Question about Brady GlobalMark MultiColor (76800) Label Printer
ERROR 52 What can I do to correct error 52 "Error reading memory cell. Please reload tape." I do have the tape and ribbon in correctly, what else can I do?
I installed new correction tape, but there's too much play in it. It keeps unravelling. I have no idea how to tighten it up. When I turn the take-up spool, it just unravels it more without tightening...
Verify that you have installed the proper correction tape. The types of tape that can be used with this system are: Item 1030 - Correctable Film Ribbon, 1230 - Correctable Film Ribbon 2pack, 1031 - Multi Strike Ribbon, 1032 - Nylon Ribbon, 3010 - Lift-off correction tapes (to be used with 1030 and 1230 ribbons), 4010 Cover-up Correction tape (to be used with 1031 and 1032 ribbons).
Make sure that the correction tape is installed properly. Pass the tape through the left guide, behind the ribbon guide and out through the right guide. The rough side of the tape should face the platen. Attach the feeder spool to the pin on the left. Attach the take up spool to the pin on the right. Turn the take up spool counter clockwise until a small amount of tape has wound around it. Replace the cassette ribbon and close the case cover. Press [CODE] + [RESET] to move the carrier to the previous position.
Dec 27, 2010 | Brother ML-100 Typewriter
I recently received lift off tapes for my nakjima typewriter. We have no user manual. I cannot get the ribbon and lift off tape to correct my errors. Please help or tell me if I am doing something wrong...
The ribbon may be noncorrectable, the knob must be orange or yellow. The lift off may be very old, or not properly installed, the dull side must face the paper.
DickyO
Sep 17, 2010 | Nakajima Office Equipment & Supplies
I changed the correction tape on our IBM wheelwriter 3 and it doesn't seem to be lifting the error. Any advise? The correction tape is not old and I had already tried moving it a couple of inches but it...
You may have a very old correction tape or ribbon, a non correctable ribbon or it isn't properly installed
Go to LEXMARK.COM for a downloadable manual.
DickyO
Mar 31, 2010 | Lexmark Wheelwriter 3 Typewriter
Brother EM-530 corrective tape appears to be broken
Be sure the tape is installed with the dull side facing the platen. The tapes are readly available but be sure it is a dry L/O tape General ribbon T355 or equivlent.
DickyO
Jan 29, 2009 | Brother EM-530 Typewriter
PUT THE CORRECTION TAPE ON CORRECTLY
First, remove the ribbon. Now look at the left side of the printhead. (thats the unit that moves back and forth) You will notice that, above the spindel that you put the correction tape on, and towards the platen, on the black plastic, there is a recessed flat place about the width of the correction tape with slight serrations in it. This is the guide for the corr. tape. There is one like this on the right side also.
Put the corr. tape on the spindle, keeping slight tension on the tape, give it a 1/2 turn so the underside (dull) side is facing to the left, and put it in the guide. Then you put the tape behind the two metal "fingers" that are sticking up in front of the printwheel, and then into the guide on the right side. Then put the other corr. tape spool on the post on the right side, and turn it until the red "leader" on the tape is past the middle of the printwheel. The dull side of the corr. tape is the side that does the corrections, so make sure that side is facing towards the platen. Make sure the ribbon goes behind the metal fingers also. The tape and the ribbon should both be between the fingers and the metal cardholder.
Oct 17, 2008 | Brother SX-4000 Typewriter
Ribbon/correction tape
Ribbons:
Correctable film - MODEL 1230 or 1030
Nylon - MODEL 1032
Multi Strike - MODEL 1031
Correction tape:
Lift-off - MODEL 3010 for use with correctable film ribbon & cover-up - MODEL 4010 for use with nylon ribbon and multi strike ribbon.
Aug 22, 2008 | Brother SX-4000 Typewriter
CORRECTION TAPE
correction tapes will not work with multistrike ribbons. You have to use a correctable ribbon. If you can find a white out tape, it will work with multistrike. What model typewroter do you have?
Aug 12, 2008 | Brother ML-100 Typewriter
Correction Tape
The correction tape which should be a yellow spool and the correction ribbon cartridge should be a yellow also, sometimes orange, first. The correction tape has to in front of the black correction ribbon. in othe words this is the order. Platen, paper, correction tape, correctable film ribbon, printwheel. Also make sure correction tape is dull side toward paper. Shinny side should face operator...
Correction Tape
Two possibilities, one the correction tape is twisted and the wrong side is .facing the paper. The shinny side should be facing you, the dull side facing the paper. Second possibility you must make sure the ribbon is compatible with the correction tape. There are 2 types of ribbons. A correctable one (orange or yellow knob) and a multi strike (blue or purple knob on ribbon cartridge). The lift off correction tape (orange or yellow spools) only works with the correctable ribbon and the cover up correction tape (blue) works with the multistrike ribbon.
Jul 17, 2008 | Brother ML-100 Typewriter
Correct key
Jul 07, 2008 | Brother ML-100 Typewriter
Brady GlobalMark MultiColor (76800) Label Printer Logo
56 people viewed this question
Top Brady Office Equipment & Supplies Experts
pkwc
Bob Rambo
Level 1 Expert
The Vanguardian
The Vanguardian
Are you a Brady Office Equipment and Supply Expert? Answer questions, earn points and help others
