Question about DeLonghi EAM3500 Espresso Machine/Coffee Maker
Not hot enough
Set to high,descaled
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 51 Answers
There is a setting between "Warm, Normal, Hot and Extra Hot" however no espresso machine will "boil" the coffee, as this would burn the coffee and taste disgusting.. The best thing to do is to zap the coffee for a little while in the microwave if you like a scalding cup of coffee..
Posted on Jun 21, 2014
My keurig b60 says prime
This can go out by draw out some hot water. However if this happens very often then you need to perform a descale.The brewer should be descaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. Descaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend descaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The descaling process involves using 48 ounces of undiluted white vinegar. Learn how to descale your brewer.
Feb 24, 2012 | Keurig B60 Coffee Maker
I have a Solis Palazzo machine. My question is:
HI When was the last time you descaled? This can have a temp lowering effect if you don't descale on a regular basis. Program you water hardness so its set on 4. This will tell you when you have to descale. Descals is not the same as cleaning. Its a special acid that disolves the deposits inside the boiler.
Jul 24, 2010 | Solis Palazzo Espresso Machine
How do you descale a Saeco Magic Comfort Plus coffee machine? do you buy some fluid from somewhere and pump it through or what?
Hi
To descale your Magic Comfort +, enter the menu and scroll to descale. Push the menu button to descale. Mix your solution in your water tank. Use warm to hot water and dissolve all the solution. Place the water tank on your machine. With a container under the steam wand that is large enough to catch all the water in the tank, you are ready to begin. To start the descaling process, open the steam knob. The machine will automatically start the descaling process and when it is finished, it will shut off and tell you that it needs to be rinsed. Remove the water tank and rinse with fresh water. Refill the water tank and place it on the machine. Turn off the machine, wait a moment, and then turn it back on. Press the hot water button to start pumping fresh water through the boiler. Pump out about 16 oz. of water and then turn off the hot water button and open the steam knob to rinse the steam boiler. When it starts to go to steam, turn off and turn on the hot water button again. Pump out another 16 oz. Repeat this process with the steam knob until you have emptied the water tank. Descaling is complete. Go to your menu and scroll to "reset descale", push the enter button and chose "Yes" and push the enter button. Now it will tell you we next to be descaled.
Jun 11, 2010 | Saeco Magic Comfort Plus Espresso Machine
Saeco royal professional excesive hot water and steam though capp
HI
These machines run water through the boilers and is heated to either 192 degrees for the main boiler or 250 degrees for the steam boiler. There is mineral in all water except distilled. That mineral deposits itself inside you boilers and needs to be removed. I guessing that the water hardness in your menu is set on 1, but should be set on 4. You need to descale more often than not enough or you get what is happening to you right now. I am hoping that a good descaling will do the trick, but it might take 2, that it needs. Use a commercial descaler for espresso machines, not vinegar which will leave a taste for about 2 weeks.
Oct 25, 2009 | Saeco Royal Professional Espresso Machine
Need descaling instructions for EAM 4500 auto espresso machine
use 1/4 cup of vinegar and fill pot with cold water, run through machine
Aug 01, 2009 | Coffee Makers & Espresso Machines
Steamer working only intermittendly
Hi
Have you tried to descale your machine. Remember to use the correct descaling powder and make sure that it is totally dissolved before running the descale program. In the menu, make sure that your water hardness is set on 4. descale more often than not enough.
Jan 30, 2009 | Saeco Royal Digital Plus Coffee...
Coffee Not Hot Enough
probably need to descale the machine scale stay on the heater and doesnt heat as much use descaler not vinegar thanks pierre
Jan 11, 2009 | Krups Small Appliances Espresso Machine
Coffee is not coming out hot enough
How old is the machine?
Do you descale it regulary?
If ther are calcium in the boiler then you get this problem.
Jun 17, 2008 | Rancilio Silvia Espresso Machine
Expresso machine
descaling gonna improved the pressure = stronger coffee and clean the inner boiler =warmer coffee but use descaler only not vinegar descaler melt calcium vinegar remove some calcium in littlt piece 1 part descaler 1 part water fill the water container open valve for a few second close it leave it for 15 minute and repeat untill empty after rince very good that stuff is corosif
THANKS FOR USING FIXYA
FROM MONTREAL CANADA PIERRE
Feb 18, 2008 | DeLonghi BAR 14 Espresso Machine
Solis 5000
Kim, I'd like to know what you found out from Solis support. I have the same really bad leaking problem. When I dismantled the cover and peered inside I saw what appeared to be white stuff (perhaps lime buildup)on the outside of the pump. I descale every 3 months. I wonder if perhaps the my gasket is bad, too??? You may find this following article about this repair interesting. http://www.coffeegeek.com/proreviews/detailed/master5kdigital/twoyear
Sep 25, 2007 | Solis Master 5000 Espresso Machine
DeLonghi EAM3500 Espresso Machine/Coffee Maker Logo
170 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
