Unable to printer on this printer have reinstalled drivers the drum and error message are blinking. Checked the device manager and it says the the device is working properly have installed new cartridge and drum. Dr. Knaus
ATX-250GU (L)
Posted on Jun 24, 2009
Brough a new Canon printer. Unable to install all drivers correctly, the error message show mp drive missing, but even reinstall it, it still show same error message.
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port
you might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps
May 08, 2012 | Canon Computers & Internet
I pressed and hold it the dell 1710 to cancel or reset it so that i can solve it is all the same blinking on error display the change of drum been done days ago and as for as issue yet unsolved.wishing...
is the blinking coming from your computer when the printer is connected and turned on
you
hope this helps you
Oct 21, 2011 | Dell 1710n Laser Printer
Webcam not working in dell inspiration n5010. lexmark x 422 error code 10 is displaying in devicemanager.
HI
A Code 10 error is generated when Device Manager can't start the hardware device, a situation usually caused by outdated or corrupted driver A device may also receive a Code 10error if a driver generates an error that Device Manager doesn't understand. In other words, a Code 10 error can sometimes be a very generic message indicating some kind of unspecified driver or hardware problem. Uninstalling and then reinstalling the drivers for the device is a likely solution to a Code 10 error. If reinstalling driver is not working than try to rollback the driver or restore the system on previous date..
regards
sandy fixya
May 30, 2011 | Lexmark International Lexmark X422
Blinking Light with no cartridge problems My HP Deskjet D1460 has its light blinking with no status messages that suggests an error. However, I am unable to print as the light keeps blinking. Could...
Hi
this problem has many reasons :
- no paper or error in paper feed sensor.
- jammed paper in printer thats prevent it continue.
- try to disconnect usb cable and if its stop lighting reinstall the driver
- else you must search about hardware errors
Apr 26, 2011 | HP DeskJet D1460 InkJet Printer
The error message "an error
click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might have to uninstall then reinstall the program and its files
the drivers for the scanner might have been corrupted
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options plus you can troubleshoot
hope this helps
Jan 28, 2011 | Panasonic Computers & Internet
I/O ERROR
A Device I/O Error is an error that occurs as a result of using a peripheral device such as a printer or external hard drive. I/O means an input or output error that is caused by a driver that is outdated or not yet enabled. The device driver is a necessary component for allowing your operating system to control and communicate with the peripheral device. When a Device I/O Error occurs your PC is unable to set up the software that is needed to configure the device driver and operate the peripheral unit.control panel administrive tools ,computer management ,device manager any yellow? ! question marks or red x will tell you that you need to reinstall the driver/sto do this right click on the ? x ! select reinstall driver
hope this helps
Jan 13, 2011 | Computers & Internet
Print unable 32 error message
The message "Print Unable 32" or "Machine Error 32" will appear on the LCD display if paper or labels are stuck inside the printer or drum unit.
Follow the below link to fix Print unable 32 error message on Brother MFC-9840CDW Laser Printer
http://tinyurl.com/print32
All the Best...
Dec 09, 2010 | Brother MFC-9840CDW Laser Printer
Unable to Scan
Remove the TWAIN software and reinstall it. Best if you can use the add/remove software in the control panel. You might want to look in the Device Manager for the USB entry that controls the device and remove that. If you find it open with an error, definitely remove that entry.
You might want to check with Brother to see if they have a updated driver for your 5840.
Thanks for your question at FixYa.com
Jan 01, 2010 | Brother MFC-5840CN All-In-One InkJet...
Error message of "Unable to detect fingerprint device"
Go to control panel from start menu,then click icon "add hardware".
Follow the instructions, click yes when asked about device is connected,then choose something like"human interface device", keep following the procedure until you find the hardware that match with windows.
Hope it works!!!
Dec 10, 2009 | Acer TravelMate 5720-6635 Notebook
I dont have an audio device it cant complete the installation
Remove the device(delete) from your Device Manager, reboot then see if windows reinstalls it.
Mar 08, 2009 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
48 people viewed this question
Alun Cox
David Payne
David Payne
