Question about Stoves Ovens
BAUER B50E THE INSIDE IS PEELING OFF WHAT CAN BE DONE?
Stainless steel oven finish peeling off
It is likely that the factory-installed clear plastic protective covering was not removed before the oven was placed into service.
Stainless Steel does not peel!
Ovens and other appliances with Stainless Steel finishes are made from solid sheets of the material. They are almost always sent from the factory with a protective plastic film on the finish.
Just find an edge of the appliance, and start peeling the protective film off. Pull it off slowly, as to not leave any possible residual glue or plastic on the appliance.
If the heat from the oven caused some of the plastic film to melt and it does not peel off, I would immediately call the store or dealer from which you purchased the oven and start hollering, as they did NOT properly prepare the item for sale (if it was delivered and installed).
If you purchased it in the crate/box, and installed it yourself, you must take responsibility for not having fully read the instructions before using the oven.
In that case, I would peel as much of the plastic off as is possible, and then use some LOW ODOR CLEANING SOLVENT ( or PAINT THINNER) to remove the rest, using ONLY a soft cotton towel to soak it and rub it with. Do NOT use anything abrasive or scratchy, or you will totally ruin the finish! Do NOT use the scrubber side of a sponge, or a Brillo pad, or Choreboy-type pad!
*** CAUTION!!! *** DANGER! *** The fumes and vapors from the solvent ARE EXPLOSIVE AND FLAMMABLE! DO NOT USE THE STOVE UNTIL THE VAPORS AND FUMES HAVE TOTALLY DISSIPATED!!! Open the doors or windows to the room for fresh air when you are using the solvent, and READ THE INSTRUCTIONS thoroughly!
All is not lost yet, but getting melted plastic off the stove will take some time and a very gentle touch. Be patient, and good luck.
Jul 20, 2014 | Ovens
Film on s/steel oven peeling off. I made the
If the film is blue this is a protective cover for shipping only and should be removed when installed. It peals away. If it is not blue tinted and is clear then you can remove remnants with a scrubby sponge.
Nov 04, 2013 | Ovens
How do i clean inside my delonghi glass door the inside
if you pull the oven out a little bit and look under the the door there should be 3 screws you only need two undo one on each side but when undoing the last screw hold the bottom of the door tight as it will fall when you have door frunt off job done ok
Oct 12, 2012 | DeLonghi DEBIE24SS Stainless Steel...
Everything burns before it is done in the oven
You will need to replace the temp. sensor inside the oven. If you could post your model number I can direct you to the part you need.
Dec 20, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Will I be able to replace the element from inside oven?
It can be done from the inside if you are careful.
The thing to watch is that you do not lose the wires off the terminals when you disconnect from the heater, because if you do, you will have to gain access from the rear of the oven.
Please rate my solution.
Thankyou.
Jan 23, 2010 | Ovens
Element needs replacing
You need to remove the outer rear panel of oven to gain access to heater on this model.
The element is attached to a panel at the rear of oven , which when removed gives you access to the element..
It cann ot be done from inside the oven.
Plz rate my solution.
Thanks.
Jan 24, 2009 | Candy Ovens
AMANA SINGLE CONVECTION OVEN CONTROL PANEL SOME KEYS INOP
Usually the keypad is separate and connected with a ribbon cable.If so, you just need to order a new keypad assembly
May 21, 2007 | Amana AEW4530DDS Electric Single Oven
I DIDN'T GET AN INSTRUCTION MANUAL
I dont know if you've solved th eproblem of getting the gyrooven working but if you press down the button that looks like a pot cooking and press the + button to whatever timer you want the oven will then work. Mine does anyway!
Oct 29, 2006 | New World E70DOa Electric Double Oven
Open Questions:
Faulty obsolete (20yr old) oven thermostat with separate fan/light switch. Can't find a 'universal' replacement. If I fit a standard 2 tab thermostat, the fan and light will switch with the element Stoves oven DF550 SI with a 46thc502/G5 thermostat which controls well (if 40C higher relative to the oven thermometer). However after an overnight cool down the oven element switches on when the mains is turned back on, even though the oven control is off. I just twiddle the oven thermostat control slightly and all is well. I can't find a 250C, 1m phile, 24mmx6mm spindle thermostat with a separate connection tab for the internal recirculating fan and oven light anywhere. Otherwise the single oven cooker works and looks like new (nearly). I was wondering whether I have to piggy back a switch on the back of a standard 2 tab thermostat (or vica versa) or attach a separate switch to the oven. Can't believe I'm the only one with this problem. I'm guessing some fragile electrical contact occurs in the thermostat on cooldown to turn on the element and its in-series lamp, and this contact easily breaks by slightly turning the thermostat. ps there is no timer and I do have the circuit diagram. I found a working solution to this problem: When turning off the oven, I don't take it to the end stop. I turn it passed the click when the element and indicator turn off, then further till the ligth and fan turn off and just a fraction further but not to the end stop. Now the oven element doesnt turn on each time I turn the mains on for some other reason ( eg grill or igniters). I guess there is something wrong inside the thermostat, but this work arround seems OK if not ideal. I've marked a new stop position around the oven dial to remind me. This was easier than making a physical stop for the oven dial.
Feb 24, 2018 | Stoves Ovens
Ovens Logo
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
