Question about American Standard Plumbing
Clogged cartridge causing water to leak out of the handle
American standard Fairbury kitchen faucet - we believe that dirt has clogged the faucet as our water comes from a lake how do we clean it ?
  • 171 Answers
SOURCE: kitchen spout leaks
Hi buffy9,
I'm Harvet the Master Plumber.
Your question is: You have an American Standard two faucet in my kitchen and the base of the spout leaks at the base. How do you remove it and replace the washers?
Are we talking about an American Standard two HANDLE faucet or one of the single handle models?
Thank you,
Harvey your Master Plumber
Posted on Oct 17, 2008
  • 68 Answers
SOURCE: Slow and nonexistent water flow.
Start by removing the spray head from the hose. Pull the spray head out and with a channel lock pliers unthread connection between the spray head and hose. BE CAREFUL not to let the hose fall back down into the faucet. With the hose directed down toward the sink test for volume by turning on the faucet. If you get a nice volume the problem is in the spray head. This is usually the case. Put the spray head back on then remove the aerator. It's the screen where the water comes out of the spray head. Clean out the assembly ( 3-4 parts). Reassemble and test.
Good luck, Phil
Posted on Dec 11, 2008
  • 297 Answers
SOURCE: American Standard Easy Touch 6310 kitchen faucet leaks at base
you must remove the faucet form the sink. under the plate in the middle is 2 screws. remove the screws to remove the body.
Posted on Jul 15, 2009
  • 297 Answers
SOURCE: how to replace sprout seal kit in american standard faucet ?
just pull straight up,wiggle back and forth,the o-rings are holding it on .
SOURCE: kitchen faucet single handle pull-out. The base of
I have the same problem with an American Standard Reliant Kitchen Faucet that wont swivel anymore. I called American Standard and they are sending me the replacement parts to fix it free of charge, I have had mine 6-7 years and they said it was under warranty. Call 800-442-1902. Good Luck
Posted on Apr 05, 2010
I just installed an American Standard easy touch faucet 6310F. The pressure is very low. Anybody know what the problem may be?
At the base of the handle there is a flow regulating check valve. Shut off water supply and unscrew handle and look for debris. Many times the washers break down on the shutoffs under the sink and release "crumbs", these usually block aerators and sometimes the cartridges on certain faucets. Hope this was helpful.
Feb 16, 2011 | American Standard Kitchen Faucet 6310 020...
When dishwasher is running, water leaks under base of our American Standard Colony model soft two-handle kitchen faucet into cabinet beneath sink
Is there an air gap next to the faucet that is leaking. If so, it is probably clogged. Pull the cap off of it and clean it out. This is what it may look like before you take the cap off.
b7ookdehz3uf293omx2ye0fveemyn-clsycdlpsjpi2zdtnzgmj_hhepw5uyprhfsmyzy7tnfmt6uzrk1edu-duydxm839afzrsaplofdfdjymmjvj8xncabtrcoevtu5jguw1elsvyttyypguy-89xi_btsfhkvzgvdbfbda26sii9hwd8sgq
Jan 16, 2011 | American Standard 4275.550.002 ColonySoft...
I have an american standard kitchen faucet, when the handle is half open I get a leak, at home depot where I bought it two years ago, they told me I need to take it apart to see which kit will repair...
The single handled faucets have a valve cartridge which needs to be replaced when it leaks. Disassemble the handle to find the valve inside. Take the valve to the hardware store to be sure you get the right one and reassemble. To disassemble, pop the cap off the lever, unscrew the single screw, then use slip-joint pliers to loosen the retainer nut. lift the cartridge out with pliers taking note of the direction of the notch at the top of the stem. Be sure to reassemble with the notch facing in the same direction. You should replace and lubricate the O-rings when you change the valve cartridge.
Since you have the numbers for that particular faucet, you might want to call around to find the cartridge first. Different models have different valves, so be sure yours is correct.
Oct 08, 2010 | American Standard Kitchen Faucet 6310 020...
Jul 15, 2009 | American Standard Kitchen Faucet 6310 020...
I have an American standard center spigot one handle, it is dripping, how do i get apart to repair
first turn the water off,then pull the handle off unscrew the top plastic piece pull neck off replace 0-rings,or cartridge what ever is needed.
Jun 06, 2009 | American Standard Kitchen Faucet Ceramix...
How to replace sprout seal kit?
After you remove the handle, the chrome cap should either snap or spin off.It also may come out with the cartridge... There are 3 screws that hold the cartidge in the faucet...take them out and you should be able carefully work the faucet are off of the core of the faucet. Put a little cooking oil on the o-rings after you install the new ones... just to allow the faucet arm to slide on without damage... Hope this gets you dripless!! Let me know if you have a question. K
Jun 05, 2009 | American Standard 4175.200.002 Colony...
How to replace sprout seal kit in american standard faucet ?
Jun 05, 2009 | American Standard 4275.550.002 ColonySoft...
Kitchen spout leaks
Hi buffy9,
Thank you,
Oct 16, 2008 | Plumbing
Plumbing Logo
27 people viewed this question
Top American Standard Plumbing Experts
Donni Steen
john h
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
