Question about Akai Televison & Video
What can i do to fix Akai adrm 9000. its not showing picture, please me to fix it
Its playing dvd also hear sound but no picture on tv. i've change the terminal chord but still not showing pictures. please help me to fix it
SOURCE: clear sound with jumping picture
either the disc ur inserting is dirty or the laser needs cleaning try cleaning ur laser first then the disc if the problem prosist take the dvd player back
Posted on Feb 08, 2008
Mrsmiley
  • 54 Answers
SOURCE: Only voice no picuter while playing DVD
make sure the video cable is plugged in correctly, or if it is damaged.
Posted on Feb 12, 2008
SOURCE: Dvd player-No pic yes sound
Try using the I/P button on the remote. Toggle between S-video, RCA and composite video outputs.
Posted on Jan 08, 2009
konzzz
  • 255 Answers
SOURCE: How do I turn off Progressive scan?
try PBC on.
Posted on May 28, 2009
  • 814 Answers
SOURCE: my portable dvd player has sound but no picture on the screen. pl
If you still have use of the on screen menu functions, you can try using the restore to factory setting option in the preferences section of the set-up menu. Press the setup button on the remote control and use the up and down arrows to find and highlight the preferences section, press ok to enter the sub-menu.In the sub-menu use the up and down arrows to find and highlight the default option. Press ok. This will reset the dvd player to the factory settings. If you do not have the use of the on screen menu, you can use the a/v outputs to a external monitor or television to perform the abouve procedure to try to restore the dvd player to normal operation. If all this fails you can call Phillips customer support at this telephone number. 1-888-744-5477 They will be able to help you, either solve your problem or get the dvd player serviced.I hope this information helps you with your problem.
Posted on May 31, 2009
DVD/VCR picture (and sound) are not on tv screen
Try setting the TV to AV1 & see if the dvd picture appears.There should be a button on the remote to change TV/video. Hope this helps.
Dec 24, 2008 | Sony SLV-D300P DVD Player/VCR
I cannot see the video when i plug the DVD Player to my TV set. The model is AKAI ADVC-7013
start with the sound , do you have some speakers or amp that can take rca connnectors if so plug in to audio out and if you hear sound then the video is presumed ok too , likely some setting or cable issue then.
if no sound the the proc amp is shot.
Apr 26, 2008 | Akai DVDP5851 DVD Player
No picture or sound
what do you have connected? you can try withe basics. if you can try a rg-6 cable into the f connector. then try a dvd on video 1 and change the input to input 1 and see. if nothing else try a hard reboot
thats unpluging the tv for about 2 min. then reconnect.
Apr 08, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Progressive scan
Approach 1: Try unplugging the DVD player from the wall for an hour, then plug it back in. It may or may not reset to the factory default settings, which might put it back to "interlaced" output.
Approach 2: When a DVD player is switched to progressive scan, it uses outputs different from the coax cable "TV out" and the COMPOSITE outputs (often yellow, white and red RCA jacks. If you have the proper cables, you can connect them to both the DVD player and the TV, then cycle through the AKAI TV's "source" settings to switch the TV to the new cable input location.
For example, if the DVD player has "component" outputs (marked Y, Pb, and Pr) hook up RCA plug cables between those jacks and the AKAI TV's Y, Pb, and Pr jacks. Connect the Y to Y, the Pb to Pb, and the Pr to Pr, of course. The LCT3285TA has two sets of these jacks. Either will do, but note if you use YPbPr1 or YPbPr2. Once this is done, push the source button on the side of the TV (or on the TV's original remote) until it shows YPbPr1 or (...2 if that's what you connected). If the DVD player is on, you should now see the DVD menu or the picture from the DVD. Now you can use the DVD remote to switch back from progressive to interlaced video. The picture may go blank at this step.
Now push the TV's source button again until you see "3" or whatever channel you had been using in the upper left of the TV screen. You should see the DVD output picture (menu) again. Back to normal.
If your DVD player doesn't have YPbPr connections, it may have a HDMI or DVI jack.
The AKAI TV also has a HDMI input, you *could* get and HDMI cable (or DVI to HDMI cable if the DVD player doesn't have HDMI), hook it up, then cycle through the TV's source inputs until you see the HDMI in the upper left... in the manner I've just described.
Final Note: The progressive scan output of your DVD will actually give you a much better picture on your AKAI TV than its interlaced output. To take advantage of that, you'll have to hook up YPbPr or HDMI cables between player and TV and switch sources when you want to watch DVDs instead of TV programs. You may need additional cables to send the stereo audio output from the player to the TV for the progressive source hookup.
Jan 05, 2008 | Akai LCT3285TA 32 in. LCD Television
Akai problem
i got akai 29" tv before 1 1/2 yrs back.3days back it was burnt with a huge sound. the set was burnt with a high smoke.since 1 wk i am waiting for your service agent.when they will come?this problem was not present in sony,LG,or other tv.akai is this much weak set.there was no lightnening only rain was present at that time.i hope you will change the set with free of cost.
K.P.Varghese,Plot.330/54,St-3E(East),Pragati Nagar,Risali,Bhilai,Durg(C>G)Pin-490006
Phone:0788 2271393,Mob:9424124176.
Dec 29, 2007 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Very low sound when using the internal dvd player
This is a known problem - there is no fix - if the dvd mech is replaced, the volume will still be the same. Sorry - - inside info
Sep 18, 2007 | Akai LCT2721AD 27 in. LCD Television
Televison & Video Logo
19 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
