Question about Canon EOS 400D / Rebel XTi Digital Camera
Why With a new battery, there seems to be no power on my canon EOS digital rebel xt?
The camera would not down load to my computer so I canceled the process and turned the camera off. I removed the battery and replaced it with a fresh one but the camera will not power up now
  • Tim Renner
    Tim Renner May 15, 2014
    Tried several batteries and the cable is removed. is there an internal fuse?
    Top Expert:
  • Canon Master
  • 6,702 Answers
Did you remove the USB cable? As long as there is an USB cable in the camera, you can't power it up.
Then you still have to check if the battery is still in good order. Batteries do have a limited time of life. And you only can be sure it is charged, when it works in another (same model) camera.
Posted on May 14, 2014
  • 1 more comment
  • Tim Renner
  • Harrie May 15, 2014
    Did you read the suggestion from hogdoctor, down here?
    Still I think you should convince yourself, all contacts are clean and shiny, and like hogdoctor puts, not any pin should be bent or cause a shortage.
  • 7 Answers
SOURCE: Canon EOS/Rebel XT won't power up
Joe, this happened to me, just tonight... I got a new CF card and stuck it in, turned it on and one CF card flash. Completely dead from there. I found one of the CF card pins bent over, shorted out the socket and blew the mainboard fuse. I took the camera apart, found the fuse (labelled K) about under the set button area) I bridged the fuse with a bit of solder, straightened out the pin in the socket, put it all back together and it's working fine. The fuse is under the right side shield cover, it's labelled with a letter K. There is another fuse on the power inlet board (below the shutter button) and it's labelled 'P'...
Posted on Aug 22, 2009
  • 164 Answers
SOURCE: Canon EOS Digital Rebel XT will not connect to computer.
Please discard that the USB port or the USB cable are defective. You can do it if you try to hook your camera in other personal computer using the same USB cable. If it works, then follow the next instructions.
Connect your camera to the PC thru the USB cable and turn it on.
If you are using Windows, go to the Control panel - System - Hardware - Devices - and check if there is any device that was not recognized by Windows. Such devices are marked with a yellow question mark.
If so, get into the device item and with right mouse click, select to update the device driver.
If there was not unrecognized device, then you can unistall your USB port driver and then run a change hardware status to recognize the USB port again, then run the update driver routine.
Regards,
Posted on Aug 25, 2009
SAFFOTO
  • 77 Answers
SOURCE: Canon EOS Digital Rebel XT will not turn on.
It could be a number of things. The first thing you shouild do is remove the back cover and check for loose screws. If you don't find any, the problem may be a damaged battery door switch, a damaged memory card slot door switch, or worse- it may be a defective power board.
Posted on Feb 03, 2010
Obertelli
  • 3006 Answers
SOURCE: Camer won't turn on.(Cannon EOS Digital Rebel XT)
A dead camera is impossible to tun diagnostic checks on without specialist tools, so yes, your camera will need to go to a Canon service centre for diagnosis and an estimate. If you decide not to go ahead with the work then you'll be charged for return shipping and a fee for the work carried out to make a diagnosis.
If the warranty expired fairly recently, then it may be worth contacting Canon before getting the estimate: it's not unknown for them to offer goodwill repairs for major faults which occur prematurely, but you need to be aware that your model was only designed with an approximate four year minimum lifespan.
Posted on Mar 10, 2010
  • 11967 Answers
SOURCE: canon eos 350 rebel xt doesn't recognize usb cable
Posted on Jun 30, 2010
Computer doesn't recognize Canon EOS Rebel when it's plugged in
Having gone over a month with no response, I assume this is no longer a problem.<!-- from fixya rte -->
Jul 05, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Dec 04, 2009 | Canon Rebel XT / EOS 350D Digital Camera
NO POWER in my digital camera
Could be your power circuit. You may contact Canon direct in Jamesburg, NJ or take it to an AUTHORIZED service center for faster service. I know of one in Flordia 305-653-7355
Apr 20, 2009 | Canon Rebel XT / EOS 350D Digital Camera
My new Canon Rebel EOS XT will not work with my external flash. WHY??
Hi , connection from camera to the quantary ps-1 dszflash are compatible the adopter it connect during flash signal.You may return and bring your camera and test what ever compatible.
Jan 05, 2008 | Canon Rebel XT / EOS 350D Digital Camera
No Power To Canon Digital Rebel XT
Change out the CR2016 3V battery. You have to remove the rechargeable battery to get to the CR2016. Refer to the manual for proper instructions.
Had the same issue with a two year old camera. This solved my problem.
Nov 29, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS 400D / Rebel XTi Digital Camera Logo
29 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
