Question about Honeywell Thermostat Pro 3000 Th3110d1008
Wiring diagram for TH3110d1008 thermostat - Honeywell Thermostat Pro 3000 Th3110d1008
  • 60 Answers
Https://customer.honeywell.com/resources/Techlit/TechLitDocuments/69-0000s/69-1929EFS.pdf attached is a link to the installation manual. it should have a wiring diagram as well
Posted on Mar 10, 2016
Lost instuction manual. Where can I get one
You should be able to download one on line. Go to the Honeywell home products website.
May 18, 2016 | Honeywell TH3110D1008 Pro 3000 1H/1C...
All is standard, heater is gas, AC is electric, old thermostat was old and burned. I have TH3110D1008 and 4 wires.
the colors on standard t-stat are rh/rc gets red wire. g goes to fan green. y goes to outside unit cool. and in your case w labeled black goes to heat normally this wire is white.
Jul 25, 2015 | Heating & Cooling
Wiring diagram for smeg thermostat
Good Afternoon Friend,
I understand that you are looking for the wiring diagram, to replace the thermostat, in your Smeg appliance. The wiring diagrams are typically not accessible to the public. I suggest contacting the manufacturer, as they might have access to that wiring diagram for your appliance. Hope this is helpful.
-Best Regards-
WP
May 13, 2014 | Frigidaire FRS3R5EMB Side by Side...
Heat is not turning on when it should
What kind of heat, and where are you turning on/off from ?
Dec 08, 2013 | Honeywell Thermostat Pro 3000 Th3110d1008
How do i reset my honeywell thermostat
Remove thermostat from wall, leaving base plate on wall.
Model number appears on back of device.
Google search thermostat model in following format: Honeywell xxxx32 thermostat .pdf
Adding .pdf to search parameter will yield product manual.
Also while thermostat is off the wall, change batteries located in compartment on back of thermostat. These batteries must be changed periodically, for example each 3-4 years.
Jul 17, 2013 | Honeywell TH3110D1008 Pro3000 Thermostat
First time starting a/c this season, display is lit but no air is blowing. Fan outside is on. Batteries changed, still no air. System is only @ 2 years old. Stat model - TH3110D1008. Thanks.
Set the thermostat FAN setting to FAN ON to verify the fan working.
If it works in the FAN ON position the fan motor is OK and you have a bad fan relay.
If it does not work you should check the fan motor capacitor.
At 2 years old the unit is still under warranty for parts.
Apr 26, 2011 | Honeywell Heating & Cooling
Honeywell digital thermostat stopped working
Sounds to me like you have a low voltage short. If the stat had no display until you installed the battery means there was no voltage for the stat to work. Putting the battery in proves the stat works, no motors turning on probably leads to a blown low voltage fuse generally a blade fuse on circuit board in indoor unit. Good Luck
Jun 11, 2009 | Honeywell Programmable Thermostat Heater
The thermostat turns the heating unit off and the fan continues
check your furnace filter to make sure the furnace is not over heating. what brand of furnace do you have and how old is it?Have you changed filter to a different kind last time you changed it?
Jan 16, 2009 | Honeywell Programmable Thermostat Heater
Wiring Diagram
here is a basic wiring diagram for all air cond systems your thermostat consist of treminal r w y and c run a four conductor wire fromm thermostat to ai handler the air handler should allso have eather have red blue white wires or a teminal block marked r w c r stands for red w for white c for comon allso blue run color for color from the thermostat to ai handler with exeption of yellow yellow runs straigth to condenserand retuns in white wire to air handler wich gets conected to comon hope this help[s you
Sep 02, 2007 | Ruud UBHC Air Conditioner
Honeywell Thermostat Pro 3000 Th3110d1008 Logo
104 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
