Question about Tasco NV200W Monocular
Unit will not turn on. Changed batteries. Batteries became hot
    President:
  • 1,185 Answers
For batteries to get hot they must be in a dead short situation.
Have you put batteries in the wrong way around before you have realised and then put them into the right positions
If the power circuit of the monocular has not got reverse polarity protection you can short out components which will give you the problem you have now.
Only solution is to get someone to take the board out to see if it is cooked
Posted on Jun 23, 2009
It works fine for about a few minutes and then the light is slowly getting pale and the sound slowly looses power until it doesn't give any sound at all. Tried a few different batteries, same thing.
Battery is not the problem.
It could be transistors, IC, elco etc. It must be checked.
This electronic parts, could be almost breakdown. At the beginning of the device is turned on, it work fine, but after a while it became hot, then the value is changed, then the circuit was not working.
Can also occur on the DC input, the diode and the elco (D006,C019,C40,C41). View image.
23095950-2ss5ycyvkoajtv035dpuezke-1-0.jpg See the full diagram here :
Boss MT 2 Metal Zone distortion pedal schematic
Jan 24, 2014 | Boss Mt 2 Metal Zone Effects Pedal
CX7300 Digital camera won't turn on. New batteries get hot after being put in the camera after a few minutes.
No. This camera requires service/repairs, the repairs will be more than this model camera is worth !!!!
Nov 12, 2012 | Kodak EasyShare CX7300 Digital Camera
Lock won't work. Our unit became sluggish. We changed the batteries, but now it won't lock or unlock using the keypad. Help.
Kwikset has a lifetime mechanical and finish warranty. Contact them from here:
http://www.kwikset.com/Customer-Support/Warranty-Information.aspx
Dec 18, 2010 | Kwikset 909 909-15 Satin Nickel Smart...
Our bonaire evaporative unit will not switch on. l rang customer service and they advised l reset the unit as we recently changed the batteries l did the reset but the unit still does not work and after...
try reset the controller. turn off power to the unit then remove batteries from controler. press the power button on the controller to remove residual power. turn on the unit then install batteries. turn on controller within 4 minutes of turning on unit
Nov 23, 2010 | Mastercool 67471 Evaporative Cooler Air...
Geko 101 wouldn't turn off. Removed/inserted batts, wont turn on
Press the power on button while holding OK until the unit switches on- that puts the 101 into Service mode. Then press the up key until the screen contrast is about right. (or press the down key... to make it darker). You'll be able to see if all the tests pass. Then when you're happy with the setting, turn off.
Mar 31, 2009 | Garmin Geko 101 GPS Receiver
Fan not turning outside
Is the outside compressor running? Check the fuses in the outside disconnect by the outside condensing unit. Also check the breaker for the A/C in the main power panel.
Jul 06, 2008 | Heating & Cooling
Sennheiser RS130 does not appear to turn on
did you try to put regular batteries in to see if that works?
May 20, 2008 | Sennheiser RS130 Headset
Samsung S800
If the camera fell on it's lens it is probably jammed. Try to find something small, strong and thin, possibly a hairpin and slide it into the barrel while gently trying to force it outwards immediately after switching it on. When it does extend, try to clean or blow out any grit that may be inside the mechanism. The batteries are hot as your camera does not switch off and may be remain on for hours
Feb 23, 2008 | Samsung Digimax S800 Digital Camera
Midland gxt-850 gets HOT!
It is very possible that the terminal of the positive end of the bottom battery is shorting to the battery's body hence the heating up. If this is the case, then when you charge the radio, excessive current is flowing since the battery set has one shorted. Again this would cause heat buildup specially on the bottom battery and the charging terminals.
A possible solution is to check the bottom battery's positive terminal and ensure that it only contacts with the positive terminal of the battery and does not touch the battery body (which is negative).
Alternately (and perhaps more to your advantage), seek replacement of the defective unit considering it is new and therefore should be under warranty.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 06, 2007 | Radio Communications
Tasco NV200W Monocular Logo
220 people viewed this question
Top Tasco Optics Experts
Marvin
Marvin
ray gallant
Are you a Tasco Optic Expert? Answer questions, earn points and help others
