Question about CRL 2002-2008 Dodge 1500 Ram, 2003-2008 All Ram Cabs, and 2007 Sterling Bullet "Perfect Fit" POWR-Slider - Solar Glass
How to fix body control module in 2007 dodge ram 1500
When turning off truck and take key out of ignition, clock radio stays on with the odometer, & power windows continue to work after opening the driver door
    Champion:
  • 218 Answers
Sounds like the switch or a relay. Try disconnecting the neg battery cable and leave off for a couple of minutes, allowing the computer to reset. Reattach battery cable and see if it works ok. If so, Relay is the cheapest fix so I think I'd try that next.
Posted on May 16, 2014
MY RADIO STAYS ON WHEN I REMOVE THE KEY and close the door
radio stays on after removing key from ignition - Car Talk
community.cartalk.com/.../radio-stays-on-after-removing-key-from-ignit...
Mar 4, 2012 - this just started today and when i turned off my car and removed the keyfrom the ignition, the radio stayed on.
04 F150 - Radio stays on after key removed & door open ...
www.f150online.com/.../323659-04-f150-radio-stays-after-key-removed...
Mar 2, 2008 - You know how you can take the key out of the ignition (after turning off), and radio continues until you open the door? Well, yesterday I opened ... More results from www.f150online.com
Oct 22, 2015 | Chevrolet Astro Cars & Trucks
Radio stays on after exiting vehicle
It sounds to me that there is a short in the ignition switch, since the ignition switch is responsible for the power supply for all those functions. Why didn't the dealer check that?
Dec 25, 2014 | 2004 Dodge Durango
2004 fx4 f 150 just got through disabling door ajar and seatbelt chime now odometer don't work and the radio stays on with the key out of the ignition
somehow I was the annoynmess person with the question about the door ajar and a seatbelt alarm that we disabled, and odometer quitting the radio stayed on well it was just a plug and the odometer speedometer all that works now, but the radio still stay on with a key out of ignition, and now the AC don't cool
May 31, 2014 | 2004 Ford F150
Remove ignition switch
Hi. Some cars do leave the display for the clock and odo on. Perhaps you only just noticed. If not then check if the radio switches off when removing the key. If it does, then all is normal. If not then you have a problem wiyh the key insertion switch in the ignition switch.
Feb 04, 2014 | Volkswagen Cars & Trucks
Hyundai i30 2013 model. Can not turn the radio / clock off. No key in ignition but radio continues to play. Turn the radio off (push button) and the digital clock displays. Worried about flat battery.
does it stay on even after the door has been opened? If so it is the retained accessory power system and it should shut off after the drivers door is opened. If not look in your owners manual or take it back to the dealer service center for correction.
Dec 24, 2013 | Cars & Trucks
The clock radio stays on with the ignition key turned off
reroute the power wire to a switched power source from the fuse block
Dec 18, 2013 | BMW X5 Series Cars & Trucks
Everything remains on with keys out
Everything as in the engine continues to run, the radio stays on, the power windows continue to work, etc? What happens when you open the drivers front door? Does everything turn off? If not does the dome light work when the drivers front door is open? If it does not than the drivers front door switch might be the issue.
Sep 08, 2013 | 2003 GMC Yukon
2006 FORD FREESTAR VAN THE RADIO CONTINUE TO PLAY AFTER THE VAN IS TURNED OFF AND THE KEY IS REMOVED. ALSO THE CLOCK CONTINUES TO DISPLAY WITH THE KEY REMOVED
This is normal until you open a door. It will stay on for about twenty minutes as long as no doors are opened.
Mar 24, 2009 | 2006 Ford Freestar
Radio won't turn off.
The radio should still shut off after 20 minutes even if the door is not opened. If it stays on longer than this there is still a problem..
Jan 25, 2009 | 2003 Oldsmobile Alero
Gauges, Power Windows, Auto Lamps radio interior lights dont work
Sounds like an ignition switch problem, maybe even at the key.
Jan 09, 2009 | 2002 Ford F350 Super Duty DRW Reg. Cab
CRL 2002-2008 Dodge 1500 Ram, 2003-2008 All Ram Cabs, and 2007 Sterling Bullet "Perfect Fit" POWR-Slider - Solar Glass Logo
259 people viewed this question
Top Cr Laurence Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Cr Laurence Vehicle Part and Accessory Expert? Answer questions, earn points and help others
