What can i do to fix sigmatek PVR-1300A DVD RECORDER. its not showing pictures on tv?
Its playing very well and i can hear the sounds but its not showing pictures on tv. i've change chord but still not showing pictures. please help me fix it.
  • 6 Answers
SOURCE: recording from my vcr to the dvd hardrive
111111111111111111111111111111111111
Posted on Oct 04, 2008
SOURCE: DVDRHD400. No volume on the TV channels
hello ,i fixed this problem on a dvdrhd400 i picked up off ebay with same fault. played dvds perfect but no audio coming in from freeview or scart (this is not a firmware update problem). the problem seems to be the capcitors on the tuner board (long retangle board at back which scart connects to) theres a 100uf 10v-16v capcitor (sorry cant remember if voltage was 10v or 16v as i fixed this a month ago and system as been working perfect and dont want to take it all apart again) its in the middle of the board off to one side with afew other 1uf caps around it. replaced it with a 100uf 25v cap (higher voltage is fine as long as same value) Capcitance meter was reading cap as bad. bingo worked perfect ever since.
Posted on Jan 23, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: Can't hear sound on Windows Mediaplayer from DVD I recorded
I've been pondering this one for a day or so - at least two possibilities:
1) There is a mute/audio-off hotbutton inside Windows Media Player itself - click on it and see if the audio works. Alternatively, you can try playing a music file in Windows Media Player to see if THAT file has sound.
2) You need a better Codec - the free version of the K-Lite Codec has limited audio support. There are no easy answers to this problem. I frequently use my computer for converting VHS's to DVD, so I finally plunked down the $50 to purchase Nero 9 and all of its codecs. Before that, however, I used VLC Media Player (free) - it has DVD/VOB audio support.
As a side note, if you wanted to use your computer to convert the VHS's to DVD, you would need a plain-old VCR, a red/white/yellow cable, a DVD burner, and a product called the Dazzle DVD Recorder from Pinnacle. You can hook the VCR straight to your computer and burn away. To get the best experience however, I would also get a program like Nero, Roxio, etc. to do the actual DVD burning (although the Dazzle's native software is perfectly capable of doing the job).
-Tha Mp3 Doctor
Posted on Feb 15, 2009
SOURCE: Green Picture
The problem sounds like one I had. If so, the cause is as follows.
The Daewoo ouputs synchronisation information on the green channel of the RGB outputs (which are pins in the SCART socket) The Panasonic TV automatically preferentially selects the RGB input in the SCART rather than the composite video signal in the SCART. The video circuits in the Panasonic should ignore the sync on the green channel but instead interpret the sync as green signal information which means the adjustment of the green channel is upset leading to a very green picture.
Possible solutions:
1. From the TV, manually select composite video input, not RGB. This may not be possible - I think the TV automatically goes for the RGB if it is present.
2. Disconnect the wire to pin 16 in the SCART socket. This is the signal from the VCR/DVD to indicate that RGB is available. Disconnecting it means the TV defaults to the composite video. This is what I did.
3. Connect the TV to the VCR/DVD using component or S-VHS leads only.
Posted on Feb 22, 2009
konzzz
  • 255 Answers
SOURCE: How do I turn off Progressive scan?
try PBC on.
Posted on May 28, 2009
How do you record from my tv and what channels will I get?
Has this ever worked?
When you mention channel I assume you mean the channel on your TV set. Normally an S-Video input will be an aux input channel and not a numbered station on your set. How do you select the player chanel/ input when you watch the DVD?
Is the arial connected to the PVR then to the TV or direct to the TV It needs t pass through the PVR.
Jun 24, 2014 | GoVideo R6750 DVD Recorder
Logik tv troubleshooting
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Jul 09, 2017 | Televison & Video
Intermittent loss of picture and sound for 1 or 2 seconds
YOu need to verify that this is actually the TV and not the source. Cable, satellite systems (upstream of you) are the more likely cause, which you cannot fix.
test with a DVD, or PVR recording.
Feb 05, 2011 | LG 47LC7DF 47 in. LCD HDTV
Using TV card on PC video perfect no audio
SOme PVR cards need a small cable from PVR card to the Sound card input to play sound via the sound card.
Jan 16, 2009 | Leadtek WinFast PVR2000 Video Capture
DVD/VCR picture (and sound) are not on tv screen
Try setting the TV to AV1 & see if the dvd picture appears.There should be a button on the remote to change TV/video. Hope this helps.
Dec 24, 2008 | Sony SLV-D300P DVD Player/VCR
Direct TV DVR sound/no picture or pict. no sound
My Direct TV has no sound or picture but does show channel info at the top. Any help is appreciated.
Dec 13, 2008 | Directv (R10) DTV Receiver / 70-Hours...
Can I record from the hard drive of a pvr
YES.
Connect the PVR to the DVD recorder via scart or RCA phono connection.
Select the relevant input on the recorder, press play on the PVR and record on the recorder.
May 02, 2008 | Televison & Video
Noise while playing VHS
It sounds like the tape is cocked slightly. some VHS tapes did make noise. I'd take it to the store and show them the noise.
Nov 04, 2007 | Philips DVDR3320 DVD Recorder/VCR
Can't view picture, but can hear sound
Are you trying to record TV signal onto a DVD, or are you playing back? What make & model is your TV and DVD player/recorder?
Oct 22, 2007 | Yamaha RX-V620 Receiver
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
