Question about Vehicle Parts & Accessories
2002 Saturn 5 speed
Will not go in reverse so we are replacing the cables first
    Sergeant:
  • 181 Answers
Hello. If the cable is loose, adjust it first. If the cable is tight, leave it alone. If the cable looks bad, then replace it. But, it could be the clutch it self getting to be bad. You also can try to adjust the clutch itself. If you are still having problems shifting into reverse, then you need to replace the clutch it self. Good Luck.
Posted on May 14, 2014
My 2002 saturn sl 5 speed sedan loses powered drving up hill on 4&5 gear ??
Fuel filter may need replaced. Partially clogged causing low fuel feed under power
Aug 10, 2014 | 2002 Saturn Sl
Is it possible to replace the output shaft bearings on a 2002 saturn sl2 5 speed without removing the trans?
No. Everything is done from the inside of the trans. If you need instructions for removal, let me know.
Apr 15, 2010 | 2002 Saturn Sl
`02 saturn sl 5 spd: grinds 2nd gear
well it got stuck originally right??might be time for a rebuild the cable does need the right amount of tension to push and pull,the linkage may need proper adjusting as well
Nov 24, 2009 | 2002 Saturn Sl
Gear Shift very stiff, doesnt want to go into 1st gear or reverse
Continued operation like this and $100 would have been the cheap fix. If this is a hydraulic clutch, check the fluid level in the clutch master cylinder. Most take Dot 3 brake fluid and it will say on the cap. It is located on the fire wall near brake master cylinder
Nov 13, 2009 | 2002 Saturn L-Series
1999 saturn sl2 5 speed transmission will not go into reverse 2nd gear sometimes will not engage is there a linkage adjustment.
There is no 'adjustment' but you can check your linkage for security making sure nothing is loose or worn. Also check your fluid levels. If reverse is completely out and your starting to lose second you will probably need to have the transmission rebuilt or replaced.
Nov 03, 2009 | 1999 Saturn SL
I have a 2002 saturn sl2 that the backup lights dont work when i put it into reverse. now i have checked all the fuses under the hood and under the dash , is there any possibility that there are other...
if its 5 speed trans,try replacing the reverse light switch on the trans,it is located on top of the trans under the battery,,like $16 part,they go bad alot
Oct 26, 2009 | 2002 Saturn L-Series
2002 Saturn SL1 - Losing reverse and second gear
The simple answer is that there are two loose nuts in the transmission.
The output shaft nuts are loose. The are behind a cover that you can see through the driver's side wheel well.
Jul 04, 2009 | 2002 Saturn L-Series
Saturn shifter linkage
Check the cable clips at the trans. Sometimes these clips come out and won't shift. Horseshoe clips that hold the cable housing.
Dec 21, 2008 | 2002 Saturn VUE
2004 Saturn Vue shifting problem
You should probably check the shifter cable. I had the same thing happen and then I couldn't shift into 2nd, 4th, and reverse gears. Then the cable snapped and I had to replace it. Be careful "man-handling" the shifter. If you break the shift linkage at the base of the shifter it's about $45 from the dealership. It's cheap plastic and doesn't take much to break. If you really want to know if it's the shift cable and not the gearbox crank the engine, have someone hold the clutch, disconnect the shift cables from the box, and manually shift the gears. If they move smooth, it's probably your cable which would mean there's a kink in it somewhere. You can't fix that. Depending on the VIN you're looking at anywhere from $189 (what mine cost with tax) to a little over $200 (from the dealership brand new). Talk to the parts desk at a Saturn dealership and they can tell you which one you need. Hope this helps
Jul 31, 2008 | 2004 Saturn VUE
Vehicle Parts & Accessories Logo
62 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
