Question about Lexmark Lemark E352DN Laser Printer
I have a Lexmark E 352DN it was asking for the photo conductor to be replaced,I have done this and I am getting the same message. Any suggestions please
  • 320 Answers
Press and hold the select button and the back button
Power on printer when you see something in the display release
you should see CONFIG MENU use arrows till you see Reset PC Cnt. Press select see Reset. hit select should solve your problem
Enter the printer's Configuration menu:
  1. Power off the printer.
  2. On the printer's operator panel, press and hold the select button (I have a Lexmark E 352DN it was asking for the - pattlnk_11202006_2142-select_button.jpg) and the back button ().
  3. Power the printer back on while keeping both these buttons held down.
  4. When you see the messages Performing Self Test or Busy on the printer screen, you can release both buttons.
  5. If the printer has successfully entered configuration mode, you will see a new menu with the heading CONFIG MENU at the top of the screen.
Press the right arrI have a Lexmark E 352DN it was asking for the - pattlnk_4122007_1837-right_arrow.jpgnet/uploads/images/pattlnk_4122007_1837-right_arrow.jpg" alt="pattlnk_4122007_1837-right_arrow.jpg" cI have a Lexmark E 352DN it was asking for the - pattlnk_11202006_2142-select_button.jpgPC Cnt. Press once. You will see Reset. Press pattlnk_11202006_2142-select_button.jpg message and go back to the previous screen. 3 Press once. 4
Press or pattlnk_4122007_1837-right_arrow.jpg on the operator panel until you see Exit Config Menu. Press pattlnk_11202006_2142-select_button.jpg once. Selecting this will cause the printer to reboot.
If the counter has been reset correctly, the printer should return to a Ready prompt. 5
If this does not clear the PC Life Warning or Replace Photoconductor message, power off the printer and attempt this entire procedure again. If the error remains after two attempts, confirm that:
  • The correct photoconductor unit is installed. The part number on the photoconductor unit should be E250X22G. If it is not, install the correct photoconductor unit into the printer.
  • The photoconductor unit has not been refurbished by a third party or is not damaged in any way. If the photoconductor unit was refurbished by a third party or appears to be damaged, try replacing it again before seeking service on the printer.
Posted on Nov 02, 2009
Lexmark 352dn 31 missing or defective cart
The 31 error message means that the printer is detecting the toner cartridge is either faulty or not installed properly. You might need to replace your toner cartridge.
Nov 12, 2012 | Lexmark E352dn Laser Printer
Have a 200.13 paper jam error-check cartridge--??? no paper jam. I just put in new cartridge.
Here's an article on Receiving a Paper Jam Message When Using the Front-loading Manual Feeder on a Lexmark E250d/350d/352dn/450dn. Click on this link: http://bit.ly/cWZVZo. Read thoroughly, you might get some tips on how to avert this problem in the future. If problem continues, I suggest you contact Lexmark technical support to further investigate the problem.
Aug 19, 2010 | Lexmark E450dn Laser Printer
Lexmark c534n printer, warning for depleted color units do not go away after replacement
The supply counter must be reset manually after a photoconductor unit is replaced. Here's an article on How to Reset the Photo Conductor (PC) Page Count After Photo Conductor Unit Replacement on C52x and C53x Series Printers. Just click on this link: http://bit.ly/dk8nHs. Thank you for choosing Lexmark.
Jun 13, 2010 | Lexmark C534N Printer
What shoud I do when error 84 replace
Photoconductor is the part of the printer where the image gets created this is a very delicate and important part in the Laser printing process. If you open the printer and remove the toner, you should see it sometimes is like a green or blue color. The message 84 is just telling you that the photoconductor has reached the end of life and needs to be replace. Here is also a link on how to do the replacement http://bit.ly/bn2HFc
Jan 30, 2010 | Lexmark X342n All-In-One Laser Printer
ERROR 940 DE LEXMARK 352DN
y lexmark x73 manual de impresora lexmark t612 lexmark z710 free driver lexmark cartouches imprimantes gros lexmark 4270 error 1203 tiger direct lexmark fax ...
www.chippewacountyabstract.com/.../information.php?id=lexmark -
Dec 03, 2009 | Lexmark E 352dn Mono Laser Printer
When display "84 replace Photoconductor" appears, and we put aq new photoconductor into the printer, the same error message above comes back, and we can get by this point.
Turn printer off. Press and hold the right arrow and checkmark. While holding, turn printer on. Hold button combination until small clock appears on the screen. Once menu comes up, select the Reset PC count. That will fix your issue.
Oct 30, 2009 | Lexmark E350d Laser Printer
My Lexmark Optra SC 1275 message windo says PC is Exausted
You will need to get replacement Photo Conductor units.
Jul 24, 2009 | Office Equipment & Supplies
Reset Photo Conductor Kit
Hi!
For step by step procedure to reset Photo Conductor counter please see the following link---
Photo Conductor Counter Reset
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 02, 2009 | Lexmark E450dn Laser Printer
Paper jams
there are two parts to the copy of this machine, one is the photo conductor (drum, green cylinder ***'y) and the toner which fits in the drum ***'y.
you replaced the drum but you need to replace the toner as well (low toner)
then turn off and hold the start key an dturn on to get into service mode, scroll to reset photo count, select.
Aug 20, 2008 | Lexmark E340 Laser Printer
Counters
It should be under Utilities menu -> Reset Photoconductor Counter.
Nov 19, 2007 | Lexmark E232 Laser Printer
Lexmark Lemark E352DN Laser Printer Logo
992 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
