Question about Kenwood Double DIN Navigation DVD Receiver - DNX570HD
DNX570HD won't play ipod sound
Ipod connected via usb cable..no sound
  • 5 Answers
SOURCE: Kenwood KVT-617DVD
ok you have two possible problems one is the remote wire comeing from the brain is hooked up wrong use the second remote wire to the remote hook up for your amp the one you have hooked up is for the power antena if you had one thats why it works when you have the radio on.
ok now the second problem is with your zone cotrole sound like to be on try playing with your audio controls.
or at the very bottom of the screen is about 3or 4 buttons use those to change through the other options while the screen is up .
Posted on Jun 14, 2008
  • 5 Answers
SOURCE: Kenwood KVT-617DVD sound issues
the wireing off the brain is connected wrong, ok look at the wires and now disconnect your remote wire from the amp remote now connect the second blue wire to the remote wire going to the amp, now your sound should be right
  • 5 Answers
SOURCE: dnx7100 ipod problem
The USB source is not for Ipods, from what I understand. The Ipod needs to be connected with the Ipod cable, $50 or so. I think it is a high speed connection.
Posted on Aug 08, 2008
  • 108 Answers
SOURCE: no sound on ddx 514 kenwwod..when hooked up ipod to usb??
This is a faily simple fix. First of all, this USB will not be able to playback audio from an iPod or iPhone without using the correct cable. The cable needed has both USB and an audio plug on it. Here is a link to the Kenwood cable you will need:
http://www.kenwoodusa.com/Car_Entertainment/Accessories/KCA-iP200
If you would like playback of iPod video, you will need this cable:
http://www.kenwoodusa.com/Car_Entertainment/Accessories/KCA-iP301V
A local authorized Kenwood stereo dealer should have these in stock. I hope this information was helpful.
Posted on Sep 19, 2009
fkuk
  • 311 Answers
SOURCE: ipod says disconnected when plugged into my
i sometimes have the same problem it says do no disconnect when it should show the kenwood logo
try restoring your ipod from itunes
Posted on May 15, 2010
IPOD cable doesnt work on my DNX570HD
I have the same problem, did you find a solution?
Jan 10, 2014 | Kenwood DNX570HD
Tip
How do I connect my iPod to a stereo Kenwood
<p>The superior audio quality thanks to the Kenwood stereo system is as good as any on the market. However, many of Kenwood audio receivers contain no iPod connection port. Even the business hubs of high-end entertainment that interface with the computer via USB cannot provide connectivity to an iPod. But that does not mean you cannot high-quality audio through your stereo Kenwood iPod. <br /> <p><br /> <p>1. Put your Kenwood stereo. Connect devices with the stereo turned on may lead to spikes in volume that can damage the speakers and even your ears. Turn up the stereo, so you can use the set of connectors on the back to see. <br /> <p><br /> <p>2. Connect the end of 3.5 mm 3.5 mm to RCA cable for the headset from your iPod. If you do not have a cable 3.5mm to RCA, you can buy one of the sound equipment stores or electronics stores like Radio Shack. <br /> <p><br /> <p>3. Connect the RCA end to your cable 3.5mm to RCA in an available port on the back of your Kenwood stereo. Put your Kenwood stereo, so you can access the buttons on the front. Turn the sound and select the channel of your iPod is connected. <br /> <p><br /> <p>4. Test the connection. Lower the volume on the Kenwood stereo and start a track playing on your iPod that you can recognize. Turn your volume until you play the iPod through the stereo to listen. If you hear no sound, check the "Monitor CD2/TAPE2" is active, and "Mute" is off <br />
on Aug 09, 2011 | Apple iPod touch
Tip
How to convert 220 volts to 110 volts for the iPod Touch
<p> <p>The battery of an iPod Touch prepared for use in the United States is designed to be reloaded from the current supplied by a 110-volt electrical system. Power is transmitted to the battery charger with an iPod battery, which are connected via a USB cable and then connected to a 110 volt outlet. To use the power of a 220 volt outlet with an iPod Touch, set the current 220 volts to 110 volts. A conversion adapter voltage, also known as "Step Down Transformer," it is necessary and can be obtained from an electronics store, a hardware store and even some drug stores. <br /> <p><br /> <p>1. Place the 220-110 voltage converter card (aka, "Step Down Transformer") next to a 220 volt outlet. Plug the adapter into the outlet. <br /> <p><br /> <p>2. Connect the end of a USB cable to the USB connector USB iPod charger iPod. Connect the other end of USB cable into your iPod's own socket on the bottom of the iPod Touch. <br /> <p><br /> <p>3. Plug the iPod into the 110 volt outlet in the battery adapter for the iPod Touch. <br /> <p><br /> <p>4. Unplug the charger from the iPod adapter and the adapter from the outlet when the battery is charged. Unplug the USB cable from the iPod charger and iPod Touch. <br />
My ipod will not turn on
Find out what to do if your iPod won't turn on.
Several things could prevent iPod from turning on. Check each cause in this order to find out what's wrong.
Products Affected
iPod
Resolution
Make sure the Hold switch is off
1. Check to see if the Hold switch is on. It's located on the top or the bottom of iPod. When it's in the on position, you'll see an orange patch.
2. To turn the hold switch off, slide it until you no longer see the orange patch.
3. Press any button to turn on iPod.
iPod hold switch on iPod hold switch on
Make sure the battery is charged
iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
iPod battery empty icon
To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod Power Adapter and plug the power adapter into an electrical outlet. Note: iPod models without a Click Wheel cannot be charged via USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information.
Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost.
Let the iPod battery drain
In rare cases, iPod might get into a state in which it needs to be drained completely before it can be reset. If iPod didn't turn on after you reset it, follow these steps:
1. Disconnect iPod from all power sources and leave it disconnected for about 24 hours.
2. Reconnect iPod to the Apple iPod Power Adapter or computer and reset it.
Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod.
Additional Information
If you have tried the solutions above and iPod still won't turn on, check the following:
* Make sure iPod is the only device in your FireWire or USB chain. Disconnect everything but the mouse, keyboard, and your iPod, then see if it will turn on.
* Make sure you are using the FireWire or USB cable that came with your iPod, and that the cable is in good condition.
* Try connecting iPod to the built-in port of a different computer to see if that works. Note: If using a portable computer, make sure it is plugged in to a power source and that the lid or display is open. If the lid is closed the computer may go into either standby, sleep, or hibernation mode and iPod will not charge properly.
If you still can't turn iPod on after performing these steps, it may need to be repaired. You can arrange for repair at the iPod Service Website.
iPod may not power on, may be stuck on the battery logo, or may have stopped responding while playing music (in which case the Click Wheel doesn't respond).
Products Affected
iPod classic (120GB), iPod nano, iPod classic, iPod classic 160GB (Late 2009), iPod (5th generation), iPod (5th generation Late 2006)
Resolution
If you experience any of the above issues, try the following steps:
1. Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
* If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
* If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer does not sleep, standby, or hibernate during the 20-minute charging period.
4. After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
* If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
6. Try putting the iPod into disk mode.
* While in disk mode, connect the iPod to iTunes and try to restore.
* If the iPod is still not recognized by iTunes, the iPod should be serviced.
See http://www.apple.com/support/ipod/ and click the Service tab for more information about your service options.
Hope it helped...
May 21, 2011 | Sony NWZ-E436F MP3 Player
I have a new ipod classic 160GB which I am trying to connect to a 2010 Ford Focus via the USB connection. When I connect using the same USB lead that I attach to my laptop the radio screen shows track...
Hi Ben3230, I have the same problem with my ipod nanno (2nd gen). If I connect the nanno up to the usb socket in the centre console of my 2010 Ford Focus, the tacks display on the screen but no sound. I purchased a 3.5mm jack and connected that from the ipod to the 3.5mm jack in the centre console (as well as the usb lead) and suddenly music. Hope that solves your problem.
Jan 12, 2011 | Apple iPod nano
Kenwood KVT 514 in dash radio. Ipod classic is connected through the usb cable. Ipod is playing and showing onscreen progress, however, there is no audio coming out of speakers. Have been unable to make...
you need to purchase the ipod cable... your ipod is connected through the usb cable which does not provide sound to the unit but everything else works
Aug 15, 2010 | Kenwood KVT-514 Car DVD Player
Currently i have a sky hd box connected to my tv by a hdmi cable i want to connect my ipod into the sky box so i can play music videos ipod and sky box are close together and i don't want to connect ipod...
This isn't possible, the USB on the front of the Sky HD box is not active. I don't have any information on whether it will be in the future.
Your only option is to connect the iPod via TV or if you have a surround sound amp
May 21, 2010 | LG LH-D6230 System
How to work the ipod on pioneer avic f900
Hi my name is Juan and let me splain to you what is going on you are connecting your ipod using only USB and the ipod is protected is not like any other mp3 players on mp3 players you can output sound trow the USB but not on ipod apple don't want you to connect your ipod to another computer using USB and transfer your music to another ipod so if you want to lessen to your ipod using this stereo you need to buy an special cable that connects in the back of te receiver is designed for ipods go to ebay and type pioneer f900bt and go to accessories you will fine one there for around 35dls I have the same system you got and what I did is I purchase another 4GB mp3 those regular mp3 from china THEY CAN PLAY USING ONLY USB
Mar 25, 2009 | Pioneer AVIC-F900BT Car GPS Receiver
MP3, IPOD, CD doesn't appear when I press "Source"
Easy.
If you read your owner's maunal, page 26, the USB is designed for a flash drive (up to 4GB), not an Ipod.
If you would like to play your iPOD, purchase the IPC008 (Ipod Lead) and you're done!
Feb 24, 2009 | Eclipse CD1200 Car CD/ MP3 Player
Ford Fiesta IPod connection problem
You need the specific cable from Ford, part number 8M5J-19C142-AA, Finis: 1529487 which has a USB and an aux jack. It costs about £19. You need to plug in both aux and USB and then connect the other end to your ipod. You can then scroll through the playlists etc using the dashboard controls. When you have selected your choice, press the OK button and the ipod should play. You can use the steering wheel controls to move forward or back through the tracks and to change the volume. The instructions in the handbook are not very helpful.
Dec 28, 2008 | Car Audio & Video
Kenwood Double DIN Navigation DVD Receiver - DNX570HD Logo
103 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
