Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Why doesn't my ice maker make ice?
I've had to replace this unit twice in 7 years and now this one has stopped producing ice as well. The unit still functions, but doesn't seem to call for water.
  • 173 Answers
Check for water valve.at the back. It is a posibility it is pluged or burned out
Posted on Jun 02, 2014
SOURCE: LG Ice maker
I got the same problem where the plate is cold and the water does not fill - saw this comment from other posting and help. Basically, the ice maker was stalled! Make sure you can see the green light is on, which means you have power. if its lit, press and hold the cube size button until i/m starts to cycle. If i/m runs, but does not fill then your water valve is bad. If i/m will not start then your i/m is at fault.
Posted on May 07, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Ice maker doesn't work
Unplug Ice maker from plug on inside wall, remove and let thaw. Don't worry when removed the water will not enter the freezer. Let me know if this works as I get very little support from LG. Thanks, Se Breeze
Posted on Jul 30, 2009
JigSaw007
  • 157 Answers
SOURCE: ice maker on a LG LRFC25750ST
hello sir
Posted on Aug 22, 2008
  • 10 Answers
SOURCE: LG Side by Side - replaced filter now ice/ water will not worl
See if it works when you pull the filter out and try running it (without the filter in). If it works, try buying a new filter and make sure you have the filter that is made for your specific refrigerator. If no water comes out or no ice is made after pulling filter out, than you probably have a obstruction in the line. If thats the case you should have someone come out to fix it. If your mechanically inclined you can try to do it yourself. I would suggest reading the owners manual first, in the "troubleshooting" section.
Posted on Aug 05, 2009
  • 13 Answers
SOURCE: LG refrigerator won't dispense water any more
The water line is freezing in the door due to deteriorated insulation. The only fix I have found to work on my fridge was to defrost the inside door with a blow dryer. Then place a weedeater replacement line (the orange 10" or so size you find at Lowes' or Home Depot) up through the dispenser nozzle, If the line only travels about 3-4 inches up the nozzle, then ice is still in the tube. Blow dry it until you are able to get water to dispense. After the tube is ice-free, place the weedeater line up throuth the dispenser nozzle leaving about 1/8" sticking out. The dispenser will still work with the line stuck in it. The dispenser will probably freeze again in about 8 hours, But all you need to do each time this happens is to pull the weedeater line out, dispense the water to unclog the ice, and place the weedeater line back in the nozzle. I have been using this method for about a week now and it works great. My GE Side-by-side is also 4 years old and this seems to be a problem with all of them. There is a part you can order to fix the problem, but I have heard it may not work.
Posted on Mar 21, 2010
How do I get the ice maker to produce for the first time
Is the arm that gets pushed up by the ice cubes (in order to stop making ice when it is full) in the down position? it is able to be pushed up and locked so that the icemaker doesn't make at ice and may need to be pushed down.
Aug 27, 2014 | Maytag MSD2454G Side by Side Refrigerator
Frigidaire not making ice
If your ice maker has stopped producing ice completely, please check these, in this order:
1. It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
2. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
3. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
4. Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Should these suggestions prove to be ineffective, contact a professional to have the unit diagnosed.
Sep 13, 2012 | Refrigerators
Electrolux icemaker not working
Should these suggestions prove to be ineffective, contact a professional to diagnose the unit.
Sep 13, 2012 | Electrolux Refrigerators
Samsung french door refrigerator ice maker no dispenser defroster leaking water into bottom and produce drawers
If it is a frost free unit the water collects in a well at the compressor , there is a heater element in the well that boils off the water , this is were the fault is.
Jun 04, 2017 | Samsung RF217ACPN - 20 cu. ft. French Door...
I have a Kenmore side by side model # 106.53609202 and its about 8 years old. About a month ago it stopped making ice. I've already replaced the water valve behind the fridge and waited 24 hours and...
OK, remove the cover on the face of the ice maker and let me know if the model look like this picture:
12_17_2011_1_36_01_am.jpgIf it looks like this model, I have the service manual for it with all the testing procedures.If it doesn't, see if you can get a model number off the unit. They make about 4 different model for this unit.
Happy Holidays!Richard
Dec 17, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker stopped working, but used to work very well. During a course of a week, ice production kept slowing down to nothing. Test button on the side of the ice make unit does nothing. Unit is only a...
I had a similar problem with my Samsung fridge, my problem was the the ice holding unit had been taken out and not reinstalled correctly,
There is a rod on the rear of the tub and it has to be placed properly in the drive gear at the rear of the ice making housing so that it fits properly and smoothly.
If you still have a good water supply available at the door then the problem is probably what I just described, Good luck
Aug 27, 2011 | Samsung RF26VAB (25.5 cu. ft.)...
This is the 2nd time I have had the same problem. After one year the ice maker stops making ice and heats up inside the unit. Viking replaced the unit last year and now one year later I have the same...
could be numerous issues that stop machine from working
but as its outdoors i would remove condensate drain pump
and make it a gravity drain
if drain pump fails will shut down power to unit
Aug 28, 2017 | Viking Refrigerators
Our Ice maker is not producing ice. I've tried using a hair dryer to melt possible frozen water. It worked once, but now that ice maker is back to not producing ice.
The heating element is not working to heat the base and free the ice from the tray. At this point it's probably better to just replace the ice maker. They are about 60-70$
May 19, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker not making ice. do have water, no ice
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Aug 29, 2009 | Kenmore Refrigerators
Ice maker in Kitchen Aid stopped making ice
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
May 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
