trays and it pulled the tray off it's tracks. After that, it would just go to "init please wait" forever. I pulled the side track cover off and aligned the tracks manually. Everything had to be absolutely perfect or else you'd get nothing. After the fact, I realized that there were two holes in the bottom of the player that you can take a spare small gear (which is attached to the plastic cover on top of the dvd tray assembly) and stick it in there and manually adjust the tray positions to make sure everything is aligned properly. After messing with it three days, it ended up being quite simple to fix. Everything works like a charm now. If you need details, feel free to email me.
seeyouatthetop06@gmail.com
Sep 01, 2007 | Panasonic SC-HT670 System
Disc tray 1 is blinking with 2 ovals around it, tray not in right Panasonic SA-HT680
Nov 19, 2006 | Panasonic SC-HT680 System
 Grubhead
Grubhead
