Question about Miele M625EG Convection Microwave Oven
What do i do?m625 eg miele oven smoke from top and turntable ceased working
Impossible to say what the problem is but if the turntable has stopped you could check the turntable motor. This is easily accessed from the bottom of the unit but you have to actually break the sheet metal tabs that retain it in place and replace using the screws only.
Posted on May 14, 2014
2 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: Miele M625 lightbulb replacement
If the owner's manual doesn't cover it and there's no obvious cover on the side or rear, you'll have to remove the outer wrapper.
See these files:
http://wwww.microwavedisplay.com/safety.txt
http://wwww.microwavedisplay.com/disassembly.txt
Often on a unit whose bulb is not meant to be replaced by the customer, the light is located on the right side in the air duct attached to the magnetron or on the top of the oven cavity.
Most bulbs can be matched up at hardware stores, home improvement centers, and places like Wal-Mart or even large grocery stores.
Posted on Dec 12, 2012
See these files:
Dec 11, 2012 | Miele M625EG Convection Microwave Oven
T783sf sparks from turntable coupling
No it is not safe to use, the windings of the motor are shorting against the coupling, solution! the turntable motor must be replaced in order to resolve the situation.
Jun 19, 2012 | Panasonic NN-T783SF 1350 Watts Microwave...
Turntable has ceased to function when oven is on. Is it dangerous to use like this?
Not dangerous, but your food will not be efficiently or evenly heated. To change the motor do the following:-
There is a panel under the microwave, held on by one or more screws. Remove it and you will see the synchronous motor inside. There should be a plug to disconnect the wires. Remove the motor and fit a new one. Ensure that the microwave is disconnected from the wall outlet before attempting any work on it.
Feb 16, 2011 | DeLonghi Microwave Ovens
Grill element stopped working.
I had the same. Dismantle the oven and see at the back side the connection wires for the heat element. Mostly one of the connectors is faulty. I fixed it that way.
Jul 29, 2009 | AEG MCC663 Microwave Oven
Turntable not rotating on my microwave
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again. If that doesn't work, leave it unplugged for about 5 minutes. You can download your owner's manual here: http://www.miele.co.uk/Resources/OperatingInstructions/M%20625%20EG.pdf On the last page it has the contact information for various countries. You can locate servicers or spare parts. The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray. You can see and hear a video of how a turntable motor should sound when you rotate it by hand: http://www.youtube.com/watch?v=rPSWi_z7M58 If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Jun 11, 2009 | Miele M625EG Convection Microwave Oven
Start button intermittent eg press many times (maybe 20) to start
Problem identified as plastic pushbutton on control panel, solution: interchanged with turntable on/off button (nevrer used). Had paid Miele €115 call out (for person who knew nothing about microwaves), Miele operate a closed shop. Local repair service say Miele will not supply parts, Miele designated repair agent will not repair microwaves, Miele will only send "engineer" to customer, no drop off facility. Was forced into buying new microwave oven from Miele as only way of recouping callout charge. Subsequently had a go myself with above positive positive result - now have a spare microwave cooker.
Mar 18, 2009 | Miele M625EG Convection Microwave Oven
Microwave Smokes
the problem is in the magnetron try to replace it.
Jan 27, 2009 | GE JVM1660 Microwave Oven
The microwave facility in this multi function Sanyo shower wave oven EM-D993 has ceased to work. Everything else does.
When you hit Start to cook, do the inside light and turntable come on?
Any unusual noises? Is it louder or quieter than usual?
These answers will help me judge whether it's in the high voltage section (magnetron, transformer, or diode) or the control section (door switch or control board relay or connection).
Nov 24, 2008 | Sanyo Microwave Ovens
Miele M625EG Convection Microwave Oven Logo
114 people viewed this question
Top Miele Microwave Ovens Experts
William Miller
William Miller
k24674
Armin Buehlmann
Level 1 Expert
Are you a Miele Microwave Oven Expert? Answer questions, earn points and help others
