Which of the following occurs from one trophic level to another? a. energy increases b. entropy decreases c. biomass decreases d. all of the above
2 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: Sound Level Changes Constantly
Make sure digital sound control is not set to optimal
Make sure incredible surround is off
Press optimal sound mix until it says "OSM Off"
Double-check the speaker connections
Posted on Apr 08, 2008
Whats the best renewable energy source?
The beat renewable energy sources are those sources of energy which can be renewed easily and which is eco-friendly in nature.
Some of the best sources of renewable energy are:
1. Solar energy: The most efficient renewable energy source. The sun rays are absorbed by the solar cells on the solar panel and later it is used as electricity.
2. Wind energy: Used in turbines to make them run and generate electricity.
3. Water energy: Water has been used in hydroelectric plants to produce electricity.
4. Nuclear energy: Nuclear fission is the main source of energy today. The energy generated by this fission is used to produce electricity.
Jan 04, 2017 | Green Living
Tip
Tips on changing orifice size on AC or heatpump
Tips on changing orifice size on air conditioners and heat pumps.
A smaller orifice will create these changes
1 - Takes more refrigerant charge to get the same superheat
2 - Increases capacity
3 - Decreases Energy Efficiency Ratio
4 - Increases Head pressure
5 - Increases sub cooling
6 - Reduces suction pressure
7 - Increases Watts and Amps
A Larger orifice will create these changes
1 - Takes less refrigerant charge to get the same superheat
2 - Decreases Capacity
3 - Increases Energy Efficiency Ratio
4 - Decreases head pressure
5 - Decrease Sub cooling
6 - Increases suction pressure
7 - Reduces Watts and Amps
on Jan 26, 2010 | Heating & Cooling
How do you adjust the door spring on a miele dishwasher?
there are two screws behind the kick plate - one for the right side on fro the left - the screw have a little - and + above them to show which way to turn to increase or decrease the tension
Aug 10, 2014 | Miele G6100SCI 598 mm Clean Steel Built-In...
Hello ! I have a Sony DAV-DZ640K Home Theater System, the problem is that I can increase and decrease sound levels for individual speakers, like i am able to increase and decrease surround (back) speakers...
Sound distribution varies according to speaker configuration. You have to select speaker size and placement and a number of other characteristics to get results. A review of the setup instructions in accordance with the physical size of the speakers you are using and nominal impedance values may help.
Feb 26, 2014 | Sony Audio Players & Recorders
What are the benefits of undergoing therapeutic massage therapy?
Benefits of massage:
  • Relieves muscle tension by enhancing blood flow, which causes muscles to relax
  • Decreases inflammation by activating genes that naturally reduce swelling
  • Reduces pain intensity by diminishing bodily substances that create and prolong pain
  • Improves recovery by stimulating mitochondria, the "energy packs" driving cellular function and repair
Nov 06, 2013 | Furniture
What are the benefits of undergoing massage therapy?
There are numerous benefits of undergoing massage therapy which includes increased blood circulation, decreased pain, stress and strain etc. It helps in eliminating the accumulated waste materials in our body. Overall health and fitness of our body gets increased. After undergoing treatment in massage therapy Richmond Hill I had this feeling of positive energy flowing through out my body.
Oct 21, 2013 | Audio Players & Recorders
Waste to energy systems (on a small scale)? Please recommend?
Yes, visit Billington Bio Energy. They are located in Liverpool and have been in business for quite some time and has gone beyond assisting other renewable energy producers to producing environment-friendly heating products such as a) Biomass Fuels to include Bulk Blown Wood Pellets, Bagged Wood Pellets, Animal Bedding, Tonne Bag Wood Pellets, Briquettes and Wood Chip Fuel Supply b) biomass boilers from 199 Kw to 999 Kw c) Silos & Stores, Fuel Level Measurement and Couplings & Parts. Talk to the staff of the company to help you with your requirements I am sure they will be able to assist you.
Feb 12, 2013 | GE Energy Star WCVH6260F Front Load Washer
To increases volume
first of all u can increase volume during call by pressing right button (middle one). but i think ur phone is set to max and u dont hear much - in this case probably some "metal dust" sticks on your speakers membrane - open case clean speaker gently or replace with new one...
Feb 07, 2011 | Nokia 1600 Cellular Phone
How is latitude related to air temperature
The temperature of the troposphere generally decreases as altitude increases. The rate at which the temperature decreases, dT / dz, is called the lapse rate. The reason for this decrease is as follows. When a parcel of air rises, it expands, because the pressure is lower at higher altitudes. As the air parcel expands, it pushes on the air around it, doing work; but generally it does not gain heat in exchange from its environment, because its thermal conductivity is low (such a process is called adiabatic). Since the parcel does work and gains no heat, it loses energy, and so its temperature decreases. (The reverse, of course, will be true for a sinking parcel of air.) [1]
Since the heat exchanged dQ is related to the entropy change dS by dQ=T dS, the equation governing the temperature as a function of height for a thoroughly mixed atmosphere is
9df09585dbe18cef06221a59290536de.png where S is the entropy. The rate at which temperature decreases with height under such conditions is called the adiabatic lapse rate.
For dry air, which is approximately an ideal gas, we can proceed further. The adiabatic equation for an ideal gas is [3]
beb483b44843aad0a6cddff7b1385c8a.png where γ is the heat capacity ratio (γ=7/5, for air). Combining with the equation for the pressure, one arrives at the dry adiabatic lapse rate,[4]
c4507116c9a4244af81e3aa8b865d863.png If the air contains water vapor, then cooling of the air can cause the water to condense, and the behavior is no longer that of an ideal gas. If the air is at the saturated vapor pressure, then the rate at which temperature drops with height is called the saturated adiabatic lapse rate. More generally, the actual rate at which the temperature drops with altitude is called the environmental lapse rate. In the troposphere, the average environmental lapse rate is a drop of about 6.5 °C for every 1 km (1000 meters) increase in height. [1]
The environmental lapse rate (the actual rate at which temperature drops with height, dT / dz) is not usually equal to the adiabatic lapse rate (or correspondingly, e52ae677de914e5cfddd35c399e2c57b.png). If the upper air is warmer than predicted by the adiabatic lapse rate (dS / dz > 0), then when a parcel of air rises and expands, it will arrive at the new height at a lower temperature than its surroundings. In this case, the air parcel is denser than its surroundings, so it sinks back to its original height, and the air is stable against being lifted. If, on the contrary, the upper air is cooler than predicted by the adiabatic lapse rate, then when the air parcel rises to its new height it will have a higher temperature and a lower density than its surroundings, and will continue to accelerate upward.[1][2]
Temperatures decrease at middle latitudes from an average of 15°C at sea level to about -55°C at the beginning of the tropopause. At the poles, the troposphere is thinner and the temperature only decreases to -45°C, while at the equator the temperature at the top of the troposphere can reach -75°C
Feb 26, 2010 | RTO Help! My Science Project Is Due...
97 people viewed this question
k24674
