Question about CyberLink PowerDirector 9 Ultra64
How to fix front end graph streaming error?
Everytime i start producing my videos the program stop. how can i solve this, front end graph streaming error ?
How to solve and graph the equation 4x+y+0
The easiest way to solve and graph and equation is to put the equation into the slope intercept form y = mx + b, where m is the slope and b in the y-intercept.
To do this, we subtract 4x from both sides and get y = -4x + 0.
From this we know m = -4 (slope) and the y-intercept is 0.
I always start with the y-intercept and put a point there. Thus, we have a point at (0,0). Using this as a starting point, we now use the slope of -4 to get future points. Since it is negative, we go one unit to the left and up four units. So we have the point (-1,4). Using a ruler, we connect these points and continue on both sides to produce the line.
There is also a great free online program/app called Desmos that you can use to check your work. Type in the equation of the line and it will graph it for you.
Good luck,
Paul
Oct 27, 2016 | Office Equipment & Supplies
How do I graph 4x+y=0
Good luck,
Paul
When I try to enter a simple equation and graph it, I get error 07 message instead of graph.
Error 07 Syntax
Means you made a typing error while entering the equation. Using the minus sign instead of the negation sign (change sign) (-), can produce a syntax error. Maybe you need to explicitly type the multiplication sign
y= (-) 1.5*x +3
Try entering it as 3 - 1.5*x
c3b67db6-adc8-4b0c-8e71-dc94a9bdbeb0.png eb28a330-c2e9-4879-857f-1e41bfe8515a.png
Jun 11, 2014 | Texas Instruments TI-86 Calculator
Everytime I attempt to graph something. The thing says Error: Invalid DIM. How do I fix this?
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Jul 13, 2011 | Texas Instruments TI-84 Plus Silver...
Everytime i try to graph i get an error saying invalid dim on my TI-84 plus calculator
May 19, 2010 | Texas Instruments TI-84 Plus Calculator
Amcap its saying error 80070450:cannot run preview graph
No solution yet, I restarted my computer but, the same problem/error appeared. I will be greatful for your help.
Nov 22, 2008 | MSI Starcam 370i Webcam
How this can be do in asp.net???
You will need a third party control to produce graphs in ASP.net. Is that what you want?
Take a look at http://www.dotnetcharting.com/ it is free I think and may do what you need.
Nov 04, 2008 | Keystone Active Server Pages (ASP)/Visual...
Built in web cam problem
i have cam acer dvc-v6 but when i connect to pc, there is no pic out, is there any fix to solve my problem
Driver not registered with NetMeeting (possible black border)
please tell me what is that means ?
regards
iqbal
redline gokart
Apr 13, 2008 | Microsoft Windows XP Professional With...
Getting the Error 13 Dimension
This just happened to me too after i tried to plot some statistics. Press 2nd, +(STAT), then F3 for plot and see that you have all the STAT PLOTS turned off.
Sep 10, 2007 | Texas Instruments TI-86 Calculator
CyberLink PowerDirector 9 Ultra64 Logo
83 people viewed this question
Top CyberLink Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
Are you a CyberLink Computer and Internet Expert? Answer questions, earn points and help others
