Question about Bosch DKE93xxUC Stainless Steel Kitchen Hood
Why wont my Bosch cooker hood work?
My Bosch chimney extractor hood isn't working. It has power because there is a very small red light in the bottom right hand corner of the readout. I've turned it off and on again to try and reset as advised by the manual but nothing. The lights don't work and I can get nothing else out of it. Some forums have advised changing the fuse but surely that can't be the problem as the small light is on?
2 Suggested Answers
  • 72 Answers
SOURCE: bosch dke 935 90cm hood. light and extractor not working
The fuse will be located in the switch or socket that the hood is connected to. This is sometimes inside the flue on the back wall. There should be two small screws either side of the chimney located at the top, unscrew and slide one part of the chimney down, please be careful as stainless steel has very sharp edges.
Posted on Jan 04, 2010
I've replaced both lights in my Faber (Classic) cooker hood but though the extractor fan works the lights dont and they're powered by the same source. The light switch is on and the flap close switch is...
Probably the transformer is blown on the hood, please write info@faberspa.com if no in North America or go to : http://faberonline.com/service.html
Jan 27, 2011 | Faber (272607) Kitchen Hood
Bosch dke 935 90cm hood. light and extractor not working
Dec 09, 2009 | Bosch DKE93xxUC Stainless Steel Kitchen...
Light on cooker hood doesnt work
check the switch, if you got power then the switch or bulbs sockets.
Jun 22, 2009 | Kitchen Ranges
What is the height of britannia omaggio 90 cooker hood?
Here are the dimensions that relate to your cooker hood. The measurements are in mm.
Width 980 front 578 rear
Depth 480
Minimum height 1015
Maximum height 1170
Main canopy height 750
(excl chimney)
Chimney section width 436 main body/340 sliding section
Chimney section depth 170
Mounting height 650 - 750
Regards
Alan Hood
ami-man
Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750
Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750 Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750 Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750
Jun 16, 2009 | Kitchen Ranges
CDA CPX9 COOKER HOOD - how to remove chimney/disconnect power
remove filters, inside there will be mounting screws, support the unit prior to removing screws. there might be ducting inside clamped on, and a power plug(hopefully) to disconnect.
Jan 26, 2009 | CDA Kitchen Ranges
Baumatic cooker hood lights not working
take the bulb out and bring it with you to store and see if you can find one the same . DIY stores have tons of types.Joe
Nov 16, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
Bosch dishwasher shu 3302
JiXing Hardware & Mesh Products co.,ltd ,established in 2005, owns two factories in China mainland.
We can supply many kinds of aluminum cooker hood filters,grease filters,,hardware parts,wire shelf,wire and wire mesh.
Our products are sold all over the world , we can assure the good quality with competitive price.
Hope to establish a long-term business relationship with you.
contact info: info@mmfilters.com
TEL:0086-318-7803299
FAX:0086-318-7755255
Nov 29, 2007 | Bosch 36 Inch Pyramid Chimney Hood - Black
Rangemaster cooker hood. model no.LEIHDC120SC/
hood should be connected to a fused spur outlet which you havent found. try removing the chimney and you may find it there. chimney only held by 2 screws at top usually.the fuse in the outlet sometimes goes when bulbs blow
May 31, 2007 | Rangemaster Broan 614804 BALLISTA 48IN...
Halogen Lights Failing
I had the same experiences with my lights. I placed a 50v bulb and it blew the fuses. The fusees located on the right side of the bottom duct cover. use 5a 125 v fuse GE part # wb27x10542 but you can find a cheaper fuse at Radio Shack. Good luck
Mar 28, 2007 | GE Monogram ZV1050SFSS 42" Island Chimney...
Bosch DKE93xxUC Stainless Steel Kitchen Hood Logo
67 people viewed this question
Top Bosch Kitchen Ranges Experts
William Miller
William Miller
ashburton
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
