HOW MUCH IS A BUSH wm-1270 tve washing machine
2 Suggested Answers
SOURCE: I have a BUSH WM
i have removed the transport brackets cant findthe rubber ones machine shake around checked level
Posted on May 28, 2011
Bush WM-1260TVEME wash on a cotton wash when i heard noises that sounded like a firework been lit i turned round and orange sparks were coming out of top of display panel.i havent used it since this as...
first unplug the machine if you haven't already-if your machine is less than a year old you should be under warranty-call the company that you bought it from-cheers Denny
Oct 22, 2013 | Washing Machines
Bush WM-1270 TVE error 2
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jan 24, 2013 | Washing Machines
Cant get Bush WM-1260TVEME washing machine to start a cycle off the button
Check to see if the power is getting to the machine. If it ismake sure the door is closed firmly, there is a safety switch on the door. If none of these things work, you have adoor switch problem or a panel fuse out or a broken panel circuit. If you have the skills to open and troubleshoot than those are the things to look for.
Jan 02, 2013 | Washing Machines
Hi my bush WM-1460TVE has been stuck on the same cycle 3.00 minutes for the past half hour it just goes round and round and is full of water still? Help?
Problem with the program controller unit. Remove the plug and power for some time and try again. If this wont work it is possible that unit has failed.
Jun 26, 2012 | LG Washing Machines
My washing machine is flashing err2 and is not spinning. I have lots of clothes locked in a machine full of water! Help! wm-1460tve bush washing machine
sounds like either the pump is blocked or broken.
bring machine forward so that you can tilt it back so as to be able to undo filter cover.
Be aware, lots (and i mean lots) of water will exit so a) have a big bowl and b) only undo filter cover a little so can retighten quickly.
Repeat until all water gone, remove cover completely and clean pump and filter area.
Refit cover, put machine back on floor, put on spin cycle and if it was a blockage, machine should empty. If not, new pump time I'm afraid
Dec 08, 2010 | Washing Machines
I BROUGHT A BUSH WASHING MACHINE WM-1470TVE HAD IT 2 DAYS AND KEEPS COMING UP WITH Err5
Hi.
Err 5 is water inlet problem.
Move the appliance, ensure that the water hose is not kinked or blocked, and check filter in water hose if installed.
Check connected faucet and water pressure.
If the inlet hose and pressure is OK, then the inlet valve and water level switch must be tested as one of the two parts is likely giving the error.
Regards.
Ginko.
Oct 29, 2010 | Washing Machines
What does error 5 mean on the bush wm-1260tve washing machine?
Hi.
Error 5 means that there is a water inlet problem.
If the inlet hose and pressure is OK, then the inlet valve and water pressure switch must be tested as one of the two parts is likely giving the error.
Regards.
Ginko.
Sep 20, 2010 | Washing Machines
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
