Question about Samsung Refrigerators
My samsung RF4287 (french fridge doors and freezer on the bottom) will not freeze.
The display was replaced 2 months ago and currently says -2, but obviously that isn't correct. The fridge seems to be working fine. It is only 2yrs old.
  • 171 Answers
Check if there is build up of snow in the freezer behind the cover.
possible defrost problem
Posted on May 24, 2014
  • 1 more comment
  • Tony Martin
    Tony Martin Jun 07, 2014
    If U have a ice lever in the door Ck this first place a towel under the freezer door and open door pour 4 to 6 oz water to over the flapper look at the front see if the water is leaking. ? Yes this is a air leak. the spring is not closing the seal. Not easy add 1 full turn to spring.
  • Tony Martin
    This stops freeze up in freezer too.
  • Tony Martin
    Sensor on coil need to be moved to return line under fan motor
  • 76 Answers
Some of the other answers could be the problem, but if the fresh food side is at the right temperature, it could be a sealed system problem or an overload relay problem. If you have a clamp on amp meter, open up the back and take a reading on one of the wires going to the compressor. If the reading is below 1.1 amps while compressor is running you have a sealed system problem which takes special tools to fix, if it is much higher than 2 amps then replace the overload relay that is connected to the compressor and this may solve the problem. The readings should be between 1.1 and 2 after replacement, if not then the compressor is bad.
Posted on May 30, 2014
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
  • 27 Answers
SOURCE: Digital display is blank in GE Profile fridge
Hi. Its either a bad motherboard or control board. I would check the control board for any obvious signs of damage to the board first. I've seen the control board go blank on the GE side by side and it turned out to be the motherboard. The motherboard is located behind a cover on the back of your refrigerator cabinet. You should have a new motherboard on hand at all times because they fail alot. Be sure to put a surge protector on your refrigerator. Good Luck, Mack
Posted on Feb 02, 2008
SOURCE: GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Posted on Sep 21, 2008
lenwest
  • 150 Answers
SOURCE: refrigerator will not get cold, but freezer works
Make sure your fan is working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked (usually with ice).With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open untill all traces of ice are gone this will free up any clogged tubes. Good luck.
Len West
Posted on Feb 27, 2009
woodchuck789
  • 4066 Answers
SOURCE: Fridge not cold as should be
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Posted on Aug 29, 2009
My samsung control on the freezer is displaying OF OFseems ice maker is off I pushed the power freeze by accident and can't get back to regular display
0F 0F on a Samsung refrigerator display indicates that your unit is in DEMO Mode. In DEMO mode, the lights work, but the refrigerator/freezer, fans, etc. will not operate (this mode is for display/retail purposes in appliance stores). Unfortunately, Samsung does not include any info re: DEMO mode in their user manuals.
To exit DEMO mode and return to operating mode, you will need to push 2 display buttons simultaneously for ~ 3 seconds (you'll hear a small chime, then the display window will display the freezer/fridge temps and will then be out of the 0F 0F DEMO mode). The 2 display buttons that you have to press simultaneously will depend on the model of Samsung refrigerator that you have.
I have a Samsung RF18HFENBSR model (french door, bottom freezer, display at top center of fridge compartment). For this model, you press the Power Freeze & Freezer buttons at the same time to enter/exit DEMO mode).
You might try googling Samsung XXXXXXXXXX Demo Mode, where XXXXXXXXX is your model number, and you may find the display button combo for your model. If not, then you can probably get the combination from Samsung support to return your unit to normal operating mode. Your appliance store may also have that information.
Sep 10, 2017 | Samsung Refrigerators
Water is coming under freezer section of Samsung RF4287 bottom freezer French Door
You have a plugged evaporator (cooling coil) drain pan opening or drain line.
Feb 06, 2015 | Samsung RF4287HA
Reading on door OF
Teresa, The fridge is in a retailers demo mode and here is what you do to reset it to normal operation:
Left Door: Simultaneously press and hold the top two buttons on the left side of the display panel until you hear a distinctively different chime sound when the display changes. This will either be a combination of "Energy Saver" and "Freezer", or "Energy Saver" and "Power Freeze/Freezer."
  • At the top of the door frame: Simultaneously press and hold the "Power Freeze" and "Freezer" buttons until you hear a distinctively different chime sound and the temperatures for the fridge and freezer are both displayed.
  • Note: If the temperature is displayed, but then "OF OF" reappears a few seconds later, Cooling Off mode was not disabled. Repeat the actions above, and be sure to press and hold the buttons at the exact same time until the distinctive chime sound is heard and both temperatures are displayed.
Apr 11, 2014 | Samsung RF265AA Bottom Freezer French Door...
RF265AARSXAC The freezer is not freezing.
looks as evaporator fan is working. have you ever clean condensor under the fridge. possibility it is pluged with dust and not allowing compressor to cool down.
Also check the fan at the back of the fridge beside the compressor. see if it is working
Nov 14, 2013 | Samsung RF265AA Bottom Freezer French Door...
Samsung rf265 series french door with freezer drawer on the bottom: Water collects under the veg drawers in the refrigerator part. What might be wrong?
I have the same problem!!! We need a class action lawsuit against Samsung for this problem on their French Door fridge. Instead of fixing it they want the consumer to pay for repair. NO MORE SAMSUNG PRODUCTS FOR ME!!!!!
Sep 04, 2011 | Samsung RF265AA Bottom Freezer French Door...
How do I increase the refrigerator temp in a Samsung fridge RF267AE. The reccommeded temp is 38 however mine is currently at 36 and items in the back are freezing
you should only have to press the button up to change the temperatures, if that does not work the display board on the front will need to be replaced to fix the issue, let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Samsung RF267AE (25.8 cu. ft.) Bottom...
Freezer is not defrosting. it's a RF265ABPN model
Your defrost termination sensor has failed & needs to be replaced.(very very common problem with todays fridge's specially samsung)
Feb 21, 2011 | Samsung RF265AA Bottom Freezer French Door...
LG French door fridge freezer not freezing
hopefully you looked out back ...rear lower panel and checked little white condenser fan running...it really needs too to keep temp stable across the condenser coils and no overheat condition to the compressor.hopefully you wont need the $300 circuit board like I just bought
Jun 26, 2009 | LG LFC20740ST Stainless Steel
My Samsung refrigerator will not cool
Call Samsung. I had the same problem when Best Buy delivered mine. The delivery people left the fridge in demo mode. The people at Samsung will talk you through it, it is very simple. The fridge should work fine then.
Jun 22, 2008 | Samsung RF265AA Bottom Freezer French Door...
Refrigerators Logo
429 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
