Question about Pioneer AVH-X5500BHS
How canI get rid of cracking and popping in my speakers when I use usb playback
    Problem Solver:
  • 45 Answers
Probably a bad connection! try using a Q-Tip and isopropol alcohol to clean both usb connectors
Posted on Jun 28, 2014
I need help with volume and popping and cracking in the speakers. It's a new system and it's only plugged into my record player.
You are most likely going to need a preamp to go between your home theater and record player. The popping and hissing is usually a grounding issue. You will have to ground your system properly to get rid of this.
Dec 21, 2014 | RCA Audio Players & Recorders
Magicjack and a usb handset device from tigerjet are suddenly in my computer's speaker mixers. now I get no sound through my computers speaker, however that sound is coming through my telephone speaker...
I am assuming you are on a windows machine.
Right click on the speaker icon (volume control icon) normally located near the time lower right hand corner of the task bar. When you right click a sub-menu should pop up.
Select "Playback devices" and then select the "Speakers" option you wish the sound to play back on.
Hope this helps.
Sep 07, 2013 | Computers & Internet
When i playback in WDM mode, i hear ckrackles and pops, when i playback in the other mode the ckrackles and pops are gon, but the input and output goes to none. how do i get rid of the ckrackles and pops...
1. check your user manual for clicks/pops.
this could be due to devices connected to the Edirol UA-25 or a television or microwave.
2. this also could be due to the setting in Windows Energy saving settings.
that is the Windows "sleep mode" and power saving mode.
3. this could also be due to the USB cable.
4. you may need an external filter device for the process you are using.
5. read your manual on Troubleshooting Noise ( clicks and pops).
Jun 14, 2011 | Edirol UA-25 External Sound System
Fujiysu siemens USB speakers problems (no sound coming out but the laptop Toshiba satellite speakers work , windows7)
Right click on the speaker icon in the System Tray next to the clock in the Start Bar. Click Playback Devices. In the window that comes up, select your USB speakers and click "Set Default" near the bottom of the window. Click Apply, then Ok. Your sound should now be coming through your USB speakers.
Mar 23, 2011 | Computers & Internet
No sound is coming out when usb is connected
Modern computers have various speaker options, much like amps. What you need to do is to find your actual speaker setup, and then place that as the default rather than the windows default.
Instructions for Windows 7, although others should be similar - Click on the windows start button (Lower left hand corner) - Control Panel - Sound (If you change your 'view by' option to small/large icon, you'll find this easier) - Playback tab
Here you will notice a color meter beside different speaker output options. One will be active when you play music, but no sound will come out as your speakers aren't actually connected physically to that device. You have two options here.
1) Easiest, but may cause problems in future if you change your speakers - Double click on the speaker, and disable it.
2) This option requires a bit more work, but will leave everything else enabled. - Double click on a speaker that doesn't have the meter moving - Advanced Tab - click the test button. If you hear sound, then this is the speaker setup you want. If not, try the next one. - close that pop-up window for the individual speaker, and go back to the main sound menu (Playback Tab) - single click on the speaker that works, and towards the bottom of the playback tab is an option to set it to default. Click on that.
Dec 25, 2010 | ION Audio iTTUSB Turntable
Speaker wires are pluged in on my dell inspiron 530 but not working help
    • 1 Make sure that your computer and speakers are plugged in, have power and are turned on. If the speakers are plugged in but don't appear to have any power, plug them into a different outlet. Some speakers are self powered and use a USB cable to supply power. Make sure that the USB cable of your speakers is connected securely to the USB port of your computer.
    • 2 Retest the sound. If you still don't have any sound, make sure the cable connecting the speakers to the computer (known as a 1/8-inch TRS cable) is plugged into the green audio output jack on the PC.
    • 3 If you're using self-powered USB speakers, remove the USB cable and plug it into a different USB port. If you're using outlet-powered speakers and have a working set handy, replace the suspected non-working speakers with the working pair to test.
    • 4 Navigate to the Microsoft Fix It troubleshooter (windows.Microsoft.com/en-US/windows/help/no-sound-in-windows) to automatically detect and fix sound playback or hardware problems. If that doesn't work, proceed with the next step.
    • 5 If you have an add-on sound card and none of the hardware or software fixes helps, you may have to replace the sound card. If you use on-board sound, it will probably pay to purchase an inexpensive sound card rather than a new motherboard. Check the system BIOS to determine whether you have inadvertently disabled your on-board sound.
    • 6 Navigate to the "Start" menu and select the "Control Panel" and "Sounds and Audio Devices." Then click the "Volume" tab. If everything is grayed out, proceed to Step 7. If the "Mute" box is checked, uncheck it. In "Device Volume," make sure that your volume level is set to a comfortable volume level for your speakers.
    • 7 Click the "Sounds" tab. Under "Sound Scheme," determine whether "No Sounds" is selected. If it is, click "Sound Schemes." A drop-down list will appear. Select "Windows Default" as the scheme. To test your sound now, click on a sound listed below the "Program Events" window. The sounds will be indicated by a small "Speaker" icon located next to them. Left-click the sound once, then click the "Play" button. If you still don't hear sound, proceed with the next step.
    • 8 Click the "Audio" tab. Under the "Sound Playback" option, make sure your sound card is selected as the default playback device. Usually, only one device appears here, unless you have multiple playback devices installed.
    • 9 If everything is grayed out, you either do not have a playback device installed or your drivers are corrupted and need to be replaced. Drivers help hardware and software function together. Fix this by reinstalling the appropriate drivers. Do this by navigating to the "Start" menu and right-clicking "Computer." Then select "Properties" from the drop-down menu. Click the "Hardware" tab and then click the "Device Manager" button. The Device Manager will open.
    • 10 Look for either a red X or a yellow question mark listed under "Sound, Video, and Game Controllers." If a red X appears, right-click the device with the X and select "Enable" from the pop-up menu. Test your sound at this point. If a yellow question mark appears, right-click the device, click "Properties" from the pop-up menu, and then click the "Driver" tab on the window that appears. Next, click the "Roll Back Driver" button to roll back to the previous drivers that were functioning correctly. Restart your computer when prompted.
    • 11 As a last resort, you can uninstall and reinstall the device. To do this, right-click the device and select "Uninstall" from the pop-up menu. Restart your computer. Windows will automatically detect and install your audio device upon boot-up. If you still don't hear any sound from your computer speakers, contact a qualified computer technician.
Nov 14, 2010 | Dell Inspiron 530s Desktop Computer
There is no sound from my speakers green light on
you have to install sound driver software to that supports your pc motherboard... then restart it will work...
Oct 10, 2010 | Harman Kardon HK206 Computer Speakers
My speakers are not working
Step 1
If no sound is coming from the computer, start troubleshooting your problem. Make sure both your computer and speakers are plugged in, have power, and are turned on. If the speakers are plugged in but do not appear to have any power, plug them into a different outlet. If you are using a power strip and this is case, replace the power strip. Some speakers are self powered and use a USB cable to supply power. Make sure that the USB cable of your speakers is connected securely to the USB port of your computer.
Step 2
Once you have verified that you have power to your speakers, test the sound again. If you still do not have any sound, make sure the cable connecting the speakers to the computer (known as a 1/8" TRS cable) is plugged into the green audio output jack on the PC.
Step 3
Before we move to software, let's try two more hardware fixes. If you are using self-powered USB speakers, remove the USB cable and plug it into a different USB port. If you are using outlet powered speakers and have a working set handy, replace the non-working speakers with the working pair to test. If you still have nothing, let's move on to software. But one tip first: (for geeks and beginners)
Step 4
As it is with any troubleshooting process, the issue can sometimes come down to the hardware itself. If you have an add-on sound card and none of the hardware or software fixes helps, you may have to replace the sound card. If you use on-board sound, it will probably pay to purchase an inexpensive sound card rather than a new motherboard. If you've been messing around in the BIOS, you may have disabled your on-board sound if that's what you're using. If you don't know what BIOS means, you probably haven't been there and can move on.
Step 5
Go to your desktop. Click Start > Control Panel > Sounds and Audio Devices > Volume tab. If everything is grayed out, go to step 8. If the "Mute" box is checked, un-check it. In "Device Volume" make sure that your volume level is set to a comfortable volume level for your speakers.
Step 6
Click the "Sounds" tab. Under "Sound Scheme" check to see if "No Sounds" is selected. If it is, click "Sound Schemes" and a drop down list will appear. Select "Windows Default" as the scheme. To test your sound now, click on a sound listed below the "Program Events" window. These will be indicated by a small speaker icon located next to them. Simply left click the sound once, then click the play button. If you hear sound, congratulations. If not, move on.
Step 7
Step 8
If everything is grayed out, you either do not have a playback device installed or your drivers are corrupted and need to be replaced. Drivers help hardware and software function together. Try this fix for reinstalling drivers. Click Start > Right-click "My Computer" > select "Properties" from the drop-down menu > Click the "Hardware" tab and then click the "Device Manager" button. Device Manager will open.
Step 9
Look for either a red X or a yellow question mark listed under "Sound, Video, and Game Controllers" If you have a red X, right click the device with the x and select "Enable" from the pop-up menu. Test your sound at this point. If you have a yellow question mark, right click the device, click "Properties" from the pop-up menu, and then click the "Driver" tab on the window that appears. Now, click the button "Roll Back Driver" to go back to the previous drivers that were functioning correctly. Restart your computer at the prompt.
Step 10
As a last resort, you can uninstall and reinstall the device. Right click the device and select "Uninstall" from the pop-up menu. Restart your computer. Windows will automatically detect and install your audio device upon boot-up. If after doing all of the steps, listed here and you still cannot hear any sound from your computer speakers, contact a qualified computer technician.
Please rate me if this solution works for you
Thanks......Have a great time.
Aug 08, 2010 | Computers & Internet
How can I get rid of the popping noise?
It is the speakers on the tv fluxing sound is too loud. Change your bass settings or use a different sound system.
Jun 03, 2010 | Vizio VO320E LCD TV
Trying to install a ion iTTUSB on computer but not
READ your quick start booklet. You need to go to control panel, open sound, there are three tabs- choose playback and make sure that the selected speaker is not USB Audio Codec-choose your speakers. In the Record Tab selcect USB Audio Codec.
Dec 15, 2009 | ION Audio iTTUSB Turntable
Pioneer AVH-X5500BHS Logo
50 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
