Question about Janome Memory Craft Compulock
I think the machine has siezed where can i get it looked at?
When itry to turn it,,, it doesn't move at all so i think its seized is there anything that can be done ...
    Champion:
  • Janome Expert
  • 300 Answers
It is an expensive machine, all you will achieve if you take it apart yourself is causing damage and big repair bills. Take it in for service.
Posted on May 14, 2014
My kenmore 22 stitch sewing machine I bought in 1990; it doesn’t reverse anymore. How do I fix it
Those older machines do need regular cleaning and oiling. I suspect the oil has dried and caused the switch mechanism to seize. As time goes on, more parts may seize, so it's probably important to get it addressed soon. It could eventually damage the motor if the motor is trying to move seized parts. Well worth the expense if you value your machine.
Mar 19, 2018 | Kenmore Sewing Machines
I have a homemaker FY2300 sewing machine and it has seized it will only move enough for me to thread it but will not move after that. HELP
As complicated as they look, they are actually fairly simple in their operation. I know parts can wear out, but that is usually indicated by a gradual decrease in performance and an increase in noise. If a machine has seized it is usually for one of two reasons. It has jammed with dust and fibres from material or the timing is all wrong.
Open up and have a look at the inside of the machine and remove any bits, dust, threads etc that are accessible. It will benefit from oiling as well, but unless it is rusted it should move fairly freely by hand turning the wheel on the side. If it does move now check that the needle is going up and down and doesn't contact anything whilst turning the hand wheel. The needle tip will drop below into the shuttle but shouldn't touch anything and should come out again before the mechanism moves to block the needles travel. Do this for a few cycles and if it operates freely then put a drop of oil in the lubrication points.
If it is totally seized or the needle hits something then maybe a professional can help with a service.
Oct 08, 2015 | Sewing Machines
I was sewing and my machine locked up. Its a 910 bernina
Does the hand wheel turn ? Does anything move when you turn the hand wheel ? If not, may be a mechanical seizure, usually from overheating or maladjusted gears.
It may also be a seized thread. Thread may catch in a burr in the needle, or a burr in a thread guide. Check the entire thread pathway, make sure no loose thread is caught anywhere, there are no rough spots or burrs in any guide. Clean lint out of the bobbin area, and under the feed dogs. Make sure the thread hasn't wound around the spool pin or spindle, which can cause an abrupt stop in stitching, though it usually also breaks the thread and sometimes the needle too.
Clean it thoroughly, unthread and rethread. Those are always the first steps if something goes wrong. If you can get it moving and it happens again, turn the hand wheel slowly and watch to see if the thread is popping out of any thread guide, or out of the tension adjuster.
If the hand wheel won't turn, it may well be seized gears, which may be a costly repair. You can open up the machine and look inside to see if any gears are stuck, or missing teeth.
Do you oil this machine regularly ? All machines should be oiled periodically. If you use it a lot, oil more often.
Oct 09, 2014 | Sewing Machines
Riccar 5100 sewing machine siezed
Check for thread jam in take up crank
Mar 07, 2014 | Sewing Machines
Singer 6550
Sounds like your machine may be seized. Suggest taking it for service.
Mar 05, 2018 | Sewing Machines
Cannot turn hand wheel or sew.
Have you checked the bobbin compartment to make sure there isn't a thread-jam there? It can get so tightly snarled that even the handwheel won't turn.
Aug 08, 2017 | Sewing Machines
Machine has seized. Wheel will only turn a 1/4
It's probably out of time, or a belt inside has slipped. If it's computerized..could be a card burnt out. Wish I could help more, but I don't have this machine.
May 14, 2010 | Singer 1120 Mechanical Sewing Machine
362 pfaff does it overheat or what, it runs smoothly couple of minutes and then it gets slower and slower until it doesn´t want to move at all. I let them cool down for a while and then it works...
Actually, its seizing up due to a lack of oil. This is common when machines aren't being serviced on a regular basis. The machine is seizing after being used because everything expands when it heats up.
Feb 16, 2010 | Sewing Machines
Siezed motor
Well, AC/DC motors do "seizing" quite well in fact.
If you were supposed to oil it prior to the failure, they most likely will not work now! (Bearings are shot)
BUT.....Lady Luck is always hiding, so you never know.
Tear that dude down, and give it some 7-in-1 oil. Spin the motor BY HAND. See if she will "free spin". If she feels like a 6 year old fighting a catfish, it will be a "no go, no fix".
But if she WILL spin after that......give her a couple of drops extra, put it back together, and see how long she lasts.
And then keep on oiling it.
Granted, I can't tell you exactly WHAT seized your sewing machine up, OTHER than motors are motors, and bearings fail when they get dry. In this case, you might get lucky!
May 29, 2009 | Brother Sewing Machines
Sewing Machines Logo
120 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
