Question about Kenmore 46123 Stainless Steel Electric Kitchen Range
How can we turn off oven cooling fan after use> It runs forever after use and oven is at room temp but fan keeps going
Also shelves are 1/4 short on width and when heavy objects are used they fail
    Problem Solver:
  • 14 Answers
The cooling fan is controlled by the EOC and a temperature sensor located at the top of the oven near the control panel. If the temperature is above a 100 degrees there the cooling fan will continue to run. If it does not turn off when the temperature goes below this, there is a problem with either the EOC or temperature sensor. Try turning off the power to your oven for at least an hour to reset the EOC, this may fix the problem.
Regarding the shelves being 1/4 short, this is actually caused by your oven liner expanding not your shelves shrinking. The only fix for this is to have your oven liner replaced.
Both of these repairs are very expensive ( > $300) and may not be worth fixing.
Posted on May 19, 2014
My oven and grill and thermostat light are not working but fan is running. Any ideas?
No make or model try this remove the temperature sensor ohm it out should be around 1080 at room temp in WP products if the sensor is open or shorted the control locks out the unit and runs the cooling fan thinking the unit has over heated hopes this helps
Feb 15, 2015 | Ovens
Cont question on impala ck engine
Haven't yet checked the coolant temp sensor ? Does the vehicle shift good , engine run good ? If yes the coolant sensor isn't any problem . Is this your only problem ,The 25 amp mini fuse that keeps blowing is labled as fan cont #1 > You have a direct short to ground on the circuit that fues powers up . Do yo know how to find a short ? Videos on youtube for checking for shorts . It's probably a wiring problem . Insulation rubbed through , touching metal on the vehicle somewhere . Your vehicle cooling fans have two speeds low an high , that's it . Relay Driven Dual Cooling Fan Diagnostics
Mar 08, 2017 | Cars & Trucks
Oven fan stays on
some ovens have a cooling fan that is controlled by a temp sensor, this will keep the fan running until the area where the sensor is cools. probably normal if it turns off after a while.
Jan 31, 2012 | Ovens
B 2200 - Fan still working - no cool air
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 08, 2011 | Dometic Rooftop RV Air Conditioner
With my thermostat on auto and on heat, and the furnace turns on, the fan will not turn on with it. If I switch the fan to on it will run after I repeat back and forth from auto to fan on several times...
Well, here is the deal: unless you rewired from two wire to multiple (usually 4 to 10 wires) wires, the fan cannot be controlled from the thermostat, even though the thermostat indicates that it can > it is a physical wiring and fan administration issue.
Unless you have a newer furnace, the fan is controlled by plenum temp. Works like this: burner turns on, no fan until the plenum temp reaches set temp,....then burner off, and fan keeps running until pelnum temp drops, and often the fan may kick on a few more times as this temp depletes.
Oct 03, 2010 | Honeywell Electronic Programmable...
The oven works fine as in it heats up but when turned off the cooling fan keeps going...used it last night and this morning the fan is still on...turned oven on and it is heating up but as I said the fan...
most ovens use a cut in limpet themostat(sometimes called button stat) typically normally open and closed at 40deg c. it will be this that will be not resetting to the open position at room temp. on rarer models the timer controls the cooling fan. some models of aeg and electrolux have a thermal delaying device located in abulb in the wiring loom. hope this helps
Aug 02, 2010 | Ovens
When the oven is switched off after cooking the cooling fan runs to cool the oven down,it now keeps running all the time when the oven is off,the only way to stop it is to turn off at the ciruit...
sounds like the thermostat which allows the cooling fan to keep running after oven switched of is faulty may be stuck on or shorted will need to be replaced.let me know how you went.
Jun 22, 2010 | Fisher and Paykel 24 in. DS-603 Built-in...
High limit switch trips and needs re-set
After grilling or cooking at higher temps leave the oven light on so the cooling fan continues to run for approx 1/4 hour, or whatever setting will keep the fan running...
Apr 22, 2010 | Dacor ECS130 Epicure Electric Single Oven
Lg split indoor fan runs non stop
Hello Hamid,
The unit is designed to run the indoor fanmotors continuously when in cooling mode on both indoor units (evaporators). The reason is that this circulates the air and the temperature thermistor or sensor is able to sense return air temperature and in turn start or stop the outdoor unit and compressor as required according to the setpoint temperature. The reason for either unit not reaching setpoint temperature can be a couple of reasons. A) Incorrect design - the unit may be too small for the application. You can calculate this roughly at 650BTU per square meter of room in a relatively warm ambient climate. Or secondly B) The outdoor unit has leaked and is short of refrigerant. You can check this when the outdoor unit is running by feeling the thicker copper tube on the right hand side of the unit. This should be cool to cold. If no temperature difference is felt, it is short of refrigerant. Hope this helps you. Goodbye
Aug 11, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Oven fan keeps running even after off and door open
3 to 4 hours is a long time. Get to the fans (behind the control panel) and check the screens for dust. Chances are the screens are clogged with dust and need to be cleaned so the fans can move air for cooling better. I had this problem on my GE JTP14, and after cleaning just one fan it can keep up with cooling the electronic area while the oven is running. It runs much less often.
Safety first! cut the breaker before removing anything with a nice conductive screwdriver! Hope this helps!
Jan 01, 2008 | GE Profile JTP18 Electric Single Oven
Kenmore 46123 Stainless Steel Electric Kitchen Range Logo
131 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
