Question about Sony Audio Players & Recorders
What do the flashing lights mean on my slendertone gymbody plus?
Blue light on panel, what does it mean?
a steady blue light means all systems are a go. if it flashes that is a flash code saying something is wrong. Refer to the manual for code meaning Scooter Doctor App
Jul 01, 2014 | Pride Go-Go Elite Traveller Plus HD...
Slendertone will not switch on
The replacement batteries could be defective or installed incorrectly. Also, the switch may have failed.
Apr 01, 2014 | Slendertone System Abs
Constant flashing blue light
The flashing blue light means the Bluetooth is connectedconnected, device is on.
Jan 31, 2014 | Hmdx Hx-p240gy Jam Plus Portable Speaker,...
Error e002 slendertone flex belt
Dear Karen! I have the same problem white my slendertone e002 error,if you deal whit it,please helm me!
Oct 24, 2012 | Slendertone Abdominal Muscle Toner
My slendertone wont turn on. it did and i turned it off!! and when i went to turn it back on it wouldnt turn back on and i have changed the baterys!!!
I've had the exact same problem! I turned it on, and the lights went on then I looked at the next step in the manual and thirty seconds later max when I looked at the belt it had turned off! And now it won't turn on again! I've changed tha batteries and it still won't work! Please let me know if you find a solution!
Aug 13, 2011 | Slendertone Fortex
Bought Slendertone Start but lost instructions so dont how to use.Would like the instructions for slendertone start
Manuals for the various Slendertone products can be found here:
https://www.slendertoneusa.com/t-manuals.aspx
There does not seem to be a manual specifically designated for 'Slendertone Start'; is that a specific product or a program for using one or more of the Sendertone products?
May 21, 2011 | Health & Beauty
How do you work the Slendertone Belt? I lost the
hold it in front of you comfortably and pull outward (its pretty straight forward)
Jan 13, 2010 | Slendertone Fortex
I have a Brother 2170w with all lights flashing. Turning on and off does not fix problem. Help!
This is in reference to another solution on this site--please search before posting as others have already solved this problem:
Per http://www.fixya.com/support/t2462964-all_3_error_lights_flashing_4_count_go
When all lights flash it's a service problem. You press and hold the go button and see what lights are on then.error light means main PCB failure, Toner light means fuser failure, drum light means laser failure. Toner and error light means main motor error, drum plus error light means its a fan failure.
Jul 09, 2009 | Brother HL-2040 Laser Printer
All 3 Error lights are flashing (4 if you count the GO button)!!
Jun 26, 2009 | Brother HL-2170W Laser Printer
59 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
