Question about Kitchen Appliances - Others
Why rational oven giving some knocking sound frequently, it seems like something is blocking
I need to know my rational oven giving some knocking sound freqently. If i m using steam its running good.
2 Suggested Answers
  • 97 Answers
SOURCE: just stopped steaming. something must be blocked.
add vinegar and let soak over-nite, think of it as cleaning out your iron.thanks
Posted on Nov 30, 2009
I have rational CM61 E ,display showing error E12, if know this anyone pl. share this
Hi, error 12 is displayed when the oven pcb is too hot, check that the air filter is clear and the cooling fan is running. Also it could just be the software, if it is an older oven and has the original software then it may just need upgrading by someone who knows what he/she is doing.
Jan 05, 2014 | Combi Ovens
Rational combi oven
Any wires out the back that are loose?
Jul 04, 2013 | Kitchen Appliances - Others
I purchased a 2007 Aura XR. 3.6 L a month ago. The car only has 23,000 miles on it. I've been noticing a weird knock noise in the rear of the car while sitting stationary in park or in drive. It's...
I have a 2007 Saturn Aura with 3.6 L engine. Had it since new (now at 55,000mi) Here is what I found that may be what you are experiencing. Particularly in cold weather, after about 5 minutes of running a sharp "pop" occurs. Usually I just have one loud pop. I believe this is something in the exhaust system that expands and pops much like a cookie sheet put into the oven. As best I can tell, this is a harmless noise. As the car has gotten older it does this less frequently.
Dave K.
Dec 12, 2011 | 2007 Saturn Aura XR Sedan
My rational selfcooking center says service34-2- no function please help
You really need a specialist repairer to resolve this but this generally relates to a main fan motor defect or a failure elsewhere in the bus circuit.
Sep 03, 2011 | Ovens
1999 suburban , seems that the crank is knocking hard. was going to purchase a crank and rebuild. what do you think?
It's proably a rod not the crank a crank noise would thump and be noisey on initial start up. a knocking or rattle is the connecting rod. I would get a price for a short block from jasper engines and not mess around if u havent done something like this before. You have to pull the engine and it's alot of knowing what your doing from there. Jasper offers a 3yr 100.000 mile warrantee if you want to keep the truck give em a call otherwise Call yr local boneyard for a low mile used engine but then again buyer beware.
Nov 03, 2010 | 1996 GMC Suburban
05 Dodge Magnum new long block
Might be a bad mass air flow sensor. Need a little more info. I am a crysler master tech so give a bit more info,plz
Jun 20, 2009 | 2005 Dodge Magnum
2001 hyundai elantra knock sensor
yes sir, the knock sensor is located on the side of the engine block, the side closest to the firewall. it is just a small circular object with a wire connector and one bolt
Aug 07, 2008 | 2001 Hyundai Elantra
I own a mercedes 190e 2.5 16v cosworth 1990 model I have noticed that it has developed a knocking sound rather like a grandfather clock. This seems to come from the fuel tank and might be something to with...
You may want to check first if the knocking sound proportionately increases speed or decreases with engine RPM. If it does, that should tell a clue as to where to look for the sound. Could be mechanical. I suggest to isolate the problem first, when it occurs, conditions present when it does etc...
Jul 15, 2008 | 1984 Mercedes-Benz 190
Need help with re-installation
ovens don't usually come with a cord. check handbook for cable size and you should find a connection block behind a plate at back. just connect to outlet making sure you get connections correct - they are usually identified on terminal block
Jun 04, 2007 | Electrolux EOC6630 Pyrolytic Electric...
Kitchen Appliances - Others Logo
49 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
