Question about Garden
I have a husky push mower that worked well foro years-no problems. Half way through moweing the lawn it starts sputtering, shooting out black smoke on the left of the mower. I no longer have the manual and understand I may need to adjust the air intake valve but don't know where that is. It has new gas and oil level is ok. Thanks
  • 84 Answers
Make sure oil is NOT black if it is replace asap. the air intake valve is on the carb which is located near the gas tank, its the switch on top.
Posted on Jun 24, 2009
My husband bought a 2011 Husqvarna YTH2348. I am the one that mows the grass. We had the mower serviced last week. We have a HUGE lawn and I mowed all but the orchard. The next day, I went out to finish...
Black smoke is generally indicative of a rich fuel system. whitish blue smoke is generally burning oil.
It sounds like there is something wrong with the fuel metering at full throttle. You might check that the mechanical compression release isn't coming on when you go to full throttle.
Aug 17, 2013 | Husqvarna Garden
I have a task force electric push mower and while mowing my lawn it started to smoke and shut off.. now it wont turn back on what could the problem be
it probably burn up if it smoked throw it away get a new one not worth sinking money into it to fix it
May 26, 2013 | Garden
5.5hp 21" Bolens Sputtering problem.
did you leave or use gas from last year? drain it and try fresh gas if not take the carb apart and clean it
Apr 20, 2012 | Garden
My cub cadet won't stay running. I can mow for a will and it just sputters, and or dies. I let it cool off for about 10 minutes.It starts right up after it cools. It also starts to smoke when it gets...
Similar issue - buddies CubCadet with Kohler Courage 22 would not stay running. Turned out the coils got rusty where it interacts with flywheel. cleaned the contacts (be careful to shim for proper spacing) and ran like a top.
May 29, 2010 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Just bought a 10 year old lawn boy 2 cyl mower from my neighbor. He had not used it for 5 yrs (heart problems). I put the 2 cyl ashless oil into the gas like the instructins said 32/1 mix. That turned out...
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helps
May 20, 2010 | RTO Lawn Boy 6.75hp Mower
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Engine runs but sputters after engaging blades
ck for water in carb bowl. also ck for filter in gas tank, or something in gas tank.
Jun 09, 2009 | Garden
Sputtering Mower
It might not be disengaging the mower deck all the way off. I had this problem on an older model.
May 20, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
224 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
