Question about Panasonic HDC-SD9 Flash Media Camcorder
Brooken lcd connection
I have broken a plastic ribon cable which connects the lcd screen to the internal board , i broke it while repairing the still image button, i cant find a replacment
2 Suggested Answers
electronios
  • 126 Answers
SOURCE: panasonic camcorder nv-gs35 ribbon cable damaged
ASK NEAREST PANASONIC SERVICE
Posted on Nov 19, 2009
I have a missil digital mp4 player and it falled down and now i can't see anything but when i turn it on it lights but no picture so please help me.
I personally can not tell you without opening up you device and since I do not know which type of MP4 player you have I can not tell you exactly what to do, but, using an educated guess, Id have to say that the data cable that runs from the circuit board to the LCD screen is disconnected or broken, or if you have black specs in you screen like a liquid you broke the screen and it needs replaced if not, your best bet is to open up the device, by means of screws, Philips or torques being to two most common types, or it had a snap seal, meaning that the front and back covers are held together with snaps, removal of these types of covers is impossible without damage to them, that is why most shops replace the covers when they fix these devices, once the cover is removed you may have to remove more screws, if not you should see the LCD screen now, inspect the cable for any damages, if you do not see any follow the cable to where it connects to the circuit board, if it is disconnected you most likely can fix your device by reconnecting it. The most common type of plug in this type of device is a **** clamp, to reinstall your cable, lift up the plastic piece over the connection and slide the data cable back in, then lower the plastic piece back in place to make a connection, before you reassembly your device be sure to turn it on now to make sure your screen still works, if it does, then reassemble your device. If not, your screen is most likely broken or there is unseen damage in the data cable.
Oct 27, 2010 | Audio Players & Recorders
I have a Polaroid 40" TLX-04011C. The screen resolution is fine except for about a 4" area along the right side from top to bottom. This area is lighter than the rest of the screen. The picture is still...
I have not repaired this particular model. But I have repaired another polaroid flat screen TV. I can tell you for sure, the biggest problem here are bad capacitors in the signal board. You may find 15 or 20 bad caps. On the power supply there may be a two or three caps that need replaced as they will be weak but not real bad. Yes,the majority of the caps will be found in the signal board. You will need a good capacitor checker to locate these. It will require patience and skill to remove and replace these caps. I cannot say enough of bad capacitors in this TV. Find a TV tech to help you! Thanks for asking, show me a few hands of appreciation. This answer is your best effort for repair!
Sep 19, 2010 | Polaroid TLA-04011C 40 in. LCD TV
Digital camera screen broken
A cracked screen will cost you, but maybe not as much as you think. Instead of replacing the whole , you can spend about $300 and replace the screen yourself. All you need is a small screwdriver.
1)Turn off the power to your screen and unplug all cables connected to it.
2)Remove the battery, if one is installed.
3)Locate the covered screws around the cracked screen. Remove the rubber/plastic covers, then unscrew the screws.
4)Gently remove the plastic frame around the cracked screen and set it aside.
5)Disconnect any power cords or cables going into the LCD screen.
6)Remove the cracked screen and slide the new screen into place. Replace any tape or plastic fasteners that hold it in place.
7)Reconnect all internal cords to the screen.
8)Screw in the frame and replace all the screw covers.
9)Reconnect the power supply and all external cables to the LCD screen and switch it on.
Aug 31, 2009 | Sony Cyber-Shot DSC-P150 Digital Camera
Broken touchpad connector
I suggest you replace the motherboard. A recent search on ebay turned up three ranging in price from $18 to $85. Soldering a motherboard by hand has a very high failure rate. It's easy to bridge or scratch something and fry the board. You could of course try to do it and if it fails get a replacement board.
May 28, 2009 | HP Pavilion ze1115 Notebook
Gatewway monitor lines
Assuming you checked your cable to monitor connection first.
There is apossibility that the ribbon or cable connecting your monitors internal video board to the lcd screen has a loose connection. Check those first.
A lot of screens also have a ribbon connecting the top and a side board in the lcd screen itself that may have a loose contact. usually this ribbon is at tthe top left or right on the rear of the lcd.
If all connections are okay, then I fear that it may be in the actual video card in the monitor..
Fran
Aug 05, 2008 | Gateway FPD2275W LCD Monitor
Dark screens
No.. most likely the ribbon cable that connects the lcd screen to the rest of the ds has been damaged or knocked loose. Or the circuit board somewhere has been cracked or damaged, affecting the circuitry that sends a signal to the lcd screen.
Is it under warranty? You can maybe send it back to Ninendo for repair. Or open it and attempt to repair it yourself. Otherewise I'm afraid the DS is just broken...
Feb 03, 2008 | Nintendo DS Lite Console
Maxent 27" LCD Flat Screen TV
This is a fault i have seen with phillips lcd tv's and i suspect it could be the lcd screen itself,the ribbon cables from the screen are heat contacted on to a circuit board and there could be anything from 10 to 15 of these ribon cables and over a period of time the heat generated from the internal panels will deteriorate the plastic ribbon cables.
Try twisting the screen gently by placing your left hand on the top left hand corner and your right hand on the top right hand corner and gently twisting,if the lines go and then come back after you let go then a new screen will be required but it may be cheaper to buy a new one,could be worth buying the extended warrenty.
Feb 02, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
LCD display
This 1.7" LCD is made by AUO and it is most likely defective. You may try reseating the internal ribon cable of the LCD connected to the printed circuit board by opening the camera back case (5 small screws) with a tri-wing screwdriver size #000. Care must be taken as the flash light charging circuit is active and touching certain area of the board may give a big shock once you have access to the internal guts of the camera.
Jan 18, 2008 | Fuji FinePix A350 Digital Camera
My MPX220 internal LCD broke
I would personally suggest going to ebay. They carry many replacement parts for cell phones such as the Flex cable that you need, and are quite inexpensive as well. I guess figuring out how to install it is the tricky part. Good Luck!!!!
Feb 11, 2007 | Motorola Mobility MPx220
Panasonic HDC-SD9 Flash Media Camcorder Logo
22 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
