Question about HP LaserJet 4 plus Printer
Hp p3005n trouble
Repetitive black marks on part
    Novelist:
    Scholar:
  • 80 Answers
Repetitive flaws in the printout can indicate problems with the fusing assembly, charging roller, image drum, paper feed rollers, or other parts. The key is to measure how far apart each print defect is as measured from the top of the page to the bottom. For example, if the distance between the first defect and the next is 3.75 inches, the problem is the image drum. You can find a list of the measurements at:
HP Support document HP Support Center
Posted on Aug 21, 2014
2 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: hp p3005n printer trouble
Make sure there is not another piece of small paper already in the unit.
if no paper then
try replace toner
if that doesn't then your rollers need to be replaced.
Posted on Dec 13, 2007
Bad printing , black marks
If the marks are repetitive down the page, see my tip. It will help you to narrow down the cause. Typically the two most common causes of black marks are a bad cartridge or a bad fuser. If the marks only happen during copying then it is likely dirt on the scanner.
Jun 08, 2011 | HP LaserJet 3330 All-In-One Printer
Please describe your hp laserjet p3005n leaving black marks problem even after a new cartrigde was installed. What can I do?
Open your printer fuser Assembly Then Clean Tefflon Sleeve Then Clean With Thiner And then Check
Feb 06, 2011 | Office Equipment & Supplies
Issues with HP Laserjet P3005n
That means that the output tray is filled to capacity, or one of the students broke the "bin full flag" at the top of the printer.
Feb 24, 2010 | HP Hewlett Packard LaserJet P3005n Printer
HP Laserjet P3005N not recognized
http://www.hp.com/cpso-support-new/SDD/main.htm?cc=us&lang=en
This is HP's driver checker,it will check your system and make sure the correct driver is installed.
Jan 08, 2010 | HP LaserJet P3005n Printer
HP laserjet P3005n. Cannot get jobs to print from bypass tray (1)
It could be a flag issue or sensor issue but, you should always try the easy stuff first. Check to see if the manual feed is on. To do this:
Press the check mark and arrow down to configuration menu
Press the check mark and arrow down to printing menu
Press the check mark and arrow down to manual feed, highligt the on and press the check mark.
In this setting the paper (if present) should pull from tray 1 first.
Let me know if this resolved the issue, if not, we can try another test.
Dec 14, 2009 | HP LaserJet P3005n Printer
New HP LaserJet P3005n printer and cannot openthe
Push the plate down with anything you can get into the small opening that it will allow you to get into. When you can latch the plate down, it will open. When you do get it down, toss the middle spring, along with the black plastic thing on top. It is the cause of a lot of stress and not needed.
Oct 28, 2009 | HP LaserJet P3005n Printer
HP P3005N printing from Tray 1 and not Tray 2. Paper is in TRAY 2 but still gives message to use Tray 1. Only way to use the printer is to use Tray 1 at this time.
Do a cold reset and the paper trays will reset themselves, it's the easiest way. Turn printer off, turn the printer back on and as soon as you see the memory starting to count push the check mark button and HOLD IT until you see all the lights stay on. When they stay on, and you see "select language", push the arrow button until you see "cold reset", and push the check mark button again. You will be all set.
Jul 13, 2009 | HP LaserJet P3005n Printer
Hp p3005n printer trouble
if no paper then
try replace toner
Dec 13, 2007 | HP LaserJet P3005n Printer
HP LaserJet 4 plus Printer Logo
Seeker5211
Seeker5211
