Question about Uniden Bearcat Pro PC68XL CB Radio
How do you turn down the modulation on a uniden pro510xl?
My amp sqweels when you key up and my dead key is set at 1.5w. the modulation is the only thing that i could think of to try and turn down to get the sqweeling to stop....any ideas its a uniden pro 510xl with a texas star 550 and a wilson 5000.
    Problem Solver:
  • 6 Answers
First things first. Make sure the antenna is properly matched to the radio and car, a bad match will most often cause squeal. Make sure you have a bonded ground direct to the battery of the vehicle and all must share the same ground. The amp and radio must be exactly the same ground potential. If you meter both the radio chassis and amp chassis back to the battery negative you should see the same reading of zero or .002 or less. Then meter the radio chassis to the amp chassis and make sure they have a zero ohms reading. This is the most common problem in radio and amp setups. Most often people get ground loops and this causes all sorts of issues like you describe. Rarely is modulation the issue unless you have an incorrectly installed MOD kit in the radio. Now if all checks out with a meter then meter the antenna shield to the outer part of the amphenol and make sure it is also at or darn close to zero ohms. The meter the center lead (at amphenol) of the antenna to the outer of the amphenol and make sure it reads 52 ohms or less. NOTE: if it is a magnet mount Wilson they tend to rust really bad between the magnet and the coil under the antenna and create a high resistance short. If you can't determine the antenna is good borrow another and test it. The Newer Wilsons since about the last ten years are made in China and fail often. I have the old one made in the USA and they still work if cared for. Hope this gets you on the right track, but never have I seen an issue with modulation causing squeal by itself unless someone went crazy turning it up way too high.
Posted on May 23, 2014
    Problem Solver:
  • 4 Answers
Not getting enough voltage or amps will make them squeal,also. Run both the amp & radio directly to the battery using some heavy wire. I use #8,but I would like to have some #6. Also,those stock little mikes on the 510 are a lot to be desired. Get someone to let you try a GENUINE Turner Roadking 56 & see if it still squeals. Lots of good tweaks on CB Tricks site. Good luck.
Posted on May 19, 2014
Benimur
  • 6966 Answers
SOURCE: Uniden PRO510XL low output and "motorboating"
Based on your post/description, I am assuming that:
1. The standard Uniden microphone that came with the radio has not been replaced with a power microphone;
2. The amplitude modulation method (transformer) is not modified;
3. The Power Output has not been modified;
4. The radio is not being used in a Rife/bare system.
Your posted problem may be caused by:
1. Mic. You can verify if your mic is causing the motorboating by grounding pin#3 to transmit without any input audio/mic connected; with pin#3 grounded and no audio in, determine if you still have the motorboating problem. If no then chances are its the mic, if yes, then its internal to the radio;
2. Audio amplified IC and/or its associated components. Check the audio amp is TDA1905, capacitors C50 to C58;
3. AMC (amplitude modulation control). VR2, Q6 likewise check the Limiter Q5.
In some versions, a microphone with an Electret Condenser Microphone Element is used. This type of mic uses 2.8~3.3 volts DC from the radio. These versions may use the audio line (pin#2 in a wire pin mic plug) or a separate +3V mic power (in a 5 or 6 pin mic plug). Motorboating then may be further caused by the dropping resistor that has gone up in value or by the capacitor after the resistor that has lost its capacitance along the +3V line. Indication low or no +3 in pin#2. In some instances, the +3 goes down when talking into the mic.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Jan 19, 2008
Mechanic688
  • 204 Answers
SOURCE: modification of frequency output of uniden pro 510xl
deweyp, hi, if you are wanting to turn the power up some on the radio, do this; tune L4, L5, L6, L9 for
maximum RF forward output. There are 2 versions of the radio, and both are listed as 510xl. If you are wanting to expand the freq's or add channels, then no, there is no mod for that radio. If your going to tune the radio for more power, make sure you have a power meter to watch the output. It is preferable to tune into a dummy load so your not broadcasting over the air. You tune the radio for peak output, using a steady awwww sound in to the mic. Just be careful as that radio has a fairly small driver and final transistor. Don't want to let the factory smoke out of it,,,
Here is what the little variable adjustments are for and what they control;
VR1 Squelch
VR2 TX Meter
VR3 RX Meter
VR4 RX IF Gain
Hope this helps you out, let us know,, Mechanic
Posted on Feb 19, 2008
tparsenault
  • 170 Answers
SOURCE: Uniden Pro 510xl can send but not receive
If you look on the solder side of board you shoud see a straight line of 5-7 solder joints, look on the other side the audio vhjp is a bmack thin retangular ic chip. Not to worry you wont hurt anything by doing this. Its an old cb tech trick to test audio chips.GOOD LUCK.
Oh one other thing does the radio have same same problem in either vehicle? A insulating washer on the antenna bracket can cause this also,
Happy New Year , Tom
Posted on Dec 31, 2008
  • 39 Answers
SOURCE: Uniden PRO510XL Outup
The Uniden 510 xl is quite possibly the easiest and one of the loudest radios I have ever pumped up .Now here's the problem it's been atleast ten years since I've had the cover off one so I can't tell you which diode # it is you clip for the modulation I know that as your looking at it (speaker side up ) it's about halfway on the right hand side buy the audio transformer.Then you change the resistor buy the final transistor , you go higher until you get where you want it , going higher is going to bring your output wattage down ; I usually tried to get it down around two watts . By doing just these two things and maybe a little adjusting you should be able to deadkey 2 watts and swing to 18 watts with just that cheap stock mic. if you change the final transistor I've seen them swing to 35watts.They are fun cheap radios that when you do this no one beieves that that's all your talking on . Good Luck !
Posted on Feb 04, 2009
  • 773 Answers
SOURCE: 1987 uniden pro 510 xl
Wow, from what you are saying, you should not be messing with the insides of the radio. Finals, are not resistors, that are TRANSISTORS, and they do not have resistance values at all.
The final is the little black transistor attached to the heat sink at the back of the radio. You can't just change the final. there are other parts that need to be changed if you want to do a high power mod. Don't even mess with it. you don't need too.
Next, D14 is not the uniden model. thats what you mess with in a cobra. Don't cut d14 in that radio or you will prolly blow it up. The diode you want to cut out is D203. DON'T CUT IT!!, Just un solder one leg of the diode. You won't be over modulated. That will bring you modulation up and your peak watts. it will swing to maybe 15-20 watts peak. That alone with make the radio louder.
You really don't need to raise the dead key. With a lower dead key you have higher swing. Its all about the audio. 2 watts for dead key is fine. Thats what I run.
You cannot do any other peaking with out a meter. If you have a meter you can spread the 2 coils behind the large transformer a tiny bit until you have peak wattage. L201 and L202. but from reading what you said, you should probably leave them alone, you will gain only a watt or 2, and its not worth it if you mess it up.
To be honest with you, all you really need to do is unsolder one leg of D203. Make sure you pull the leg out, and make sure it is not touching anything so it will not short.
Now if you do this, and it splatters, you can always solder it back in, and then turn RT201 all the way to the right, I think. If you turn it all the way to the right, and there is not modulation, you just turn it all the way to the left.
Please don't mess with anything else or you will screw the radio up.
Posted on Oct 03, 2009
Yesterday My 1997 xj6 would not turn over, all dash lights came on but when the key was turned to start nothing happened, no click from the solenoid, the other thing I noticed was the interior lights did...
Just a shot in the dark. If your key has the magnetic chip in it, the chip may be week. Try another key if you have one.
We have a key without a chip in it we hide under the car. It will turn the ignition but will not crank(dealer told us that). One more thing the dealer who made the key told us not to try cranking the car with it because the car could think someone is stealing it and shut down till a dealer input codes to allow the car to run again.
Jun 03, 2017 | 1997 Jaguar XJ6
Hi
It sounds like your circuit board may have a bad solder joint. Sometimes during manufacture of the ciruit board, the joint could not be perfectly made. This will limit conduction and create heat which will worsen the effect over time. If you are familiar with opening and working with electronics then I suggest you remove the circuit board and inspect it for cold solder joints. When you find one, you can use a Cigar Torch type lighter to help reflow the solder easily. Out side of that, you mayu want to send it to a Electronics repair shop to do this for you. Let me know more and I will help. Good luck
Jan 19, 2008 | Uniden PRO510XL 40-Channels Base CB Radio
Pro510xl schematic
do a search for it. uniden pro 510XL schematic. I found it.
Oct 23, 2013 | Uniden PRO510XL 40-Channels Base CB Radio
1985 Chevy El Camino 305ci. Turned over good but wouldn't fire. Replaced contrrol module and it started fine for about 2 months, then did the same thing. Replaced dist cap, rotor & coil. Start
Had an 84 silverado 305 that did the same thing. Try giving it a full tune up. Plugs, wires... Mine turned out to be fouled plugs. I didn't find that out till after i tore it down & put a timing set in it. Wasn't getting good enough spark.
Feb 16, 2013 | Cars & Trucks
No power to my radio when ignition switch is in the on / run position
sounds like your body control module. it is located down in the kick panel on the passenger side. the body control module run things inside the car
Feb 10, 2013 | 2001 Cadillac Catera
How to add talkback to a uniden pro510xl
68 to 200 ohm resistor to the postive side of the speaker to board ground
Jan 28, 2013 | Uniden PRO510XL 40-Channels Base CB Radio
Is it possible to convert the cobra 29 wx nw st sound tracker cb to 10 meter amateur band?
No it cannot. If you want that buy a Ranger or a Galaxy.
The 29 can be altered to increase modulation and turned down in power to match it to amp for increased output of power.
Set to dead key a watt or so with a 100 watt amp it would dead key low and swing to 80 to 100 watts pep.(peak envelope power)
Mar 16, 2012 | Cobra Radio Communications
I have a Uniden Pro 510xl, it's about 9 yrs old. I went to use it last week and after turning it on, found that there was no sound, (turned the squelch up) . When I keyed the mic, I saw that I was...
chk mic, lose cable in **** plug test with other mic .. also test with Ext speaker.. do u get any reading on meter / LED display during RX? does PA work? otherwise your sound chip is dead
Dec 30, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
I just have uninden pro510xl (used), but don't know how to set the channel (progamming) so it can match with my handheld radio (i use motorola GP200). Thanks...
hi The uniden pro510xl operates on 11mtrs or 27mhz (cb band) the gp200 is vhf 136-174mhz so you will not be able to communicate through these radios you can only program within the specified frequencies hope this solves your problem
Dec 09, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
Can a 19 ultra power be turned down to 1 watt? If so where?
Yes it can, but it requires the addition of some components. It isn't really a straight forward install. It needs some reworking. In my opinion, not worth the trouble.
Sounds like you want to run a linear amplifier. If you really want to run an amp, get a better radio to do it. There really is no other reason to lower the dead key that low. Also, 1 watt might be too low. May not drive the amp well.
If you just want to make the radio swing, 1 watt is way way too low. You will have barely any carrier and the radio will sound like ****. That radio stock dead keys 2.5 watts. That's perfect for swing. Now you just need to have more modulation. Find DM1 and unsolder 1 leg and pull it out of the board. Now you will have full modulation. You will deadkey 2.5 and swing to about 15 watts.
If you want to run an amp, get a good radio. If you like cobra, get a cobra 29. They are fairly cheap, and sound amazing. As well it is real easy to lower the dead key in that radio.
Nov 12, 2010 | Cobra 19 Ultra II CB Radio
Uniden Bearcat Pro PC68XL CB Radio Logo
89 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
