Question about Laguna Pressure Flo Uvc Filter 11w Replacement Bulb (Pf700 and 1400)
How do you change the mode selector switch on a laguna pf700 ?
How can I change the mode selector switch on a laguna pf700?
Submersible pump has broken power cord. can it be fixed? pump quiet one 2200 submersible pump sp33 was being used with laguna pf700 filter system
Interesting question. Yes. Purchase a replacement cord. If you are not comfortable doing that contact your electricion.
Sep 13, 2013 | Plumbing
Su-c800u pre-amp switching not steady, keep darting from one mode to another and disrupting smooth flow of music
I had the same issue.the contacts on selector switch is dirty.All u need to get a good contact cleaner and spray the selector rod( remove knob first with preamp facing up), the liguid will find leak into selector and clean contacts.
after doing mine, the slector knob feels more solid when turned and does not change input anymore.
Junior
Jan 14, 2012 | Technics Audio Players & Recorders
MY DISTRABUTION DIAL FOR DEF.,VENT, ETC IS IN DEFROST AND WON'T CHANGE. THE DIAL TURNS BUT NOTHING CHANGES. I NEEN SOME ADVICE ON WHAT TO DO TO FIND PROBLEM AND FIX. THANKS GENO
Here is the info. I hope the pictures show up. please rate assistance. thx.
Air distribution within the vehicle is determined by the function selector switch position. Two airflow mode doors are used to direct airflow within the heater core and evaporator core housing. The function selector switch/cable assembly is used to position these airflow mode doors. Refer to Section 412-00 for description and operation of each of the system functions.
Function Selector Cable Assembly
The function selector cable assembly moves the airflow mode doors to the desired position using a 2-sided pull-pull type cable assembly. The function selector controls the cable movement. The end of the cable assembly attaches to the airflow mode door/temperature blend door actuating assembly which transfers the cable movement to the 2 airflow mode doors.
An electrical switch is incorporated into the function selector to notify the A/C switch assembly if DEFROST or FLOOR/DEFROST is selected. When DEFROST or FLOOR/DEFROST is selected, the A/C switch assembly will disable the RECIRC request button and send an A/C request to the powertrain control module (PCM) regardless of the A/C request button indicator ON/OFF status.
SECTION 412-01: Climate Control 2005 Focus Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 02/25/2004
Function Selector Switch adobe.gif Printable View (173 KB) Removal and Installation
  1. Remove the 4 bolts and position aside the lower steering column cover.
  1. Remove the function selector knob.
  1. Remove the center instrument panel finish panel.
    • Disconnect the cigar lighter electrical connector.
  1. Detach the function selector switch.
    1. Disconnect the electrical connector.
    1. Remove the screw and detach the function selector switch.
  1. Detach the function selector cable and remove the function selector switch/cable assembly.
  1. To install, reverse the removal procedure.
Aug 04, 2011 | 2005 Ford Focus
Do you carry uv-c t5 11w if so how much
It cost 12 dollars at the link below...
http://www.lightbulbsurplus.com/index.php?main_page=product_info&cPath=622_128_133&products_id=256
Mar 21, 2011 | Laguna Pressure Flo Uvc Filter 11w...
After taken photos the image out of focus
On the front of the camera body, below the lens release button you should find a two position switch labeled "AF" & "M" This is the "Auto Focus - Manual" selector switch. Make sure the selector is set to "AF" for auto focusing.
Your lens may have a similar focus selector switch on its barrel. There are two types of switches used - depending on the lens. The first is labeled "M/A" and "M" The "M/A" position indicates it is in "Auto Focus" mode with a "Manual" focus over ride capability. You can simply twist the focus ring to change the focus to a point other than that chosen by the camera's auto focus system. The "M" position is Manual Focus mode. No focusing operations will be performed by the D80 auto focus system - focusing must be done by the photographer.
The second type has "A" & "M" positions. These represent Auto and Manual focus. The difference between this type switch and the "A/M & "M" switch is that when in "A", the camera will no allow the focus to be changed manually. There will be opposition to twisting the focus ring in the position. Forcing it will likely result in damage. The selector switch must be changed to "M" to change the focus.
If either switch is set to manual, the auto focus system will be disabled, so it is very important to have them both set to "A" or "A/M".
I hope this helps. Please rate my reply - thanks!
Jan 04, 2011 | Nikon D80 Digital Camera with 18-135mm...
New uva light not working, have been told about a reset button but unable to find it
On the bottom of the UV head where you just replaced the bulb. There are 3 screw holes and a 4th hole with the button in it.
May 10, 2010 | Laguna Pressure Flo Uvc Filter 11w...
My camera is set on lock, how do I unlock it (fuji s5200)
Are you pertaining to the Focus mode? If so you can unlock it using the Focus mode selector lock switch. Press the Focus mode selector button to change the focus mode.
S-AF- Single AF
M-F- Manual Focus
C-AF- Continuous Focus
I would like to know more information regarding this matter.
Aug 15, 2009 | Fuji Cameras
How to set alarm and how to turn it off so that it is not used.
To turn on alarm, switch the selector lever to "Wake" and adjust the time shown. Then, switch the lever back to "Lock" and push the "Wake Mode" button until you see the selector dot (located on the bottom right of the time display) change to either the music or bell symbol; depending on how you'd like to be awaken.
To cancel the alarm, simply hit the "Cancel" button once, then press the "Wake Mode" button until the selector dot disappears.
Mar 10, 2009 | GE 7-4837 Clock Radio
Canon eos 400d mode dial does not select modes
Looks like you need to take this to a camera store and have them check it over. I don't know of any setting that would cause what you describe.
Dec 03, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Mode switch is not working
I talked with a repairman via telephone. He suggested I buy a new camera. I thought what the hell, I will take it aprt myself. I took it apart, messed around and figured out how to change the mode to taking pictures. I still can't change modes with the mode selector switch but, I can now take pictures with my camera.
Sep 06, 2008 | Cameras
Laguna Pressure Flo Uvc Filter 11w Replacement Bulb (Pf700 and 1400) Logo
60 people viewed this question
Top Laguna Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Laguna Garden Expert? Answer questions, earn points and help others
