Question about Yamaha 96 Kodiak 400 Generator Stator Flywheel Rotor
1996 yamaha kodiak 400 ATV starter spins but will not engage the engine, what is the problem?
    Genius:
  • 1,114 Answers
The starter Bendix gear must be stuck in the disengage position, and is not engaging the flywheel. Try hitting the starter with a rubber mallet or with a piece of wood and a hammer. You may be able to loosen the gear by spraying some WD40 or the like into the gear. You probably should take the starter off to clean /lube the gear. If all fails, you're looking at a new starter.
Posted on May 14, 2014
  • Jerry Smith
    Jerry Smith May 14, 2014
    How and where can I access this gear?
  • Joel Friedenberg May 14, 2014
    You can access the gear by removing the starter. The ger is at the end of the starter motor. Try to lubricate it to see if it frees it up. It has an in-and -out motion. You can hook the starter up to a battery once it is out and check to see if the gear moves in and out. The starter has a lot of torque, so hold down. Place Pos cable on large screw and Neg cable on the case. Be Careful not to hit the Pos cable on the frame. You can use a set of jumper cables.
    Problem Solver:
  • 12 Answers
I have 2 Kodiak's with no starter problems thus far. My suggestion would be to visit your local Yamaha dealer to see if the starter drive is replaceable, if so replace it or have it replaced you may be too far from help the next time it decides not to function.
BR
Posted on Nov 08, 2014
02 yamaha kodiac 400 4x4. Magneto won't lock onto shaft. Keys lined up magneto in place but when I out case back on it sucks the magneto off the shaft and to the magnet. Is this supposed to happen?
Hi, David for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your problem. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.maultechatv.com/techguides/Service%20Manuals/YAMAHA/Kodiak%20YFM400%2093-95.pdf
OEM parts for Yamaha
Yamaha KODIAK 400 Ultramatic 4x4 Owner Manual
Kodiak 400 4x4 and 2WD 2003 Yamaha ATV Lineup Off Road com
Apr 17, 2016 | Yamaha Motorcycles
How to install choke cable on 400 Kodiak atv ?
Your information is on the ATV Forum
Throttle cable: remove the 3 screws on the right side of the carb, take off the cover, there is small rubber gasket (red) Don't lose it. you'll see the cable attached inside. move the mechanism forward like you're opening the throttle to get enough slack to unhook the cable.
Choke: on the other side of the carb, the choke cable screws in with a plastic nut (10 mm i think) unscrew with your hand, if its tight use pliers or wrench..its easy to unscrew it.
throttle choke cable removal Yamaha Grizzly ATV Forum
Sep 12, 2015 | Yamaha Vehicle Parts & Accessories
Yamaha 400 kodiak
is it belt driven if it is check belt for slippage if not check fluid in the drive axles and gears
Aug 17, 2014 | 1993-1994 Yamaha Yfm400 Kodiak Bear 4x4...
How to fix the yamaha krypton starter not engaging the engine
Hi, Anonymous the starter drive/Bendix/clutch is a mechanical gear driven component that engages the clutch pack ring gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed, it is not serviceable and needs to be replaced. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
ATV Connection
Yamaha YBR 125 starter clutch rebuild engine rebuild video coming soon
Yamaha YZ125N1 Service Manual
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Jun 29, 2014 | 2003 Yamaha YZ 125
I have a 1996 Yamaha Kodiak 400 with no spark
If you have another one try the ignition switch and the kill switch.
Jan 27, 2014 | Yamaha Motorcycles
I have a 2003 yamaha kodiak ATV, reverese indicator light stays
MAKE SURE THAT FORWARD AND REVERSE ARE FULLY ENGAGEING AND DISENGAGING
Jan 18, 2010 | 2003 Yamaha YZ 450 F
Starter spins freely, will not engage
there is a coil that pushes starter out to engage it to flywheel and a motor part that turns it. check to se if the coil part is good or hooked up.
Apr 22, 2009 | 2000 Yamaha WR 400 F
Sequence for starter washers
Here you go,Please rate this fixya
Jan 29, 2009 | 2001 Yamaha FZS 400 Fazer
Yamaha 96 Kodiak 400 Generator Stator Flywheel Rotor Logo
127 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Dusty Ryan
Level 1 Expert
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
