Question about Panasonic Workio DP-1820P Laser Printer
How to get rid of black lines and marks appearing on photocopies
Do I need to clean internally?
  • dijim33 May 14, 2014
    Do you have a manual for the printer? If not try Panasonic's web site and download one if available.
  • 36 Answers
Clean the printer as recommended by Panasonic - if you don't have a manual, you should be able to download it.
Posted on May 14, 2014
Testimonial: "searched for manual,it does not contain cleaning instructions"
Have more lines what I do
More lines when printing or photocopying?? What color lines? For lines when printing, clean charge rollers of the respective PCUs. If not, replace PCU drums. For lines that are appearing only when photocopying, check if the slit glass or flat bed glass have white out liquid correction ink markings on them. If yes, clean them. If not, clean scanner lens and mirrors of the scanner assembly.
Mar 11, 2014 | Ricoh Aficio MP1600SPF Copier
Black line on paper when ever i photocopy any document
clean glass - if only when copy from document feeder, check the narrow glass strip at extreme left side - use alcohol or window cleaner. You can place the paper with mark on glass to locate exact area to check
Oct 31, 2013 | Panasonic DP-8016P Copier
Photocopies are not clear even after increasing image intensity.
if you have over approx. 60-100k copies on the machine it sounds like you may need regular maintaince on the machine.
to check how many copies you have press the user tools/counter button and then press counter.
Jul 13, 2013 | Ricoh Aficio 1045 Black and White Copier
Sharp Al1655cs copier black smudge down center of page about as wide as a pencil
Hi
Sounds like a fusing error . If your able to wipe the toner off the page its a fuser unit problem (replace fuser unit).
Also clean the copier's paper rollers. Marks on copies will occasionally be the result of a dirty paper-rolling mechanism. Simply access these rollers (your photocopier will likely have a plaque or series of signs indicating the locations of these areas) and wipe them off.
Clean the copier bed's glass plate. One of the most common causes of blemishes in photocopies is a dirty glass plate. In some cases a permanent mark, such as a scratch, will be present on the plate, showing up in every copy as a dark line or spot. However, most problems attributed to the glass plate can be fixed by wiping the plate with a soft towel and common household glass cleaner.
Clear any excess toner that has spilled or overflowed in the toner cartridge chamber. Excess toner will almost always result in blemishes on your copies. The most effective means of cleanup is to remove the toner cartridge and set it aside, thoroughly cleaning up any spilled toner in the compartment before putting the cartridge back in place.
Check for low toner levels. Low toner levels can actually contribute to unsightly lines and blotches on a photocopy. Most photocopiers will automatically indicate the need to replace an empty or low toner cartridge; while the toner is low, these models will permit continued copying. Consult your photocopier's instruction manual or key to warning lights and indicators for how to tell if the toner is low or empty.
Aug 03, 2011 | Office Equipment & Supplies
The photocopying using the feeder leaves a black line
There is a separate scanner glass from the flatbed scanner glass.
Without a make/model I cannot tell you exactly how to access it, but once you have uncovered the document feed scanner glass area, the glass will need to be cleaned well, and then you will be able to scan from the feeder without the black line appearing.
Jul 27, 2011 | Office Equipment & Supplies
Black lines on copies and on drum
There are a few things you can do to troubleshoot this problem.
  1. Be sure you are using new, clean paper
  2. Clean the copier's paper rollers, the marks may result from a dirty roller mechanism.
  3. Clean the copier bed's glass plate, smudges manifest themselves in the final copies.
  4. Clear any excess toner that has spilled in the toner cartridge chamber. Remove the cartridge, set it aside, then clean the compartment.
  5. Check for low toner levels. Low toner levels can actually contribute to unsightly lines and blotches on a photocopy
If all else fails, try turning down the darkness of the copies in the settings, this can occasionally lead to lines and marks.
Feb 28, 2011 | Brother MFC-8460N All-In-One Printer
When I photocopy I get a black line down the page, I am using a C
check the drum unit maybe the drum or the cleaning blade is the problem
Jan 04, 2010 | Canon PC-950 Black and White Copier
Lines rule across my print out paper at photocopying mode
Make sure you don't have a scratch on the glass of the scanner. If you have a mark, or scratch that matches the line ruled on your print, then there is your problem.
It;s also possible the scanner is jerking as it goes across the bed, which is causing the line. Is the line solid, dashed, bold, thin or just kinda there?
Mar 14, 2009 | HP DeskJet F380 All-In-One Printer
Samsung CLX-3160FN All in One Printer
open the scanning unit. in scanning unit clean the mirrors.
Sep 16, 2008 | Samsung CLX 3160fn All-In-One Printer
Panasonic Workio DP-1820P Laser Printer Logo
77 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
