Question about Toshiba DKT3207-SD 1-Line Corded Phone
Caller ID on a toshiba DKT3207-SD
What buttons do you use on the phone to access the call log
5 Suggested Answers
  • 40 Answers
SOURCE: Toshiba DKT2010SD Phone Problem
Here you have the manual for the phone:
http://www.toshiba.com/taistsd/common_dsd/pdf/userguides/StrataCIXCTX_User_Guide_IPT2000_DKT3000.pdf
Posted on Aug 18, 2008
jncayo
  • 31 Answers
SOURCE: Caller ID
You have to have caller from the phone company, your phone system has to support caller ID, system has to be programmed by a technician or your local telecom dealer.
Posted on Oct 11, 2008
  • 45 Answers
SOURCE: How do I set up caller ID on these?
It is very possible. You would have to install a RCIU card into the sytem to recognize the incoming caller ID from your provider. Then you would have to program your system for it to work properly. Do you have a DK or CTX base system.
Posted on Feb 22, 2010
casouzaj
  • 1118 Answers
SOURCE: DKT3020SD Corded Phone: HOW DO I DISPLAY THE CALLER ID ON A TOSHIBA DKT322...
Caller ID in POTS networks is a service which has to be subscribed to. The local exchange (to which the user's line is attached) has to allocate a DTMF sender for each and every incoming call, for it to be picked up by your phone and shown on its screen. Talk to your phone company for further informations.
Just my 2 cents... Carlos
Posted on May 18, 2010
How to get caller id for missed calls for Panasonic kx-t7730
Panasonic KX-TA624/824 automatic Caller ID logging How to set up automatic Caller ID logging
in the KX-TA624 phone system with KX-T7735 phones. (for dash four and five, and KX-TA824)
System Programming:
  1. In System Program number 900, enable Caller ID for the lines you have Caller ID on. (To get into system programming, press Program * # 1234.)
  2. In System Program number 901, select your own area code and any other area codes that don't have to be dialed when making a call. The area code digits are removed from Caller ID log information so you can return a call without dialing unnecessary digits which would mess up the call.
  3. In System Program number 902, if necessary, indicate the number of digits to be removed, and a particular digit (usually 1) that might have to be added, when returning a local phone call. The default programming is to remove the first three digits, and add nothing; which is correct for most locations.
  4. In System Program 903, if necessary, indicate the number of digits to be removed, and up to 4 digits that might have to be added, when returning a long distance phone call. The default programming is to not remove any digits, and add a 1; which is correct for most locations.
  5. In System Program number 909, enable Call Log Assignment for each phone where you want to log Caller ID information. You can use * to indicate you want logging at all phones.
  6. Get out of system programming. (Press Hold or End, then Program.)
Phone Programming:
  1. Program a button for Caller ID Indication on each phone where you want to log Caller ID information. Press Program, then the button you want to use for Caller ID Indication (we recommend the top button in the left column), then 96, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 6 instead of 96.)
  2. At each phone where you want to log all calls, press intercom, then 7382#.
User Tips:
  • The Caller ID Indication button will light up only when the system has logged UN-answered calls.
  • Use the Navigator Key at the lower right corner of the phone to scroll through Caller ID information.
  • You can erase the entire Caller ID log by pressing Intercom, then 70**#
  • You can erase an individual Caller ID record by pressing Transfer while the information is displayed.
  • If your phone does not have a Navigator Key, you can program an available button for Caller ID Selection. Press Program, then the button you want to use for Caller ID Selection, then 97, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 7 instead of 97.)
  • To call a number displayed on the Caller ID log, pick up the handset or press the speakerphone button, and press the Caller ID Indication button.
Jul 01, 2015 | Panasonic KX-T7730 Corded Phone
Retrieve a phone number from earlier today from the caller id
If you're running on a CiX or CTX platform, you're dealer or system administrator needs to enter the amount of CID calls to be buffered on that particular phone. This can only be done via the System Administration Program. You'll also need to program a "Caller-ID Log" key
Sep 09, 2014 | Toshiba DKT3207-SD 1-Line Corded Phone
Need to add a caller id scroll button on phone for toshiba cix 40 phone system
Your problem was posted in the printers and copiers section. Try posting it again in the correct section.
Dec 03, 2013 | Toshiba Strata Cix40 Cix 40 Complete Phone...
Message light blinks all the time> How can I get it to go off?
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Aug 01, 2013 | Toshiba DKT3207-SD 1-Line Corded Phone
How do I connect caller ID
First, I'd need to know what switch you have your phone connected to and if the version supports Caller ID. Also, your telephone service must provide Caller ID to your switch (phone cabinet).
Jun 07, 2012 | Toshiba DKT3020SD Corded Phone
I have caller id on my avaya phone but I don't know how to find the call log. How do I access the call log for caller id?
You need to do Admin programming to tell the system to log the calls (#317 & #318)
Then you need to put a log button on a lighted button (Feature 23)
Jun 25, 2010 | Avaya Eurostyle 18D Corded Phone
May 16, 2010 | Toshiba DKT3020SD Corded Phone
Toshiba DKT3207-SD 1-Line Corded Phone Logo
32 people viewed this question
Top Toshiba Lands Phones Experts
george  peters
george peters
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
