Question about Troy-Bilt Troybilt Mtd Mini Tiller Cultivator Clutch Assem See Model
What can cause my Troybilt TB146ec not to spark?
It kept cutting out. I found the lead wire was frayed and broken so I replaced it. Now I don't get a spark at all.
  • 1 more comment
  • Joel Friedenberg May 14, 2014
    Hi Alex kalanihuia, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?I'm not sure what you mean by the "lead wire". Con you explain please- is that the spark plug wire??
  • Alex kalanihuia
    Alex kalanihuia May 14, 2014
    Sorry. Their parts list call it a lead wire. It runs from the cut-off switch to a couple of connectors on the engines. I reversed them on the engine to be sure that I hadn't mistakenly crossed the wires, but still got no spark. Spark plug wasn't changed because they rarely give out nowadays in my opinion.
  • Alex kalanihuia
    Alex kalanihuia May 16, 2014
    Sorry again. The Lead Wire connector's I reversed were at the cutoff switch, not the engine connectors.
My fuse keeps blowing on the fuelpump of a Lincoln ls 2001 do I need a new fuel pump
Probably. The fuel pump is really easy to do on an LS. Just remove the rear seat and make sure to keep spark or heat sources away. DO THE FUEL FILTER too. don-ohio
Mar 24, 2017 | 2001 Lincoln LS
What are the most common causes for power windows and side mirrors not working on a 99 intrepid? I checked appropriate fuses and they're all working.
Check for broken wiring between the drivers door where the wiring comes out and enters the vehicle. Usually covered in a rubber boot. Cut/slide boot from door and inspect wiring for broken/frayed wires
May 15, 2015 | Cars & Trucks
Artic cat 2003 mountian cat 800
Assuming all wire harnesses are stock and loomed from the factory it sounds like a frayed power wire making contact to your frame somewhere. Chasing wiring is never fun. Start from the headlamp bucket and work through them looking for fray or broken wire loom. Could be a lead touching the frame or ground wire connection somewhere in its path. Sometimes its as easy as within the headlight bucket itself. Goodluck
Dec 18, 2013 | Suzuki Motorcycles
Hi, I have the Hoover d14194 bagless pet vacuum..when I switched it on it worked but kept cutting out, I emptied it and cleaned the filters but now it won't even switch on.is there something I can
You could check the motor brushes, if they are worn and check for loose wire connections.
Another possibility is that there may be a break in the lead, plug it in and shake the lead, if it starts and stops you have probably found your problem with a broken lead.
Jan 01, 2013 | Vacuums
My ryobi 350 cfm 180 mph gas backpack blower just stop andwont start again and my brother in-law said my mixture of gas to oil is not correct,less oil was mix how can i remedy the problem.
PROBLEM Engine fails to start. CAUSE - REMEDY No fuel in tank - Fill tank. Spark plug shorted or fouled - Replace spark plug. Spark plug is broken. (cracked porcelain or electrodes broken) - Replace spark plug. Ignition lead wire shorted, broken, or disconnected from spark plug - Replace lead wire or attach to spark plug. Ignition inoperative - Contact authorized service center.
Aug 21, 2011 | Ryobi Garden
Truck cuts off while driving. I replaced the fuel pump a few months ago. if i wiggle the wire harness it will restart
I have seen this and took me a long time to figure it out. The problem I have found was inside the plug on the wiring harness to the fuel pump. You can't see it unless you take the plug apart and it may be corroded inside. I don't know if this is your problem but check to see if you have power there and wiggle the wiring to see if it cuts out. Hope this helps.
Jun 12, 2011 | 2001 Chevrolet Silverado 1500
Spark plug wire will not stay on
just an idea is there a lot of vibration on the cutting head as this can cause the problem or you might just have to replace the HT lead for a slightly longer one.
Jul 11, 2010 | Yard Machines 11A54MC006 21Inch 139cc MTD...
My aprilia rs125 2007 jus cut out on me and wont fire up again
  • Start with a new spark plug. Now do you see spark? If not, check the side stand kill switch. It kills the engine so that you don’t start out with the side stand down. If broken or out of adjustment, it would kill the spark. Check for a broken wire at the side stand switch and coupler. Try moving the kill switch by hand. If that doesn’t work then wire a jumper around the switch to bypass it.
  • Check the fuses. How good is the battery? Try a jump start from your car battery. Is the handlebar kill switch on?
  • Check the operation of the ignition switch and all kill switches with a volt ohmmeter. Check the wiring harness. Did a wire come unplugged? Are all wires clean and with solid connections? Any abraded or pinched wires? Is the bike in neutral and the neutral light is lit up? If no neutral light, check the neutral switch and neutral switch wire on center casing. If still no spark, get CDI system and coils checked at the dealers shop.
  • Are the fuses good?
Can I get a “very helpful” rating on this answer? Thanks!
Aug 03, 2009 | 2007 Aprilia RS 125
I can NOT GET SPARK AT THE SPARK PLUGS,AND I REPLACE,CRANK SENSOR.CAM SENSOR,COIL PACK,AND LAST i REPLACE THE MAIN COMPUTER AND STILL NO SPARK .IT IS A 2000 LANOS 1.6 L STICK.
looks like you got one of them right you changed most of the things that cause loss of spark so lets try the simpler things are all the items you have replaced a proper grounding just test with a muti meter you havn,t by any chance got a alarm with cut outs on it then check all your connectors carefully exam the pins have not been bent and are not connecting properly also check the wiring loom on the engine for signs of being rubbed through yates210456
Sep 28, 2008 | 2000 Daewoo Lanos
MDR-7506
On my MDR-7506, there are 4 screws, not one. Slip the ear pads off (they should pull off intact; don't worry) and the screws should be visible on the face of the driver housing. Remove the screws and you'll gain access to the wiring behind the drivers. You'll see the right side driver's 2 wires attached to the back of the left driver. I believe the ground wire is gold and the signal wire is red. In my case, my right driver is the one that's gone silent on me, and the culprit appears to be a frayed ground wire over on the left side. It's frayed right where the 'bare' (micro-insulated) wire leading from the left driver enters the protective black tubing that leads to the right. There might be just enough slack to cut and resolder it, but there's no margin for error. Does anybody have tips for working with these very fine wires?
A service "manual" (really more of a parts list / exploded view) is here (for now).
Jun 11, 2007 | Sony MDR-7506 Professional Headphones
Troy-Bilt Troybilt Mtd Mini Tiller Cultivator Clutch Assem See Model Logo
53 people viewed this question
Top Troy-Bilt Heavy Machinery Experts
Mike
itsman
ray gallant
Are you a Troy-Bilt Heavy Machinery Expert? Answer questions, earn points and help others
