I own the denon avr-3802 and no longer have a remote control unit. I recently bought a denon tu-460 fm tuner component...can i connect this to the vcr2/v-aux input so i can listen to the radio?
  • 27 Answers
1) - Try buying a universal remote, Maybe something like the Logitech Harmony. This can be an inexpensive way to control everything from one remote.
2) - I don't know the exact models but I'd wager "yes". A pair of RCA cables will most likely do the job.
Posted on May 15, 2014
suffolkpo
  • 6 Answers
SOURCE: Denon AVR 1803
Hello, I think that you've got a problem in the relay circutry or a logic problem. tell ya what I ve got the service manual and schematic for the reciever. the engineers at denon where ahead of there time when this company started. they designed the equipment around what they wanted the specs to be for signal to noise and discrete audio channels. each of the sound channels from the component and composite inputs is given its own bus and amplifier channels. these paths are also common to the reciever/tuner outputs. one question though you mentioned that the composite/component video paths are not switching from the input to the output youve designated, and that the monitor checks good. do you have another video source,either digital or analog that you can input throgh another channel to see if it is infact a switching problem. try that and let me know. I can give you help with the switching circutry form the schematic if need be. believe me I know It took me about a week to track down the service schematic for this unit. Denon doesn't like giving out info unless you are an authorized repair center.
Posted on Jan 03, 2008
tech48
  • 624 Answers
SOURCE: Denon AVR-3802
I have repaired many of these Denon receivers over the last few years.
Since the headphones work, that means if you dis-connect the speakers it will turn on and not go into protect (when power cuts off a few seconds after turning the unit on).
The most likely problem is a bad speaker. to find out which speaker is causing the problem, do this.
Start out with just one speaker connected and then turn on the unit. If it turns on and plays music, you know that speaker is good.
Now turn the unit off again and add another speaker and keep the first speaker connected. Once again, if the unit plays, that speaker is also good.
Keep doing this same procedure one speaker at a time. As soon as you connect a speaker and then try to turn on the unit and it goes into protect, the speaker you just connected is bad.
To confirm that this speaker is the bad speaker, dis-connect all speakers and only plug the suspected bad speaker into a speaker jack that worked with one of the other speakers.
If the unit still goes into protect you know then that you have found the bad speaker.
If the unit still goes into protect, that speaker is bad and you will need to take it in for repair or replace it.
make sure you use 8 ohm speakers. if i remember correctly these Denons can use 6 ohm speakers, but those are harder to find and most home speakers are 8 ohms.
If the unit does not go into protect and that suspected bad speaker plays in one of the other speaker jacks, what you really have is a bad channel in the amplifier, the channel that the suspected bad speaker was previously connected to.
If you find out you have a bad channel, you will need to take it in to an repair center. Preferably an authorized Denon service center. There are not very many of those around. I work at the only authorized Denon service center in the entire state of Michigan.
If I can be of more assistance, don't hesitate to ask. And a good rating is always appreciated. :)
Posted on Jun 22, 2008
  • 27 Answers
SOURCE: No system setup menu on screen
its related to the control AVI switch inside on the right side with the contact and 7 Ri sisters.
about 200.00 something to repair.
I can help with some money do you have the reciever still???
Posted on Nov 11, 2008
SOURCE: reset channels??
http://www.eserviceinfo.com/download.php?fileid=26004
http://www.eserviceinfo.com/download.php?fileid=26005
Here are the links for the manual. I've lost my remote as well. I can't get my unit to recognize the digital audio input (optical). Very frusturating.
Posted on Nov 20, 2008
  • 119 Answers
SOURCE: Remote control for Denon AVR 1706
YES YOU CAN THERE MAYBE A FEW DIFFERENCE BUT YOU WILL BE FINE TO USE IT
Posted on Mar 02, 2009
Denon AVR-3300 component channel switch burnout?
hi there, i don't have a solution unfortuantely, but i may have the same problem. I have a denon 2802 av receiver, i bought it second hand and I can't seem to get the component video in / out working. Are you supposed to just plug it in and it works? Because I can't find any buttons or settings to select component in / out as my input / output sources?
Nov 12, 2009 | Denon AVR-3300 Receiver
AM,NEED REMOTE CONTROLL DENON AVR-3802 HOW I,BUY?
I had the same problem. Unfortunately Denon no longer mfgs. the remote for this receiver,
their solution is to offer a remote for a "similar" model. Problem is it doesn't work on all the
functions for the AVR-3802. My solution was to purchase an aftermarket universal remote
(Logitec Harmony 550 in my case}. The cost was a little less (approx. $90) vs. the price
quoted by Denon (somewhere around $120), and it works on all the functions.
I don't know if a budget priced remote (All-in-one, etc.) would be able to do th same.
There are several different programmable remotes on the market that should do the trick,
Logitec just happens to be one of them.
Good Luck
Mar 24, 2009 | Denon AVR-3802 Receiver
Denon AVR-3802 Problem
Check that your speaker cables are not touching each other at the amp end and also at the speakers as this will cause the amp to shut down.
hope this helps.
CABLE GUY.
Jul 12, 2008 | Denon AVR-3802 Receiver
Set up
You don't need to fake it with a VCR - on the back left side near the bottom there is a Monitor section with an RCA connection and an S-Video connection. Connect one of these to an input connection on your tv and switch your tv to show that input. Select the AMP setting of your remote and press Setup.
Mar 01, 2008 | Denon AVR-3802 Receiver
Denon 3802 Amp issue
check the output res. from the DVD, your Denon may not pass high res 720p, 1080i or 1080p and also check the component assignment in the Denons setup
Oct 08, 2007 | Denon AVR-3802 Receiver
49 people viewed this question
 Grubhead
Grubhead
