Question about 2003 Dodge Ram - 3500, 4WD, 5.9L Cummins, with single rear wheels - Complete Lift Kit
What is the problem
Dually ram 3500 5.9 making clanking noise blowing smoke when i give it fuel
    Problem Solver:
  • 16 Answers
Rings are burnt
Posted on Feb 12, 2015
04 dodge ram 3500 diesel with turbo blowing smoke from vaule cover breather and tail pipe plus lack of power
Could be head gasket, piston, or other nasty issue. Smoke isn't a good sign. Run a compression check, that may help indicate where the problem is.
Nov 02, 2014 | 2004 Dodge Ram 3500
2003 dodge making clanking noise and blowing smoke when i give it fuel
Hello. Sorry to hear. If it's blowing smoke, then the piston rings are blown. If it's making hard loud thumping noise from the engine, it could be a blown piston. If the truck is in good working condition, save it and rebuild the motor or replace the motor. Good Luck.
May 14, 2014 | 2003 Dodge Ram - 3500, 4WD, 5.9L Cummins,...
How to install a condenser on a '06 dodge 3500 dually?
need to take the raidstor out its the the silver one att to it
Oct 24, 2012 | Dual 03-09 Dodge Ram Quab Cab 2500 3500...
How many fuel filters does a 2004 dodge dually have and where?
A 2004 dodge daully, What model, is it a 2500 or 3500 ? i will also know need to what size engine is in this truck? the last thing is i need to know if this is a gas or diesel and does it have one or two fuel tanks.
Good day
Apr 29, 2012 | 2004 Dodge Ram 3500 Truck
I have a 1997, 1 ton, 3500 dodge dually.
what does the exhaust smell like? if it has a sweet smell to it check your head gasket, and head. there does not have to be oil in the coolant to have a bad head gasket. if there is a heavy engine oil smell, check to see if your turbo is bad. if it smells like raw fuel you either have an injection system or compression problem
Apr 24, 2012 | 1997 Dodge Ram 3500 Club Cab
To replace the rear fender on my 2005 Dually, how
they bolt on through the bed which is a hard one to change for most
Feb 05, 2010 | 2005 Dodge Ram 3500
I have a 2003 3500 Dodge Dually that blows heat thru a/c vents only. Defrost wont work at all.Any suggestions...
you probably have a bad vacuum switch, a broken or loose vacuum line. The problem is finding it, it's buried under the dash.
Nov 14, 2009 | 2004 Dodge Ram 3500 Truck
Serious understeer with 96 Dodge Ram 3500 Dually
Are the tie rod ends tight? Is the trac bar (frame end) tight? The steering boxes on these trucks require more input that a 1/2 ton truck or a car. How is the alignment? The caster on these should be set to about 5 degrees, the original specs allow a lot of wandering.
Apr 05, 2009 | 1996 Dodge Ram 3500 Club Cab
2003 Dodge Ram - 3500, 4WD, 5.9L Cummins, with single rear wheels - Complete Lift Kit Logo
62 people viewed this question
Top Rancho Vehicle Parts & Accessories Experts
Jesse Garcia
Level 1 Expert
Richard Warren
Richard Warren
Timllfixit
Are you a Rancho Vehicle Part and Accessory Expert? Answer questions, earn points and help others
