Question about Oster 78950-100
I have a oster groom master detachable blade pets can i put a human blade on this clipper if so what one
SOURCE: oster clippers
Found another web site where some one had posted the information I needed. I just used Google search and found the information.
Posted on Jul 15, 2008
wormosa1
  • 4 Answers
SOURCE: blade installation
i had the same problem and i fixed mine ( it is not broken) ... the tongue is the thing that is silver and has grooves that face upward, the tongue should be up compared to pressed against the shave, take a small screw driver or a kitchen knife and get under the tongue and lift it up, once this is done you need to slide it on the blades and snap it down, i found that i did not need to have the clippers on to put it back on.... at first i got confused in thinking that the tongue was the red thing at the top, and in actuality this is the thing that moves the blades to clip.... i hope this helps, once you get the tongue up the blades are on in 10 seconds...
Posted on Aug 14, 2008
SOURCE: NEED PARTS FOR OLDER OSTER CLIPPERS
I gave it a shot and it worked!!!....
No need to bother with the universal guards. They looked bulky for the task, and after careful (visible scrutiny) decided to gamble on the "fast feed clipper" guides. Check them out here:
http://www.cache-beauty.com/oster0541.html
There are surely other people who sell them - you might shop around, but I bought from these guys. Warning, the shipping price is kinda steep. But like I said in my last post, I've tried other clippers and these are just the best. It was worth it to me.
Anyway, I am now confirming that these guards fit this old clipper brand of ours. Perfectly!
Posted on Feb 03, 2009
SOURCE: can't put on a new blade
start the clippers then slide the blade onto the tongue of the hinge assembly , now push the blade into the clipper don't be afraid sometimes they can be tight from new,
Just make sure the two screws either side of the hinge are tight.
Posted on Sep 04, 2009
philschneide
  • 448 Answers
SOURCE: Bought Oster Golden A5 clippers new but did not
There is a small gun-metal colored bar at the very rear, just below the back of the blade. It pushes inward, in the direction of the blade. Push it firmly in and pull up on the teeth of the blade. It should pop upward. You can then remove the blade from the tongue that it sits upon. When you want to put it back, slide the blade back on the tongue, then, WITH THE MOTOR TURNED ON, push the blade down to its seated position. It will click into place.
Terms regarding these devices are all too often assumed as understood. For most purposes, these are what you have to know for the A5 Oster. The cover plate is the part with two screws that has the name and other info on it. If you remove the two screws and the plate, you will see a nylon part that moves the blade back and forth--that is the lever. The other end of the lever, with a hole in it, is connected to a metal part called the link. Both parts are easily removed by simply pulling them upward from the device. The bakelite gear is the part that the link sits on (the larger hole in the link). It too can be simply pulled up off the metal shaft that it rides upon (careful not to lose the washer under it). That gear is turned by the armature gear of the motor (which is where things get much too involved to cover here, but from that point on the device very rarely has problems). Incidentally, the lever, the link, and the gear can all quite simply be replaced. They are available quite inexpensively at Amazon under Oster A5 Clipper parts (note that the one speed and the two speed take different bakelite gears, but the lever and the link are the same). If you were to replace parts such as these or simply lubricate them, remember that a good white lithium grease is recommended in light application for the gear and the shafts (lever and gear shafts and armature gear). Also, the gear shaft has a hole down its middle (and two small holes that lead to the outside of the shaft. The shaft should be filled with grease so that grease can get through those small holes to lubicate the inside of the bakelite bearing. The two pads (one on each side of the lever) should be oiled. The simple way to tell if you need to replace parts is to grip the blade end of the lever while all parts are in place and try to move it back and forth, as though it were running the blade. If there is any more than the slightest movement, replace the lever (replace that anyway if the part that contacts the blade is rounded off) link and gear.
Good luck.
Posted on Oct 03, 2009
How do I take off Blade
I'm pretty sure from memory the blade will pull off from the front edge. There should be a black metal bar at the rear end of the blade which you can push in so the blade will pull off.
Jan 05, 2016 | Pets - Others
How do I change the blade?
There is a small button at the bottom edge of the blade, push it in and at the same time push the blade teeth away from the clipper. The blade will hinge away from the clipper, you then lift the blade up off the tongue. When fitting another blade pop it onto the tongue, turn the clipper on and snap the blade shut.
Mar 31, 2015 | Oster Turbo A5 2-speed Dog Pet Clipper...
Conair clippers manual
RTM. Read the manual. You can find a manual in .pdf format if you use Google and put in the make and model and manual and you should get results.
Aug 23, 2014 | ConairPro Canine FX Turbo-Groom II Pet...
The brand new gear lever on my oster a5 isnt moving the clipper blade
make sure the blade is clicked into place fully, secondly check to see if the blade is sitting further away from the clipper than usual, it could also be a stripped gear inside the clipper does the lever move when the blade is engaged?
Jun 21, 2014 | Oster Turbo A5 2-speed Dog Pet Clipper...
Oster blade no. 913-50
http://www.ebay.com/itm/Oster-Blade-Set-913-50-Fits-Fast-Feed-17-tooth-76913-506-New-/130803957423
Mar 09, 2014 | Oster Corporation Pet Oster Performance...
Does someone know which # blade to use with the Oster, universal comb set for use with the Oster A5 turbo clipper?
Hi, as far as I know you're suppose to use a size 10 or 30 blade with any combs. I prefer to buy a longer blade like a size 4 rather than using the combs as I find the coat finish not great with the combs.
Feb 06, 2013 | Oster A5 Turbo Clipper Kit-10,40 Blades&5...
Oster A5 clippers work briefly then "pull" hair
Lever arm worn, blade blunt, or loss of movement inside the gearbox. It is possible to have a 'bad' sharpen.
Aug 03, 2012 | Oster Golden A5 Single-Speed Clippers
Where do i grease a oster shearmaster
Undo the 2 screws from the FRONT that go through the aluminium housing into the yellow housing. They are either side of the blade tension thumb screw. Pull the housing off and that will allow you to squirt the grease into the gear assembly.
Jul 19, 2012 | Oster Corporation Shearmaster, Color:...
Oster 78950-100 Logo
52 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
