Question about 2003 Dodge Ram - 3500, 4WD, 5.9L Cummins, with single rear wheels - Complete Lift Kit
2003 dodge making clanking noise and blowing smoke when i give it fuel
    Sergeant:
  • 181 Answers
Hello. Sorry to hear. If it's blowing smoke, then the piston rings are blown. If it's making hard loud thumping noise from the engine, it could be a blown piston. If the truck is in good working condition, save it and rebuild the motor or replace the motor. Good Luck.
Posted on May 14, 2014
3.9 ltr V-6 running very rich, acts like it is choking out when trying to accelerate and blows black smoke. Is this a fuel problem?
Yes, the engine is being overfuled if blowing black smoke. Possible internal leak of fuel pressure regulator. Possible sticking/stuck EGR valve. Possible computer supplying more fuel due to a sensor supplying false information. A scan tool will be required to determine if one or more sensors is supplying erratic info
Jan 04, 2016 | 1989 Dodge Dakota 2WD
92 Dodge Dakota V6 dies randomly. Why?
hope that it isn't the head gasket (white smoke from oil or water ending up in cylinders?)-check water for bubling, and oil spending perhaps, could maybe be faulty lambda probe(exhaust)/air mass probe(intake) or broken exhaust/intake gasket causing wrong mixture(more fuel) - the car can spend much more fuel as normal, can also be the spark timing too late maybe.high pitch mechanical clanking at higher rpm can be heard from the valves - perhaps timing belt?. if it is some kind of electrical fail you are lucky :)
May 02, 2014 | 1992 Dodge Dakota
No power in engine, and a clanking noise from the bottom of the truck. I changed the plugs, Fuel pressure regulator, and air filter. Coils are good.
is the clanking noise connecting rod bearings,crank bearings,piston noise.is it a metallic noise you don`t say in your question.these can cause no power.what is the fuel pressure reading.need more description of noise.
Jul 30, 2011 | 2003 GMC Yukon XL
My 2003 duramax is nocking blowing black smoke
WELL BLACK SMOKE AND KNOCKING CAN BE CAUSE BY RESTRICTED AIR FILTER FAULTY .INJECTION PUMP IT HAS INTERNAL FAILURE OR INJECTION PUMP TIMING OFF.USE A MECHANIC STETHOSCOPE SAME THING DOCTOR USE BUT IT HAS A LONG PROBE PICKS SOUNDS YOU CAN HEAR ENGINE NOISES.FAULTY VALVES AND FAULTY FUEL INJECTORS.YOU CAN GO TO SEARS BUY ONE.PLACE IT NEAR YOUR DIESEL INJECTION PUMP WHILE ENGINE RUNNING IF PUMP FAULTY YOU CAN HEAR IT USING A STETHOSCOPE.
Oct 22, 2010 | 2003 Chevrolet Silverado 2500HD
Losing power, blowing black smoke and stals
my 2003 f350 6.0 started to have turbo lag when in a strain and i can give it more fuel and it will blow out alot of black smoke and it clears up does anyon have any sugestions on what it could be
Apr 27, 2010 | 2003 Ford F350 Super Duty DRW SuperCab
2003 chevy impala makes clicking noise/smoking thru exhaust
the clicking noise could be eiter a valve or piston. the smoke out of the exhaust means different things depending on the color and how much smoke. Check your air filter and make sure oil is not backing up into it. Also, it may be a good ideal to go ahead and change the oil even though you arent at 3000 miles, unless you just changed it. Change the PCV valve also, if itis clogged it will give you problems. Has the check engine light come on?
Nov 11, 2009 | 2003 Chevrolet Impala
Noise and vibration
check the cv joints in the axles
Jul 02, 2008 | 2003 Dodge Neon
2003 Dodge Ram - 3500, 4WD, 5.9L Cummins, with single rear wheels - Complete Lift Kit Logo
81 people viewed this question
Top Rancho Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Rancho Vehicle Part and Accessory Expert? Answer questions, earn points and help others
