Question about Refrigerators
My refridgerter leaks inside. I have it set at 3 which is the recommended setting. It is about 11 years old. Items placed on the bottom shelve at the back, tend to freeze. It's a Whirlpool, model # ET18PK.
docjohn174
  • 943 Answers
SOURCE: Whirlpool ED5VHGXML10 Side by Side Door shelves cracked
HI thanks for your question. its the door liner, that's broken, if you can repair with some epoxy puddy, only problem with epoxy puddy , it smells. so the door liner is to be replaced. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 12, 2008
sdmc73
  • 121 Answers
SOURCE: GE Profile refrigerator model PFCS1NJWA is freezing items in back
slow air flow will cause it to freez check air flow from freezer in at the top and back at the bottom
Posted on Nov 30, 2008
peyton32034
  • 410 Answers
SOURCE: whirlpoo refridgerator question
if it frrezes up even with the control set to 1 then you have a bad temperature control. the t-stat is loacted in the control housing in the refrigerator section. this housing is usually held in place by 1 screw near the front then swings down for access. you can get pt#2201754 from sears or a local appliance parts house in your area. just 2 wires so its not hard to do.
sorry it took so long to get back to ya. good luck peyton
Posted on Jan 27, 2009
  • 531 Answers
SOURCE: My whirlpool refrigerator W-21 model #
clogged drain
Posted on Apr 01, 2009
  • 531 Answers
SOURCE: Refridger Freezes items on shelves and in drawers
check coldcontrol or damper control settings
Posted on Apr 07, 2009
What is the best way to display my china in my china cabinet?
If done correctly, your china cabinet can be a work of art. When designing your cabinet divide it into three sections - left, middle and right side. Most china cabinets come with three shelves and it is a good idea to coordinate each shelf with similar groupings. If your cabinet has a light on the inside at the top, I recommend displaying your crystal items on the top shelf. The middle of the second shelf is your focal point. I recommend displaying a complete place setting of your china. On either side display other items that match your place setting. On the bottom shelf, place a few key pieces from your china set - such as a gravy boat or a set of salt and pepper shakers.
Here is an image of a well-designed china cabinet -
Sep 02, 2012 | Acme Furniture
Model GR 382-R serial # 208MR36393 only 7 years old, not main fridge, is freezing all items in bottom, called in repairman, after 1 mo still cannot get my fridge repaired.
The damper could be sticking open or in some models, the bottom of the air tower will need to be sealed. The setting may also need to be adjusted. The recommended setting is just a normal starting point under ideal conditions. Try setting it slightly warmer. If this is electronic, it could be a board or sensor problem.
Jan 26, 2011 | LG Refrigerators
8 year old Whirlpool Gold refrigerator: Freezer icing up. Found ice on shelves and on the bottom under the vegetable hydrators. The shelves and drawers constantly have a humid film on them. Last week,...
for no frost type;cleaning of freezer cub underneat is a must...cloggged drain outlet buildup thick frost on your freezer cub..
.ie..for frost type;you must set your thermostat setting to normal,replace it with new one
Oct 20, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Do the door hinges ever wear out
I did my own search for the same problem and saw Dougs question and lack of a solution. I have the same sagging door problem and was looking for a fix.
First, when I removed the weight of the items from inside the door, the door closes properly. This means that the door is not very sturdy and cannot hold the weight of items placed on door shelving. There are NO adjustment mechanisms on the door hinges either. Bad on Amana. The GOOD NEWS is that I fixed the problem.
Take out all items from the door shelves. I removed the top hinge with the door closed to keep it from falling. I took the door off and placed it on the floor. The lower hinge has a plastic pivot over a steel pin - remove that for a moment. Place steel washers over the steel pin - about .080" or so thickness. Replace the plastic pivot. Replace the door. Add the normal weight of items back on the door shelves. The door closes perfectly. At least until the door sags again and I'll need to add another shim.
Jun 21, 2010 | Amana ABB2524DE Bottom Freezer...
Water pooling in the fridge.
excess water usuall y means there is a blocked drain tube in the bottom of the fridge.this can be cleared by using a small bottle type brush and run down through the drai hole to clear it.also check the drain tube from the rear of the fridge and make sure there is no obstruction near the drain pan
Feb 24, 2010 | Refrigerators
Freezer froze on top thawing on bottom
Dispose of the unit and buy a new one. If it leaked the refrigerant out you have to fix the leak before charging it again. The chances of finding the leak are slim.
Sep 01, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Leaking water
the water reservoir tank could be your problem, take out the drawers and operate the dispenser and see if water is leaking from it. if so replacement of the tank is very easy
May 21, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Whirpool Refrigerator Door Shelves Not Cold Enough
The door bins are the last place you should keep milk. The door shelves are always the warmest part of the fresh food compartment (of any refrigerator). Sorry.
Apr 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leaking in refrigerator on shelves, drawers, and under draw
We took the back bottom vent cover off. Clean that area of lint. We than followed the advise given to another posting of a refrigerator link. This has seemed to work for now, time will tell. However we were told most people with Haier refrigerators have problems. Thank you.
Feb 15, 2009 | Haier Refrigerators
Maytag freezer
sure its on ly 3 years old. you rseled system should be covered for 5 years (compreessor, freon, evap, condesor). was it making a buzzing noise?? trying to start and clicking right off??? thaose are sounds a bad compressor makes,
Mar 19, 2008 | Maytag Freezer MQU2057
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
